Question about Dryers
How do I get the dryer apart. I have a mouse that climbed into the intake and died
I have a mouse (dead). How do I take the front or back off of the unit? The mouse is not in the exhaust. Must have climbed into the intake. Not covered under warranty because it's a foreign object. I disagree, I'm confident its a domestic mouse. Ha LG DLEX3001R
  • 1 more comment
  • moneyhippo May 21, 2009
    I have the front panel off. And the circuit board. There isnt anything in the coils (it's electric) and nothing in general in the open area around the coils, belt, etc. Took the piece before the blower off, not there. Must be somewhere in the intake which is behind the drum.
    They seriously make this so the back wont come off? How do I get to the intake?
  • moneyhippo May 26, 2009
    OK. I found it.
    Actually, it's what I didnt find after taking the thing apart that may be helpful to some of you here. After about six hrs of prodding around the innards of my dryer ......... no mouse. What had happened, it I have a air circulatory thingy on my dryer vent tube - to recirculate hot air back into the house in the winter. I had it held open with a piece of duct tape which had come loose and closed (completely) the exhaust. This left the wet air with nowhere to go except to build up, get nasty, and circulate the stink back into the drying compartment.
    Hope that helps someone.
  • steve
    steve May 11, 2010
    You will have to remove the front panel to access the inside of the dryer.
  • Dryers Master
  • 3,361 Answers
Good for you. All you needed was a little confidence to look around.
Glad you found the problem.
Posted on May 26, 2009
  • 20 Answers
Not sure but my front load dryer (kenmore) has two little screws on top back of dryer which allows you access to unit....if it stays inside long enough the heat will dry out body and VIOLA no more stink!!!....easy for me to recommend from my house ....Good Luck!
Posted on May 21, 2009
I have a 1986 Porsche 944 turbo which was running well except for injector was leaking after intake removal to replace vacumm delay valve.put in brand New injectors and the issue started. Porsche starts...
You have a large intake leak, un metered air leaking after your maf. Grab a can of intake cleaner, start your cAr and start spraying your intake and any vacuum lines. Any change in idle activity is where I would double check
Oct 22, 2013 | Cars & Trucks
Odor
if you have a bad odor,pull off the vent line from the back and see if an animal is dead there,i've found dead birds,mice and a possum,in the blower wheel of some dryers,they get in from the outside hood,once they get into the vent line and slide down they can't climb back out or if the dryer is running the wheel does a job on them.also if you had some painting or staining done this also can make the dryer smell bad.this is going by what i've found when someone complains about an odor in the dryer.hope this helps,one more thing if the motor is overheating from the dryer not being cleaned out it could have like a shellac smell,you might have to take the dryer apart to see what's stinking or it could be something near the dryer,when the air is heated in the dryer it makes the smell worse but if you find waht is causing it and remove it the smell will go away,if it is from a dead animal you can wash down the area with soapy water,you don't want to use anything with a strong smell because your clothes will smell of that when the dryer heats up.what does it smell like?
Apr 13, 2013 | Maytag Atlantis MDE6400AY Electric Dryer
Dryer is not drying- wet lint in the filter
Maybe you have a dead animal, (mouse,rat etc) inside of unit. They could have died whilst chewing the wiring, hence the no heat problem. Take off the panel on the back of unit or tip it on it's side. You should be able to see the inner workings and anything else. If not, buy a new dryer, this one must be costing heaps to run.
Dec 14, 2011 | Dryers
How do i clean the lint trap in side the dryer. I can't figure out how to take it apart.
There must be two vents going into the interior of the dryer, one is the intake (where the hot air comes from), the other is the outtake (where the lint trap must be). Locate the two vents and see if one of them has anything removable near it, or if the vent itself has finger holes or something that you can grab and pull or slide it open.
In some front loading models the two vents are at the back and both look like nonremovable vents. If that's the case, one actually pulls right out easily. It might then have two parts (the grate on the dryer side and the screen on the exhaust side) that snap or slide apart, with a space between for collecting lint. If that's the case, and you haven't cleared it in a long time, it will be packed full of lint. The two parts snap or slide apart, then you can get at the lint and remove it. Then snap or slide it back together and just push it back securely in place in the dryer.
Jun 13, 2010 | Maytag Atlantis MDE7657BY Electric Dryer
Bad odor from dryer
A dead mouse would have crawled up fro the bottom. Carefully tip the unit back and see if you have an unexpected guest.
Feb 16, 2010 | Maytag Dryers
My drier smells like a animal has died when heated up.
You will have to diss-assemble the dryer to look for the cause. I have run into that problem before, and found that a mouse electricuted himself by contacting the exposed wire terminals on the motor. When the motor warmed up, the dead animal smell was there. There are a lot of areas where a mouse could come in contact with live voltage and end up dead on an area which heats up, like near the heating element.
Jan 26, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
A bird has managed to get in through the vent and die. We're trying to take the front off of the dryer but there must be a screw somewhere that we can't see. Do you have drawing of how the dryer is put...
Take off the back and save on time, the front is plastic notches and one screw buried inside on the blower! Go to www.apdepot.com and punch in your model as looking for parts, there good and giving good pics.
Sep 29, 2008 | Bosch Dryers
Need to get inside a maytag dryer. i think i have a dead mouse inside
depending on what model it is, there should be 2 screws on the bottom of the front  panel. take those out and pull the bottom toward you and unhook it from the top panel. then you can see inside the dryer pretty good. btw there is a small panel in the back you can take off to get a better view if needed.
Jun 28, 2008 | Dryers
Dead Mouse
Try different USB jack. Try fresh batteries. Re-install software.
Sep 22, 2007 | Logitech 9311570403 Mouse
Dryers Logo
145 people viewed this question
Top Dryers Experts
