Question about Philips Televison & Video
My Phillips TV is stuck on teletext holiday channel
My sony tv keeps dropping out of teletext back to the tv program
the web began to take over some of the functions of teletext from the late 1990s, and many broadcasters have ceased broadcast of teletext-CNN in 2006 and the BBC in 2012. The decline of teletext has been hastened by the introduction of digital television, though an aspect of teletext continues in closed caption .
May 22, 2015 | Sony Bravia KDL-32V4000 32 in. LCD TV
I can not get teletext on my tv lg flat
you should press the home button of your teletext page usually its 100
or you could press one of the four colored buttons o your remote control unit so it will reset to the home page of the teletext
(a black page mostly says that teletext isn't available to the specific channel )
Aug 08, 2014 | LG 32LG30 32 in. LCD HDTV
Phillips 40PFL3505D 42 inch tv stuck in channel search mode , continuous cycle
You can try to go back to factory settings.
After that disconnect the power from the TV and wait for about an or two hours. Then put on the power and try to make the installation complete from the start.
Regards GJ
May 25, 2014 | Philips 42PFL5332D 42 in. LCD Television
We just bought a Sanyo LED tv and channel ten is not found when auto tune is done someone please help!! :)
Test the signal strength using analogue tv mode and teletext page 284. If this shows no issue open up the TV tuning menu and use 'Manual Tume' until the missing channel shows on the screen and then Save.
Apr 03, 2012 | Sanyo Televison & Video
Samsung Exit TTX mode
Had to reset the TV and re-tune all channels. But it worked.
Feb 02, 2010 | Samsung DynaFlat TX-P3064W 30" TV
I am trying to install a phillips apapter RF modular to a televison. I have no idea whether to hook it up to the cable box or the TV. To be honest am not sure where the input cords go. Phillips SWS2326W/17
Hi and welcome to FixYa,
Initially, the video (yellow) and audio (red & white) OUTPUTs of the cable box should go to the Video/Audio INPUTs of the RF Modulator. Thereafter, the TV should be set to Channel 3 (or whatever it is the RF Mod is using). This is done if and only if the TV has no A/V INPUTs and/or the cable box has no RF OUTPUT.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 14, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Samsung LE32R74BDX LCD TV Analogue Teletext
DEAR Customer,
it can changable,
read out your manual topic named channels settings tou got this problem soplved already solved there.
THNX
May 18, 2008 | Televison & Video
Proscan model 52690
You can get the Phillips universal remote that will work that tv at the following link with free shipping. The phillips universal is one of the best remotes for a universal and easiest to program also
http://servicemanuals.vstore.ca/
Apr 13, 2008 | Proscan PS52690 52" Rear Projection...
Televison & Video Logo
12 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
