Question about Garden
Toro troubleshooting runs then stalls
I have a toro timecutter z5000, after disengaging the drive in order to hand push the mower it doesn't go back into drive mode. what can the problem be?
Posted on May 27, 2014
I have a toro zeroturn mower motor starts up fine I can drive it around fine, but as soon as I engage the mower deck the motor will start running rough then stall out. why?
Could be there is an obstruction in the deck that is not allowing the blades to turn freely and stalling out the motor.
Sep 13, 2017 | Toro Garden
I can not keep my weedeater running?
Mark, Ensure plug is good, remove,inspect replace in tn tank fuel filter if clogged, remove muffler and clean screen in side, carb., carb. could be dirty or out of adjustment or diaphragms worn out and needs rebuilding. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
http://support.mtdproducts.com/app/answers/detail/a_id/10666/~/basic-troubleshooting---handheld-string-trimmers-(gasoline-powered)
Toro String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Jun 11, 2016 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
My toro lx 420 wants to stall when engaging the blade sometimes..also when I push on the reverse, it acts like to wants to stall as well...any easy troubleshooting ideas? runs fine when not engaged
Try rolling when you engage instead of in the still position may be too much on the motor, either that the belt is loose or needs to be replace. Or u need a carb adjustment at the idle.
May 02, 2016 | Toro Riding Mower LX Series 22 HP Kohler...
Toro lawn mower troubleshooting
A dirty air filter is a common cause of this. Give it a look. Otherwise a replacement carb would be the route to take.
Aug 21, 2014 | Toro 20371 - 22In OHV Recycler High Wheel...
My toro snowblower keeps stalling. It starts up fine, but won't run continuously.
If you haven't already, dump out gas and put fresh in it and try this, if it doesn't work you will have to clean the carb, take it apart and clean all jets ports etc and put back together and you should be Good to Blow Snow, pretty common problem with Small Engines that set half the season.
Dec 04, 2011 | Garden
I have a toro commercial self propelled, engine stops when I engage the self propelled. I t runs until then. What can I do to solve this problem?
Regularly check the wheel-drive belt on a self-propelled mower for wear and tightness .... "Affected engines may run rough, stall or bog down under load,"
Jul 22, 2009 | Toro Lawn Mower With Toro Power Tools
Lawn mowewr wont restart
Check the gas cap. Loosen it a bit and try again. There is a vent built into it the hole on top plugs up ans stops the fuel flow.
Eric
Jun 24, 2009 | Toro Lawn Mower With Toro Power Tools
Can't start toro mower. cleaned spark plug , new air filter . will run for 2 or 3 seconds on prime , then stalls ,will fire every time , but won't continue to run what next? 22" self propelled...
Hello:
There are 2 Possible Causes for this Problem.
1- The Carburetor Requires Soaking and Cleaning.
2- The Valve Clearances Require Setting.
You can View a Breakdown of this Unit at the Following Site Addy.
https://lookup3.toro.com/partdex/default.cfm
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
1,327 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
