Question about Exercise & Fitness
Have a Vision Fitness T9250 and new today motor not working and getting E9 error message
3 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: I turned on my treadmill after a long hiatus :)
E4: Solution 1. Check power to the treadmill, as insufficient voltage to the treadmill can cause this error to reoccur. Check the power socket that the tread is plugged into. Eliminate any extension cords or surge protectors (plug the tread directly into a functional power source). Make sure the circuit is not overloaded. Make sure the circuit is NON-GFI. 2. Calibrate (See engineering mode for specific treadmill). 3. If calibrations do not hold, replace upper console. Note: Usually simultaneous with an E6. E6: Solution 1. Check the elevation plug connection at the lower board. 2. Check ALL large data cable connection at the lower and upper boards. 3. Calibrate (See engineering mode for specific treadmill) 4. Test/change large data cable (use large data cable information provided in the data cable portion of this Guide). 5. Replace elevation motor E7/E9: Solution 1. Certain lower boards have an LED that flashes when the magnet on the roller passes the sensor. Adjust sensor position if LED does not flash. See lower board basic troubleshooting for lower boards with the LED. 2. Unplug RPM sensor at the lower board. Check continuity. Treadmill will operate without sensor but cannot Autocalibrate. Calibrate manually. 3. Replace RPM sensor TREADMILL.TROUBLESHOOTING. AUTO CALIBRATION STEP 1 ENTER ENGINEERING MODE • With the SAFETY KEY in place, hold the “ELEVATION UP” and “SPEED DOWN” buttons for 5 seconds. “DGA3” will appear in the profile window and “EHG1” will appear in the function window. • You are now in ENGINEERING MODE STEP 2 ENTER AUTO CALIBRATIONS • Press the “ELEVATION UP” or “SPEED UP” to “EHG4”. • Press “SELECT”. STEP 3 • Press “START”. The treadmill will calibrate itself. This will take about 3 to 5 minutes. When AUTO is complete, “END” will appear in the window. Wait 10 to 15 seconds and the treadmill will reset itself to “P1”. STEP 4 • Press “START” to test the treadmill
Posted on May 06, 2010
ercupa190
  • 12223 Answers
SOURCE: I have a vision fitness treadmill T9250 and now the console display isn't working properly. Some of the
Dear Sir:
Please see the diagram attached from REED switch, adjust, clean, and tight the connector wires very well.
2) change the batteries by new ones, use the best.clean the contact batteries.
3) tight the ribbon cable from keypad .+ tight the connector from display board vs lower board.
4) after you fix it RUN THE sofware calibration for diagnose, troubleshooting, See my personal tips for help
sincerely. God bless you
Posted on May 03, 2012
My belt has stopped working, but all other functions are fine. I've removed the motor cover, but now what should I look for?
Try to check the carbon brush of the motor. If it's OK then the motor control board would be faculty
If you wish to get some more details about treadmill repair then check the following link
http://electro-medical.blogspot.com/
Aug 20, 2016 | Vision Fitness T9250 Treadmill
How to fix error E9 on vision fitness T 9200 treadmill
If you wish to get some details; check the site linked here. Pull up older posts treadmill . Surf the site with patience.
Jan 10, 2016 | Vision Fitness T9200 Treadmill
Doesn't move. What does error E9 indicate?
If you wish to get some details; check the site linked here. Pull up older posts For treadmill error code . Surf the site with patience.
My Vision Fitness T9250 treadmill. Can hear a low noise when no one is on it but gets much louder when anyone is on it and operating...any ideas where to start looking for repairs?
Try to open and separate the motor carefully from treadmill chasis, turn the motor shaft with hand if it not easily turn or you hear a unsual sound try to open the motor and add a lubricant to motor bearing, and turn the motor on if its still noise replace all the bearings with new one
Dec 14, 2014 | Vision Fitness T9250 Simple Folding...
E4 coming up on my screen display , what is this and how do I fix it so it will work again ....
What device are you talking about your stereo ATV a computer or a cell phone?
Most manufacturers have a support site on the Internet and given the error code and the model number they'll give you a solution
Nov 25, 2014 | Vision Fitness T9250 Deluxe Folding...
Getting E2 error on my vision fitness t9250 treadmill
68a1477a-4453-48c8-9f94-cd15c6c6fea7.giffollow this steps and fix it. God bless you
This is probably a faulty speed sensor or the speed sensor is not plugged in properly. Its also possibly a faulty motor control board or lower board. The error codes will differ between makes and models but could be e1.
See the diagram attached.
Oct 13, 2013 | Exercise & Fitness
ERROR CODE E9 VISION FITNESS TREADMILL T9200
If you wish to get some details; check the site linked here. Pull up older posts treadmill . http://electro-medical.blogspot.com/ Surf the site with patience.
May 08, 2012 | Vision Fitness T9200 Premier Treadmill
Dear Sir:
Apr 30, 2012 | Vision Fitness T9250 Deluxe Folding...
Hi i have a vision fitness 9450 hrt and i'm getting an error message: E6
Typically an E6 error message indicates that the machine needs to be recalibrated because the elevation motor is out of range or that you have a loose cable connection. Below are the auto calibration instructions. Please make sure that no one is on the machine because it will speed up quickly.
With the safety key in place, hold "ELEVATION UP" and "SPEED
DOWN" buttons for 5 seconds. Software version will appear in display
window for a few seconds before model displays.
Press "STOP" , "ENG1" will appear in display window.
STEP 2 AUTO-CALIBRATE
Press "ELEVATION UP" until "ENG4" is displayed.
Press "SELECT" , display will read "AUTO".
Press "START". Unit will calibrate, when finished "END" appears in
display window, then "ENG1".
STEP 3 EXIT ENGINEERING
Press and hold "STOP" to exit engineering mode
I would also suggest that, with the power to the machine off, you check all of the wire connections underneath the motor cover, the assembly connection that sits where the mast meets the console and underneath the faceplate. Check to be sure that all of the connections are secure and that the pins within the cables are seated properly.
If you are still having any problems you can reach a knowledgeable Vision Fitness Representative toll free at 800-335-4348.
Mar 29, 2011 | Dmm Vision Fitness T9500 Treadmill
Exercise & Fitness Logo
14 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
