What does F-06 mean on a Hotpoint Aquarius WMF940
5 Suggested Answers
SOURCE: WMF940 Child lock will not deactivate?
unplug the machine completely and plug it back in. Wait a second & it should deactivate.
Posted on May 25, 2010
FitzOriginal
  • 842 Answers
SOURCE: hotpoint aquarius wmf940 wont spin or drain water
This is simply a problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. Your repeat of the rinse/spin cycle is giving it extra empty time and then the spin works OK.
You need to locate and clean the filter. Depending on the model (not sure which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom ( behind the clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked. Ofter that, unscrew the round cap, remove the filter and clean.
If the filter is not there, you will need to access the debris trap from the back of the machine. If there is no filter at the front, pull the machine out and you will see a roughly oval panel at the bottom of the rear of the machine. Unscrew the 3 or 4 screws and unclip. Directly below the drum, you will now see a rubber "Cup" like bulge in the black pipe, with a plastic tube connected to a plastic pipe. The cup is held in place by a large jubilee clip. Unscrew the clip, pull off the rubber boot to expose the debris trap (A conical plastic cage with a ping pong ball in it) Take out the ball and the plastic trap, clean out the debris and replace the trap and the ball (Note that the cage may have a slot in it that locates in the rubber boot, make sure it lines up, or it won't reassemble correctly). Now push the boot back onto the fitting at the bottom of the drum where it came from and tighten up the jubilee clip, making sure that it is fitted correctly (it too may have a small slot out of it that fits around a protrusion on the bottom of the housing).
Posted on Jul 10, 2011
  • 6277 Answers
SOURCE: hotpoint aquarius wmf940 filter cap wont come off,
Had the same problem with our Bosch, cap would not even turn!
Suggestions-
pour anticalc/limescale fluid into any gap there is around the cap. Empty the machine and you can switch it off providing the door is open! Then pour the contents of at least 2 sachets of proprietary anticalc powder/liquid into the drum direct together with a kettle full of boiling water. Leave overnight at the very least. The following day run just a spin cycle as then there will be no water diluting the mix. This mix will go through the filter and motor and is likely to help release the filter/cap. If you feel like it, do the overnight again. If nothing else it will ensure that the heater element is clean!
I had to spend a couple of hours gently turning the cap back and forth until it finally released its hold- but the filter did not remain attached to the cap by its rubber ring. More patience, anticalc fluid and all was revealed!
I now run an anticalc clean regularly............which reminds me..............!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 18, 2011
  • 114 Answers
SOURCE: im getting error code f-06 what does this mean?
sorry but f-06 is not coming up as an error code for this model, if you can post up the full model number or product number illlook into it again
Posted on May 23, 2012
My hot point aquarius wmf940 washing machine door won't lock
If this model has brushes check them first.
check wiring to door lock
new door lock
new board/motor.
This is the order i would go at trying to solve the problem
May 23, 2012 | Hotpoint Washing Machines
Im getting error code f-06 what does this mean?
May 25, 2010 | Washing Machines
Hotpoint Aquarius Fault Code F-08. What does this mean?
F08 means Heater relay stuck: check pressure switch, heater & module connections..
Dec 10, 2009 | Hotpoint Aquarius WF000 Front Load Washer
My hotpoint aquarius washing machine wd 640 is showing the fault h2o
The code h20 indicates means (not filling)
check the tap/s, hoses, and water inlet valve/s.
Please leave feedback.
Thanks.
Nov 12, 2009 | Hotpoint Aquarius WD640 Front Load...
Error code f-01 on hotpoint washer dryer aquarius model wd 640
f-01 means there is a motor problem.
may be the motor and/or the circuit board that controls it.
Jan 05, 2009 | Hotpoint Aquarius WD640 Front Load...
How difficult to Replace bearings for Hotpoint Aquarius WF 745
have fun! i woundnt like the job .that means its very loud in spinand the tub water seal has gone bad
Jan 01, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
