Question about Sony - VGN-FS675P/H VAIO PC Notebook
Won't turn on after being in docking station
Laptop was in docking station and suddenly shut down during use. Removed from docking station and can't turn it on. Removed the battery and tried with power supply, won't turn on. Checked the latches on the lid, they seem to be working so it doesn't think the lid is closed. It is just dead. ANy help Thanks Siggi
  • 1 more comment
  • Sigmeister May 21, 2009
    No sounds heard, no fan noise , I did not hear the cd running either. Just plain dead. No thunderstorms at the time either.
  • Frank Zhang
    Frank Zhang May 11, 2010
    could you see the charging lights on when plug in AC adapter? (battery installed)
  • Frank Zhang
    could you feel or hear any spin inside laptop? such HDD CDROM or CPU fan spin?
How can i update dell dock?
A docking station is an extension or addition of ports for a laptop computer. Once the portable computer is docked, you can access the docking station's ports, such as PS/2 or USB 2.0 ports, through your computer. Some docking stations have monitors that you can connect your computer to, placing your video on an external screen so you can turn off your computer's monitor and conserve some of your computer's energy. All Dell docking stations will have the same general troubleshooting steps.
Plug your laptop's power adapter into the docking station and dock your laptop onto/into the docking station. If there is no power going to your laptop from the docking station but it works when the power adapter is plugged into the wall, the docking station is bad and needs to be replaced. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power goes on but your computer doesn't recognizes accessories such as a USB mouse--plugged into the docking station, try a different port on the station. If it works in a different port, the previous USB port is burned out. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized, you might have a corrupted docking profile. Undock the computer and dock it again once it has fully started up to reset the docking profile. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If you have an external monitor and it is not working, completely close the lid on the laptop so the image will move to the external monitor. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized and resetting the docking profile fails, update all drivers through Dell's support website and then re-dock the computer. Some of the software that runs the hardware may have become corrupted. Hope this helps
b>
Jan 16, 2013 | Dell Inspiron 1545 Notebook
The D800 says it is docked or running on battery, push F1 to shut down. This happens at power on and with AC power adapter being used. Have tried other power adapter(90 watt) and no docking station being...
There's a "slide-away" coverv on the bottom of the laptop, where the docking-station's adapter would connect. Manually slide the cover, and inspect to ensure that there's nothing stuck there that is "tricking" the laptop into claiming that it is docked.
Apr 16, 2010 | Dell Latitude D800 Notebook
Dell Latitude 630 docking station USB ports no longer work
Try removing the laptop, unlug the power to the dock and wait a few minutes, then connect the power now put your laptop back on the dock.
I hope this helps.
Have a good day and good luck.
Nov 20, 2009 | Computers & Internet
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
Nov 07, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
When I install the driver and the computer restarts I get a blue screen that tells me a fatal error has occured and windows will not start normally. The only way to get past this screen is to restart in...
When you install the drivers, are you installing them while the laptop is conected to the docking station? If so, try installing with docking first. Then after installation, shut down your computer. Dock the comptuer, then start the computer back up. If you get a blue screen, go into your bios and make sure that your USB setting is set to High Speed.
Please make sure that the docking station is plugged into your notebook before booting up, there is an issue that all expresscard docks share with plugging the docking station in while the notebook is powered on.
If there is a switch located on the Expresscard
On-Pre-boot support
Off-Post-boot support (Default)
This switch is used to determine how the dock is recognized in the
system at boot up stage. Certain notebooks will detect the dock and not
work properly during a pre-boot mode (ie. trying to boot up on the
external VGA device, not the internal VGA of the Notebook). This was
observed in notebooks (Fujitsu, some Sony and Toshiba models) that
use a BIOS developed by Phoenix Technologies. If you experience
such issue, please turn the switch from the default "OFF" position to
"ON". You will only need to set it once.
Jul 23, 2009 | Targus ACP50US Docking Station
Shut down not complete from dock station
the z sometimes means sleep mode which ur laptop is still running but ur harddrive is not in motion as much as it is awake
Jul 19, 2009 | Lenovo ThinkPad T61 Notebook
No internet when docked.. needs network controller
Assume the docking station is powered. I have seen funny behaviour with my docking station. Sure way for it all to work is, everything off, fit to docking station, turn on with power button on docking station. Ensure network cable plugged before this.
Sep 16, 2008 | Dell Latitude D600 Notebook
USB ports in docking station stopped working suddenly
I was having the same problem - the USB ports seemed to have stopped working so I could not use the mouse, keyboard, or printer, even though the monitors and power could still operate through the docking station. Finally, I just unplugged the docking station for 30 seconds, plugged it back in, and everything resumed working. I was surprised it was that simple, but it's working for the moment.
Aug 27, 2008 | IBM (250410U) Docking Station for ThinkPad
Sony - VGN-FS675P/H VAIO PC Notebook Logo
144 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
