Question about Radio Shack RadioShack Professional Weather Station
Temperature problem I just charged out the batteries on all sensors. Now my base station only gives the temperature in Celsius. How do I get it to read in Ferenhite?
My Smart Gear STG-6007-BB weather station won't pick up the outdoor temperature from the remote sensor. I changed the batteries and reset the unit, but it still doesn't work. Any suggestions?
  • Remove all batteries
  • Install batteries in remote sensor. Allow time for it to begin sending temperature information
  • Install batteries in indoor unit. You should see temperature displayed
Cold weather can cause loss of temperature information
Dec 17, 2016 | Measuring Tools & Sensors
I have a new weathr station and can not get the outside temp. to display what can I do?
I assume it is a wireless station. If so, there is a procedure to go through to get the temperature sender and the base station to sync up and work. You need to check your owners manual to get the exact procedure for your unit. On my station, I have to remove the battery from the base station, let it power up and within 5 minutes, install the battery in the remote station(s) (temperature, rain gauge, wind gauge, etc.). Also, you must keep the remote station within a certain range for the base to get a good signal. Probably 25 feet, but the owners manual will have the right number. Also, use new batteries.
Aug 02, 2016 | Oregon Scientific WMR86 - Backyard Pro...
Why cools the ac only 1 hour full power and never reaches the set-point temperature ?
check that all the doors and windows are closed as ac units do not work well when trying to cool the world
is the ac unit too small for the room size
I suspect that because it is working the problem is outside the ac control
is the inside fan working and blowing out cold air
May 22, 2016 | Heating & Cooling
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
Jan 07, 2016 | Measuring Tools & Sensors
Replaced batteries, outsid temp. does not display
Jan 05, 2016 | Taylor Measuring Tools & Sensors
Why does outdoor temperature display only show = signs?
The outdoor sensor probably uses solar energy to charge a battery that powers the wireless transmitter. The battery may be defective or the charging circuit may have failed. The instructions that came with the station could provide some troubleshooting tips.
Nov 03, 2015 | Weather Channel WS-8500TWC-IT Wireless...
Will not display outside temperature even though I changed the battery on both the inside and outside unit
Find reset pin hole on base unit. Push in with a paper clip. Pin hole may be in battery compartment.
Mar 13, 2015 | La Crosse Technology TX37U-IT 915MHz...
Model no 217s31 does not display outdoor temperature reading.
As much as it sucks to do, you have to reset the base and the temperature sensor. When you do it, keep the temp sensor next to the base until the base recognizes it.
Mar 11, 2013 | Oregon Scientific BAR386 Wireless Weather...
Auriol 4-LD3091 weather station will not pick up sensor
I had the same problem and gave up on the unit for a while, then I had another attempt and found this worked for me. Take the batteries out of both units (receiver and outside sender) then reinsert the batteries BUT put the batteries into the outside sender unit FIRST, this seems to make the difference as when you then put the batteries into the indoor base-station it detects the outside temperature signal immediately as it starts to set itself up .
Aug 18, 2012 | Measuring Tools & Sensors
Radio Shack RadioShack Professional Weather Station Logo
99 people viewed this question
Top Radio Shack Measuring Tools & Sensors Experts
 steve
steve
Are you a Radio Shack Measuring Tool and Sensor Expert? Answer questions, earn points and help others
