Question about Makita 1,100 Watt 2.5 Hp Portable Power Generator #G1100
Makita G11oo portable generator. starts on choke. cuts off run
I have a Makita G1100 portable generator. Getting prepared for the hurricane season, it started, but when turned to run, rpm slows down picks up and cuts off
  • 1,305 Answers
Just noticed your question... If you still need a little help:
1. If the gas is from last year, drain the tank and the carb bowl and replace gas with new. Visually inspect the inside of the tank ..be sure there's no sediment that needs to be cleaned out.
2. remove air cleaner and make sure it's not plugged or dirty
3. plug the spark plug and clean with spray carb cleaner.
4. At end of season, mix some gas stablizer in with the fuel to keep it from going bad while in storage.
Let me know how it goes..
k
Posted on May 31, 2009
  • Julio Maza Jun 14, 2014
    i've had the unit stored for a while, it won't start, whats the process to get it started.
Leaking gas overflow
The float is probably stuck, or there is debris in the needle valve seat. may be time to rebuild the carbureator.
Jul 18, 2014 | Makita 1,100 Watt 2.5 Hp Portable Power...
Makita concrete saw, no spark, new ignition coil.
Check clearance between the coil and magnet, too far away and magnetic field won't generate.
Apr 13, 2012 | Makita DPC7311 73cc 14Inch Gas Powered...
What tipe of oil makita generator g1100 takes
Great generator, i use 15/40 Quaker State it seems to work well for my uses, i have same one, but is 2000. check your manual if your really concerned, the whole thing, is keep oil fuel, and changed often. Hope this helps mike
Jun 13, 2011 | Makita G1100 1100W Generator
Generator will not run. Can start generator by spraying gas directly in to carburetor but will not idle/continue to run. Not currently connected to load. Trying to prepare for hurricane season. Can...
you have a blocked up card jet strip carb and clean out all jets
check fule flow from tank as well also clean all filters air + fule
best advice on missing hurricanes,,is move away?
Aug 14, 2010 | Honeywell HW5500E Portable Generator Not...
Won't run without choke on
main jet on carb is dirty.colemans work better if you keep the load balanced also
Aug 04, 2009 | Coleman Powermate Premium Plus 6250W...
What will a 2.5 hp engine run please?
It's a 1100 watt gen, so you have 1100 watts available to use. All electriccal equipment is rated it volts and watts. Just do the math...
Jul 18, 2009 | Makita 1,100 Watt 2.5 Hp Portable Power...
Makita Generator G2800R
Check your tank for contaminants (water, trash, dirt, monsters, etc), as well as the balance of the fuel system. You may also need to remove the carburetor and clean it out, particularly if the generator has sat for more than a month with fuel in it (most do, including mine) and now has deposits. The only thing that the choke does is make the mixture rich by cutting off the air.
And just for grins, look at the spark arrestor screen on the muffler. This can be related and problematic as well.
Mar 10, 2009 | Makita 2,800 Watt 6 Hp Portable Power...
Makita 1,100 Watt 2.5 Hp Portable Power Generator #G1100 Logo
381 people viewed this question
Top Makita Electrical Supplies Experts
Craig Butler
Craig Butler
obsteiner
Tom Chichester
Are you a Makita Electrical Supply Expert? Answer questions, earn points and help others
