Question about Refrigerators
I have a frigidaire side by side model mrs22wnew the fan inside is squeling in the freezer how dow i get to it thanks
2 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: The refrigerator side is warm
is there a heavy frost build up on the back wall of the freezer?? is the fan in the freezer working??
Posted on Feb 17, 2008
Model FRS23R4A - loud humming noise coming from inside freezer section at top behind the ice maker. What might this be?
Somebody hiding in your freezer? Na, I'm just kiddin! Sounds like an evap fan going bad on ya. Eventually you will need to replace the fan!
Thanks and please rate me!
Tips Provided by: www.HoustonRefrigeratorRepair.com Brian Gillespie (GOFAR Services, LLC)
Aug 26, 2011 | Frigidaire FRS23R4A Side by Side...
Frigidaire side by side freezer - LOUD noise...
It sounds like the evaporator fan is hitting ice that is built up on the evaporator coil. When it's making the noise, open the freezer door and see if it stops.
(Most models are wired so that the evaporator fan cuts off when the freezer door is open.)
Check the inside back, lower panel of the freezer for ice built up or frost on it. If there is, you have a defrost problem that is most likley a bad heater. It's located around the coil inside the freezer behind the panel you will be looking at. The defrost problem would explain the freezer not freezing ice cream.
Nov 12, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidair side by side refigerator fan not operating
I do see the power to the evaporator fan section going through the adaptive defrost part number 240554502 It would not hurt to unplug for a few moments and open the control panel inside the fresh food section and examine that control board. With it doing that you may see signs of heat or burn marks on the ADC Let me know, Sea Breeze
Jul 21, 2009 | Frigidaire Refrigerators
Frigidaire refrigerator not working colling
Can you tell me a little more like sounds of fans or compressor sounds. Lights on inside. When you open freezer is fan running? I will give you a try on fixing this. Let me know also if the model number above your post is the model of your refrigerator. Let me know if I can help you, Thanks, Sea Breeze
Jun 18, 2009 | Frigidaire FRS26R4A Side by Side...
Refrigerator and freezer not cooling. We checked out the door, and that seems to be fine. There is some ice build up on the bottom of freezer and on back panel. Model # is FRS26ZSH Thanks.
sonds like a either a defrost issue,( not self defrosting), or your evaporator fan motor is not turning,can you here hte fan turning inside the freezer compartment???
Nov 24, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Nov 08, 2008 | Frigidaire FRS26H5AS Side by Side...
Fan continuously running, non-stop
hi thanks for the question its normal for a frost free freezer to run a long time to keep a good cold temp i don't think you have a problem thanks the appliance doc
Sep 08, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Frigidaire does not work (freezer and cool area)
what can u hear. u should hear fan in freezer. fan in back. is compressor running. is ice in freezer on back wall. are both sides not cooling. post more info to go by
Jul 02, 2008 | Frigidaire FRS26RLECS Side by Side...
Feb 17, 2008 | Frigidaire FRS26ZSG
Refrigerators Logo
14 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
