Question about Audiovox FPE3205 32 in. HD-Ready LCD Television
Auto tuning not working - Audiovox FPE3205 32 in. HD-Ready LCD Television
How do I reconfigure an LG 32LY560H from Commercial setup to auto tune for use in personal residence?
possible that you need to have cable to do this, you might only have 6 digital channels, without cable
Mar 01, 2015 | LG Televison & Video
CANT TUNE IN
You must connect an Antenna to use the AutoTune. A set of rabit-ears is sufficient for most areas: RE: the Digital (Free) TV singals are using the old UHF/VHF frequencies - so any antenna designed for Broadcast TV should work. Connect your antenna to the ANT/Cable connection then re-run the Auto-Tune again.
Jan 10, 2015 | Televison & Video
I lost a few digital channels on an old LG LCD, tried to auto tune but could not retrieve. Followed a tip online that said to auto tune with the antenna cable which will wipe all saved channels, once...
hi your signal could be to strong, on the aerial cable the thin brad rap 4 strands around the center solid pin then retune in auto, if this does not work you may to manual tune it in, or get someone to check your aerial and you could try a firmware update on your tv hope it helps
regards
shaun
Jun 29, 2014 | Televison & Video
My Tv says Not Programmed
Your indoor antenna will plug into the same RF Antenna input jack as would an outdoor antenna. It will take some time but let the unit go through its entire auto tuning mode. If stations are available in your area and signals strong auto tuning will pick them up.
Mar 05, 2014 | LG Televison & Video
AUTO TUNING WONT RUN
Check and replace its main system control memory IC. If this IC is faulty, auto tuning will not work, or, the TV will store any received channels. If the TV do not tune into channels too, the AGC voltage to its tuner, and tuner itself should be checked.
May 27, 2013 | TCL L32D20
How do i get my toshiba regza lcd tv to work via the antenna/cable input
Change video source by pressing Input button and select TV, make sure antenna is connected in RF In jack in tv then go to Tuning menu and select Auto Tuning/ Auto Scan option, tv will tune and store all available channels in memory.
Let me know model number of tv if you have additional question.
Thanks.
Jan 08, 2011 | Toshiba Televison & Video
Tuning a sony trinitron tv
Most of the sony TV's comes with an auto tuning facility and all your need is ensure that the RF inout/cable TV or antennae is plugged into before the auto tuning is activated.
The auto tuning is available inthe older models on the set and in the newer models on the remote control. Choose program menu , tuning, auto mode.
Also you can search inthe manual mode individually and preset the channels position to your convenience such as news channels together, movies together etc.
Sep 21, 2010 | Televison & Video
How do I retune my TV.
Ensure you have a working aerial connected to the back of your TV.
With you Tv remote press the tv button, then MENU go down to setup and then to auto tune. Once this has auto tuned. then press your DTV (freeview) on the remote then press the MENU button then go to setup and then auto tune. This will do the same as before but with your built in freeview.
Hope this helps you out
Little Dish Fitter
Sep 28, 2009 | LG 42LG50 42 in. LCD HDTV
Auto-Tune
It is a plug in, it will be in your plugin list as long as the plugin type is compatable with your DAW. ( ie. RTAS, VST, AU ect).
May 16, 2008 | Microsoft LifeCam VX-1000 Webcam
Audiovox FPE3205 32 in. HD-Ready LCD Television Logo
14 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
romy sibug
romy sibug
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
