Question about Wahl Designer 6 (8355100)
Wahl clippers too loud or won't cut. Do they just get tired at some point?
I don't have the instructions for adjusting the clipper but it won't work unless it's buzzing to an unbearable level.
5 Suggested Answers
geokohler
  • 304 Answers
SOURCE: wahl designer clipper
Have you been oiling the blades? If you ran out of oil you can use any light machine oil available at any hardware store. If you feel comfortable opening the unit you will be able to see the electromagnet inside and watch what is going on. If all else fails Buy a new set (the exact kind) and keep the receipt. Swap them out and return it from the store where you purchased it. You paid good money for them and they should not have died so quickly. The store will get full credit for it when they return it to the manufacturer so it is not that morally bad. The manufacturer should bare the burden because of the poor quality control that allowed your clipper to die in such a short period of time. Hope you find this solution helpful and the last option is a surefire fix...
George
Posted on Jul 25, 2008
  • 30 Answers
SOURCE: wahl magic clip clippers are very noisy , tried to adjust ?
1 or 2 basic things happened. 1st there is an armature adjustment on the right hand side when viewing the clipper from the top (it looks like a screw). Place a screw driver in this and turn it counter clockwise, if this screw is up against the stop than you can place a small screwdriver behind it and pop it out (this is actually a cap) now you can access the actual adjuster. back this out about an 1/8 of a turn at a time until the noise stops, turn them side to side to insure that the armature is far enough off of the motor coil. Then replace the cap.
Posted on Sep 21, 2009
rick_stokes_
  • 61 Answers
SOURCE: loud buzzing on Wahl "Designer" model clippers
There is a "power screw" located on the side of the clipper opposite the switch. This may need adjusting. Take a screw driver or coin....and with the unit running......turn the screw back and forth until the clipper stops making noise. The proper position for the most power is to turn the screw intil it makes a loud noise, then turn it back just enough to get rid of it.
Posted on Sep 27, 2009
SOURCE: WAHL model MC. Very loud (mechanical)
Should have a flat head screwdriver handy... on the side of the clipper there is a dial where you can insert the tip of the flat head.. Turn on the clippers and turn that knob with the screwdriver slowly till it hums nice and even..
Posted on Nov 17, 2010
My husbands clippers won't cut
Blades are NOT moving HOW TO Fix a broken Hair clipper ...
? 2:42
https://www.youtube.com/watch?v=DX4Xc47F_IE
Mar 29, 2015 - Uploaded by You can Fix It!!!!
... blade fix how to won't cut by adjusting the blade adjusting the play with the motor so ... Blades trimmer trim trimming cut cutting cutter trimmers barber ... dog clippers shear shears shearing shave shaver shaving buzz cut ...
My clippers hum like their working but dont cut - Fixya
www.fixya.com/.../t3222969-clippers_hum_like_working_but_dont_cut
Jul 25, 2008 - my clippers hum like their working but dont cut - Wahl Designer 6 (8355100) question. ... hair clippers repair. Apr 22, 2013 ' Shavers ยท 1 Answer ...Clippers jam and won't cut when trying to use attachments. Jan 11, 2009 ...
Clipper Maintenance - Rapid Edge
www.rapidedge.com.au/cat/maintclip.html
Clipper won't cut cleanly or easily. Lack of oil and dirty. Sometimes a hair gets caught between the blades. Lubricate and clean your Clippers regularly.
Dec 21, 2015 | Health & Beauty
Wahl clippers
The clipper was being held at too sharp of an angle
Oct 01, 2013 | Wahl Super Taper Hair Clipper 2000 Hair...
Wahl clippers
Have you read the instructions and put it together the right way?
Sep 29, 2013 | Wahl Home Grooming Animal Clipper Kit With...
How do I reduce my clipper's rattling noise and still be able to cut properly?
The power screw is the correct way to adjust the problem you describe. If you have attempted to adjust it as instructed in the user manual and have not had satisfactory results, there may be a problem with the clippers.
Most Wahl clippers have a 1 year or longer warranty. You can call Wahl for warranty service at 1-800-334-4627
Nov 12, 2011 | Health & Beauty
WAHL model MC. Very loud (mechanical) buzz when on. May be clipper blade out-of-adjustment (?) Do not have instruction manual on how to adjust.
Nov 15, 2010 | Wahl Health & Beauty
How to position the clipper blade while u sharpening?
Hi!
I'm not sure about the nature of you question. Firstly if you mean, position the comb (with the adjusting lever on your clipper because your blades wont work, then:)
1.
If you move the comb downwards using the lever on the side of your clipper you will get a shorter cut, if you move it forward you will get a slightly longer cut. If your clipper makes a horrible noise, I believe there is a plastic adjuster on the side that you adjust with a flat head screwdriver. This adjusts the springs inside the clipper which effects how central the cutter moves from side to side. Adjust this while the clipper is running. You want your blades to be as central as posssible. If they still do not work, you may need your blades sharpened. This costs £5.90 incl. VAT & Postage www.sheareaseltd.com You could send your clipper to them as well and ask them to re align your blades after sharpening and they'll just charge the extra postage. (extra £5)
Hope this helps!
2.
If you mean how to hold the clipper with the blade relative to what you are clipping. You need to hold the clipper so the teeth are not pointing into your project, but not pointing away from it either. Keep the comb parallel to your project. With human hair, cut against the grain, with an animal cut with the grain!
Hope This Helps!
Jun 18, 2010 | Wahl Magic Clip Clippers Hair Trimmer
The moving cutting edge keeps going diagonal to the bottom cutting guide- to the point where it overlaps and chews into skin! how do i fix this?
if this is a Wahl clipper Contact mannyssharpening@yahoo.com they are a Wahl Dealer they have all the parts for Wahl clippers.
Mar 15, 2010 | Wahl Super Taper Hair Clipper 2000 Hair...
Loud buzzing on Wahl "Designer" model clippers
Jul 03, 2009 | Wahl Designer 6 (8355100)
Wahl magic clip clippers are very noisy , tried to adjust ?
Jun 28, 2009 | Wahl Magic Clip Clippers Hair Trimmer
Wahl Designer 6 (8355100) Logo
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
