Question about Ovens
Shacklock wall oven
On Fan Bake the Fan stops
reg501
  • 413 Answers
SOURCE: wall oven will not bake
In many cases, even if the igniter is glowing, the resistance may not be low enough to turn on the gas valve. The igniter has probably gone bad. ($50.00 to $90.00 for igniter)
Posted on Jun 29, 2008
  • 491 Answers
SOURCE: Our wall oven will broil, but will not heat up to
IT SOUNDS LIKE THE HEATING ELEMENT HAS BURNT OUT AND THIS IS WHY YOUR OVEN DOSENT HEAT UP, I WOULD ALSO SUGGEST THE REASON YOUR FAN IS LOUD IS IT MAY BE OFF BALLANCE AND LOOSE AND AS ITS TURING IT BANGS ON THE FRAME , SO REPLACE THE ELEMENT AND FIX THE FAN .
Posted on Nov 09, 2009
  • 69 Answers
SOURCE: my f&p wall oven model number BI602 is not reaching temperature
Most likely you have a faulty fan element- this is a round element that goes around the fan at the back. To check- Disconnect from power(easiest way is to switch off oven at fuse board). Remove rear panel inside oven (held on by screws), and visually check element- often you will see a blow mark on the element. Element is easily changed, although sometimes requires oven to be removed to access element wires from the back. Proceed if you are a confident DIYer, otherwise call a local service agent. Elements are readily available for $75-$125 depending on the retailer.
Posted on Mar 09, 2010
tbreeze47
  • 3083 Answers
SOURCE: the oven setting for convection bake stops at 285
I would suspect the thermostat as being bad, but it could be a heat sensor also. Here is a blog that gives general troubleshooting of this problem, and perhaps it will help:
Here's an answer I found on the web from someone that had already changed the temperature sensor:
Gas oven? You need to remove the bottom panel inside the oven and watch the burner cycle. If it's real slow coming back on, this will let temp drop too far inside the oven, which may indicate a bad ignitor. Could be this, or a sensor, or the thermostat. Sometimes upper limit switches go bad. I tried to bring up diagrams of your oven, but could find any one the net. Here's some info on troubleshooting a gas range, and hope it helps: http://home.howstuffworks.com/how-to-repair-an-oven7.htm Good luck.
Posted on Nov 23, 2010
tbreeze47
  • 3083 Answers
SOURCE: classquie ch204 wall oven i
On the bake cycle, the top and bottom elements should heat up. On broil, only the top element will heat. I went online, but couldn't find a schematic on this unit- you will have to contact Classquie to possbily obtain one. From your description of the problem, it sounds like the bake element on the bottom of the unit is failing, and might need replacement, or possibly a control is failing.
I tried to google "classiquie" and came up with nothing, so that's allI can suggest.
Good luck, and hope this helps.
Posted on Mar 29, 2011
I have a double whirlpool fan oven. The fan doesn't always work, seems to stick. What do I need to do to get it working? We've had it less than 3 years but I've never cleaned it. Is this why it doesn't...
Do you mean the fan inside the oven box in the back wall. This is the fan for the Convection bake etc. If so this is how it works..
a) Bake feature - that fan does not come on
b) Convection bake - that fan comes on during bake cycle
So that fan works for several features but not for all. It helps to circulate the hot air inside better for a more even, fast bake.
Do you mean the fan in the control board area. It is there to get the hot air trapped in the oven walls out. Not the heat inside the oven bake box area. This fan works differently depending the model and/or brand. Some models fan works from the time you start. Some models fan comes on only when that area reaches a certain high temperature.
Mar 01, 2015 | Whirlpool Ovens
My Chef Classic Wall mounted fan forced oven stopped working. Its grill section working. Fan and the light in the oven working well. Bot oven doesnot heat up. Please give a tip what is probably wrong?
The bake element has gone bad. They can visually look fine but still be bad. To check and replace that element you will unfortunately need to kill the power and remove it from the wall. Remove the back cover. Check for a low resistance (around 16 ohms) across the bake element. If the resistance is high the element is bad. Google the make and model for a replacement element.
Dec 26, 2014 | Magic Chef Ovens
When trying to thermal/radiant bake, convection fan at the rear does not stop turning after the preheat. Why doesn't this happen? Isn't it then convection baking?
Most wall ovens have a cooling fan that comes on when the oven has been on for some time. It is separate from the convection operation. It should shut off after the oven has been off for a time.
Nov 12, 2013 | KitchenAid KEBS279BWH 27" Double Electric...
I have a Thermador Model C302U wall oven the fan on the uppper oven starts and then stops and I get the F34 code I am thinking to replace the motor but I want to know if there are other things I should...
When that fan starts up the air pushes against an air switch and that tells the board the fan is blowing. The stove uses a DAC system that relies on switchs to confirm the operations of the fan. the DAC control uses signal voltage to detect switch function. The air switches must physically close by air movement from the cooling blowers before the oven proceeds into a bake or broil mode. Reason being f the cooling motor does not function and the oven goes into a bake or broil mode, the oven will overheat and could damage the fancy smancy over engineered piece of garbage electronic components. My opinion. This is not for the DIY unless you are a TV repairman.
Nov 03, 2011 | Thermador C302U Electric Double Oven
Ge wall oven will not heat up on bake,boil or clean cycle
GE JKP86BF3BB COMBO MICRO/ELECT OVEN
NO HEAT ON BROIL OR BAKE ELEMENTS
CKD WIRING FROM PANEL OK
CKD TERMINALS AT ELEMENT HAVE 120V ON EACH ELMT
FAN COMES ON
THE ON INDICATOR SHOWS WHEN TMP &START PUSHED
MICROWAVE WORKS FINE
I ORDERED A NEW BAKE ELEMENT TO TRY-NOT HERE YET
STUMPED
Mar 16, 2009 | GE JTP15 Electric Single Oven
Cadco XAF 115 fan not working
make sure you have selected convect bake, otherwise remove oven from wall to acces the back and test voltage at the fan, most likely the fan is bad, if you use conv. bake alot
Mar 29, 2008 | Ovens
Oven temperature fisher paykel
benypeny what that flash was from what I have seen over the years is your heating element on the back wall burning out. Remove the cover and you will see the element is no longer in 1 piece.
Feb 03, 2008 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
