Question about Canon PIXMA iP1600 Printer
How do I reset the printed head on a Canon Pxma 1600
2 Suggested Answers
jell587
  • 447 Answers
SOURCE: reset canon iP 1600 waste ink counter
This link should help you with your problem.
Posted on Feb 21, 2009
Suport code 1702 pxma i cant print
Hi Rolando,
This error relates to the ink absorber being almost full. You should be able to press ok and continue (unless you've already done that in which case, the ink absorber is probably full). http://canontechsupports.blogspot.com.es/2014/09/how-to-fix-error-1702170317041715e08-in.html
Aug 16, 2016 | Canon PIXMA Office Equipment & Supplies
IR 1600 print server
Interface Connections Ethernet (10/100BaseT) (Optional)
IEEE 1284 (Parallel)
Token Ring (Optional)
Any print server that offers the above connections, do a Google search.
Mar 12, 2014 | Canon Computers & Internet
I have a Canon printer PXMA IP6000 D. I suddenly will not print. I get a code, "Service Error 5200". I have tried turning it off and checking for a paper jam. Nothing works. Can you help me? Gary
1.Reset the printer
Follow these steps to reset the printer:Turn the printer off with the Power button (if available).
Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
Turn the printer back on.
2.This is the waste ink reset proceedure and should clear the error (Waste ink absorber full [5B00] )
1. Power off printer2. Hold Resume button then press and hold POWER, the beeper will sound once.3. Keep holding POWER and release RESUME 4. Press RESUME twice, then release all buttons 5. When the indicator lights steady, press RESUME four times. The indicator should be orange. 6. Press Power to set data .
3. According to the service manual error 5200(LED alternateblinking in orange and green) indicates Print head temperature rise error ( The error means the print head is getting too hot.)
- Re-seat the print head
Confirm that the printer is powered on.Open the paper output tray and top cover.
Note: Gently open the paper output tray while holding it.
After confirming that the print head holder has moved to the center, open the inner cover.
Remove all ink tanks. >> click HERE <<
Raise the print head lock lever and remove the print head. >>Click HERE <<
Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard >> Click HERE <<
Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner. >>click HERE<<
Close the inner cover and top cover.
Note: Check that each ink tank is installed in the correct position. >>click HERE<<
4.If the problem persists ,the print head may be defective and needs replacement .Here's a link to your service manual in case you need to confirm >>manual/hp/iP6000Dsm.pdf <<
Oct 15, 2011 | Canon Office Equipment & Supplies
How do i get and install driver for printer Canon pxma 270
It is pretty simple
Go to this global Canon site and download drivers/software and user manual for your printer.
http://usa.canon.com/cusa/consumer/products/printers_multifunction/photo_all_in_one_inkjet_printers/pixma_mp270#DriversAndSoftware
I am sure this will help you.
Good luck
Jul 04, 2011 | Computers & Internet
My pxma mp 600 canon printer is printing black lines through some of the lines on the page. I have tried all cleaning and alignment instructions in the manual. Did not help.
Do you have these black lines on the back of the paper as well. I bet you do. They are caused by the waste ink pipe overflowing onto the paper and not into the ink absorbers. Alas you cannot fix this yourself as the printer engine needs to come out and a modification carried out (it lengthens the pipe) Its a pain of a job even for a Canon engineer but its the only answer i am afraid.
Srri
Jun 30, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Printing labels setup on the PXMA MX860
You don't need to do anything to set the printer up except to tell it you have heavier stock than normal.
Your answer lies in the program you are using to print labels. Please tell me which program you are using and what other office type programs you have on the computer and I will try to give you a viable solution.
Chris
May 27, 2009 | Canon PIXMA MX850 Multifunction Printer
Paper jammed @the output/slot or the auto sheet feeder of my Canon PXMA MP530 Printer. I had put UPS Priority Label 2x 3.5" x 4>5" into the auto sheet feeder. I cannot see either label. And...
move the printer head with ur hand, slowly and tried ur best to look into the printer and if there appears to be a piece of paper stuck then remove it...
Dec 04, 2008 | Computers & Internet
Canon IR 1600 error message
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET." Power the unit off/on.
May 17, 2008 | Canon imageRUNNER 1600 Laser Printer
How to change from black ink only to include color printing
Go to printer settings on control panel and change to print in colour
If you don't have manual go to
http://alpha03.c-wss.com/inc/ApplServlet?SV=WWUCA900
Dec 17, 2007 | Canon PIXMA iP1600 Printer
Canon PIXMA iP1600 Printer Logo
13 people viewed this question
old marine
old marine
