Question about Facebook Social Network
Delete entry remove all info related to me
How do I uninstall deal4me
Removing deal4me is not an easy job, for you have to find out and delete all its related files from your computer. The following post shows you the detailed steps to remove this adware from your PC.
Remove Ads by Deal4Me Deal4Me Adware Removal Guide
Sep 04, 2014 | Cars & Trucks
Viber downloads cant be delated
it needs to be uninstalled, not deleted.
By deleting you leave loads of entries in the registry and that is where it will look for previous versions.
However now that you have done this. If the uninstaller no longer functions in control panel, delete everything from program files that relates to viber.
Then open your registry (using regedit), take a back up of it (in case you delete something you shouldnt) using file/export.
Then using Find, find all keys and entries relating to viber, and delete the whole lot.
Then restart your machine to make sure you havent deleted anything important by mistake.
Assuming thats all ok, load you new version and it will be fine
Mar 18, 2014 | Microsoft Windows XP Home Refurbisher...
How to Uninstall and Remove AVG Free Edition Completely?
I've setup a step-by-step AVG Free Edition removal plan for you so you can conduct the removal as soon as possible.
Uninstall and remove AVG Free Edition manually
* Locate and remove AVG Free Edition by deleting the related files, a trained software professional would better do this job.
* Eliminate the registry entries if you can.
* Delete connected directions.
By doing a quick search via the Internet, you can find out what files and registry entries need to be deleted. But this removal is only recommended for computer experts, for deleting the wrong file or registry key may render Windows unbootable.
Oct 13, 2011 | Harman Kardon SoundSticks II Computer...
Lenovo cannot detect DVD ROM, Error code 19 reported. Related to drvier. Tried to update driver but found out driver that is already installed is the latest. Did not find any driver in Lenovo's web....
Microsoft Windows Vista loadTOCNode(2, 'resolution');
  1. Click Start Collapse this imageExpand this imagevistastartbutton.jpg, and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK. Collapse this imageExpand this imagesecurityshield.jpgIf you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  4. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  5. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
  6. On the Edit menu, click Delete.
  7. When you are prompted to confirm the deletion, click Yes.
  8. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  9. On the Edit menu, click Delete.
  10. When you are prompted to confirm the deletion, click Yes.
  11. Exit Registry Editor.
  12. Restart the computer.
Now go to the "Did this fix the problem?" section. uparrow.gifBack to the top Microsoft Windows XP loadTOCNode(2, 'resolution');
  1. Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
  5. On the Edit menu, click Delete.
  6. When you are prompted to confirm the deletion, click Yes.
  7. In the right pane, click LowerFilters.
  8. On the Edit menu, click Delete.
  9. When you are prompted to confirm the deletion, click Yes.
  10. Exit Registry Editor.
  11. Restart the computer.
Nov 06, 2009 | Lenovo ThinkPad SL400 Notebook
I have 5.8 vtech phone. A set of 3. I would like
Delete a Number/Name Stored in the Directory
1. Press . The screen displays DIRECTORY.
2. Press or to scroll alphabetically through entries stored in directory.
— OR —
Press the dial pad key for the first letter of the entry you want to delete.
3. When the screen displays the entry you want to delete, press select . Then press or until
ERASE flashes.
4. Press select . The screen displays ERASE NO YES and the number. The current choice
flashes.
5. Press until YES flashes.
Sep 07, 2009 | Lands Phones
Windows cannot find file csrcs.exe
File csrcs.exe is located in the folder C:\Windows\System32.
Program has no file description. The file is not a Windows system file. The application is loaded during the Windows boot process.
The program is not visible. It is an unknown file in the Windows folder. Program listens for or sends data on open ports to LAN or Internet. csrcs.exe is able to monitor applications, hide itself, record inputs, manipulate other programs. Therefore the technical security rating is 86% dangerous.
It simply means, "It is very dangerous"
Try these steps to remove it.
Click on START-RUN,
type regedit (it will open the registry editor)
Press Ctrl+F
type "csrcs" (without quotes) and click on Search It'll show you some results, where you'll find "csrcs.exe" delete it immediately.
Again do the same search you may see "explorer.exe csrcs.exe" , right click then modify and remove the csrcs.exe part (leave the explorer.exe as it is)
Hurray !!! you have removed csrcs.exe
Restart your system and see it for yourself
Don't forget to give feedback
Sep 05, 2009 | Computers & Internet
My Acer Asprire 5100-5674 no longer recognizes the cd/dvd drive.
hi, cd drives do wear out or just break, most time it is software related. but they can just stop working.hope this helps. good luck
Feb 26, 2009 | Acer Aspire 5100 Notebook
I canĀ“t star my dvd rom say the code 19
Does the drive even show up in My Computer? If not use this:
Step 1: Start Registry Editor loadTOCNode(3, 'whattotry'); Start Registry Editor. Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'whattotry');
  1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
  2. Expand SYSTEM, and then expand CurrentControlSet.
  3. Expand Control, and then expand Class.
  4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
  5. In the details pane of Registry Editor, on the right side, click UpperFilters.
    • If you see the UpperFilters registry entry in the details pane of Registry Editor, go to step 6.
    • If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to "Step 3: Delete the LowerFilters registry entry."
  7. Click Yes when you receive the following message: Are you sure you want to delete this value?
The UpperFilters registry entry is removed. Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'whattotry');
  1. In the details pane of Registry Editor, on the right side, click LowerFilters.
    Note You might see a LowerFilters.bak registry entry. You do not have to remove that entry. Click LowerFilters only.
    If you do not see the LowerFilters registry entry, unfortunately this content is unable to help you any more. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  2. On the Edit menu, click Delete.
  3. Click Yes when you receive the following message: Are you sure you want to delete this value?The LowerFilters registry entry is removed.
  4. Exit Registry Editor.
Step 4: Restart your computer
Jan 27, 2009 | Computers & Internet
Plugin.dll
This is the obsolete entry of a deleted of corrupted software (somthing myweb....) to remove this you must look for this entry on several places.
1. try to find this software in your Add/remove programs list and uninstall it.
2. Go to Start-> All Programs-> Startup and if you find it any entry related to this one then delete it.
3. Go to Start-> Run... and type "Msconfig" (without quotes) and press enter. in the newly open window go to startup tab and un-tick all entries related to this software and apply the changed. you may also go to Services Tab on the same window and tick the box "Hide All the Microsoft services" then try to find this software entry in the remaining list and if you find one then un-tick it and apply the changes and restart your PC.
If the problem still persist then
4. Go to Start-> Run... and type "Regedit" (without quotes) and press enter. it will open your windows registry. Now press Ctrl+F and try to find this entry in the windows registry and delete all entry related to this software. it will surely solve your problem.
Oct 06, 2008 | Computers & Internet
Error 39, corrupt DVD/CD-Rom Drive
Dear NICK,
its a windows registry related problem, you can fix it through :
This method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base: 322756 (http://support.microsoft.com/kb/322756/) How to back up and restore the registry in WindowsLog on to Windows by using an account that has administrator rights and permissions. Then, follow these steps. Step 1: Start Registry Editor loadTOCNode(3, 'resolution');Click Start, click Run, type regedit, and then click OK. Registry Editor starts. Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry:Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step. Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry:Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor. Step 4: Restart the computer loadTOCNode(3, 'resolution');If a CD recording program no longer works after you restart the computer, you must reinstall the CD recording program.
Mar 24, 2008 | HP Pavilion dv6000z Notebook
Facebook Social Network Logo
29 people viewed this question
Top Facebook Computers & Internet Experts
David Payne
David Payne
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
