Question about Shure Beta 87A Professional Microphone
Mic works fine until warms up about 15 min then volume goes way way down
First 5 min. works fine but then loses volume anad not clear
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
Contact Shure for repairs. www.shure.com/service
Posted on Jul 27, 2014
LCD TV - INTERMITANT BLUE SCREEN
Fault in the main board. You have to replace the main board. As it's have SMD components is would be difficult to repair.
If you wish to get some more details then check the following link.
http://electro-medical.blogspot.com/
Jul 13, 2016 | LG 37LC7D 37 in. LCD HDTV
What causes the TV to go on and off when first turned on, until it warms up for 5 to 10 minutes
Try turning the volume all the way down then power the TV an see how
long it takes to bring a screen up if you still hear a popping sound then you have a bad part with a bad connection most likey a lamp and wiring.
Call to have it serviced a must if so.
Jun 08, 2012 | Mitsubishi LT-3280 32 in. LCD HDTV
After playing for a while, approx 15 min, the volume dies away leaving some sound but greatly reduced. It then gradually returns to normal volume after about 3 mins. Otherwise all other functions seem to...
Such a long delay and a slow return to volume is puzzling. If the return came back in say 30 seconds, I would suspect 1/2 of the V1 tube (12AX7) might have a failure of the heater. When it has failed see if this tube has TWO points of light in it. The cooling down and warm up would give a 15 second ramp up or down in volume. This tube has a path around it that would sustain a very low volume. Try swapping one of the other 12AX7's into this spot. If the sound totally goes away replace the one that was in V1 at first place and see if problem goes away.
Mar 29, 2011 | Peavey Delta Blues 115 30w All Tube Combo...
We are watching tv and the volume just turns itself all the way up. If we turn it down, it goes right back up. It stays like that for about 15 min at a time and then it will allow me to turn it down until...
check the remote control, take the batteries out and try to adjust the volume on the tv set itself.
If this resolves the problem the button on the remote may be sticking, either clear it or get a universal remote.
If you still have the problem without the remote then its time to take the tv to a repair shop or claim on a warranty.
Mar 15, 2011 | Televison & Video
Hi I have Prima lv 3228p tv and there is no volume it was working fine yesterday andtoday no volume
prima lv-3228p lcd tv-after 15 mins of play the screen goes funny and there is still volume but the remote will not function. you cannot even shut the unit off, only by disconnecting the power supply. If you wait 15 -20 mins and plug the unit back in it will work for approx 15 mins again- then it will start acting up again?/
Jan 13, 2011 | Televison & Video
I lose the picture after 20 - 25 mins. I turn off the TV and turn it quickly back on and the picture works fine; then 10 - 15 mins goes by and I lose the picture again. I turn the TV off then quickly back...
it probablt needs power supply capacitors, if you can take it apart and inspect the power supply, the bad capacitors usually are expanded and have a bulge at the top, you would need to solder these parts in, so some skill is required.
Sep 07, 2009 | Polaroid FLM-4201 42 in. LCD Television
Power goes off
Try resetting the unit.
Make sure there is no disc in the unit. With the unit on, go to the front panel and look for the STOP (square) button.
Hold it down until the unit shuts off by itself. Turn it back on it shoudl work fine.
Jul 01, 2009 | Samsung HT-X40 System
Briggs and Stratton dies after 15 mins
sounds like the head bolts maybe lose just check that first
Dec 26, 2008 | Garden
Saab 2.2tid car loses all power when warm, rev counter goes to zero
Check fuel feed is ok and fuel pump pressure also check cold start injector could be running on this til warm.
Sep 16, 2008 | 1999 Saab 9-5
Vr-309 starts to clip after 10-15 min
This is a case of one or more transistors breaking down when heated. This can be found usually by using freeze spray to cool down one transistor at a time until the problem clears up. You can narrow this down a bit by determining whether this "noise" is effecgted by the volume control or not. Also, does the problem show up faster when the unit plays louder?
Dan
Aug 29, 2008 | Kenwood VR-309
Shure Beta 87A Professional Microphone Logo
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
