Question about VIA Computers & Internet
Tv keeps cutting out - VIA Computers & Internet
The sound on my TV keeps cutting out. It cuts out for 1-2 seconds. It does this approx. every 30 seconds. I have changed cables and cable box....no change. Any suggestions?
Sounds like the final audio amp MOSFETs are overheating.
After set has been off and unplugged check for dirt and dust clogging cooling fins and parts. Air must circulate for cooling. Remove dust with a gentle blast of air or an upholstery brush attachment on your vacuum cleaner.
If this doesn't work the parts usually cost more than a modern set is worth and I suggest purchase a new set.
Nov 26, 2015 | Televison & Video
Why does my TV screen keep cutting out
do you lose the audio signal when this happens ?
Sep 05, 2014 | LG Televison & Video
My tv keeps saying stand bye and it won't cut on all its doing is making the click noise and the red light keep blinking
Try unplugging it for 30 seconds and see if it resets. If not, take the model # and get on the internet for the manual and go to trouble shooting page. It should answer your questions
Feb 13, 2013 | Televison & Video
Sound keeps cutting off
Bad smd audio output ic. Are hard to replace, may just need to replace main board.
Nov 16, 2011 | Televison & Video
The hd tv keeps cutting out and saying no signal
It not the tv,u restart the Sky HD box the signal come back right?The Sky HD box is the problems,replaced the box,u will solved this problems.
Apr 22, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
My samsung tv sound keeps cutting out. I have to
either you have a loose connector going to speakers or the main board is failing.call 1-800-samsung for nearest service center.
Dec 02, 2009 | Samsung LA40A450 40 in. LCD TV
My tv keep cutting itself off. I will have to
It could be going into power saving mode. Check your settings.
Hope this helps.
Iain
Oct 14, 2009 | Computers & Internet
Why do my tv keep cutting off by itself?
check your tv if the timer is on..if the timer is on,off it..
Jul 28, 2008 | Symphonic ST420FF 20" TV
Computers & Internet Logo
37 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
