Question about Exercise & Fitness
Sole E25 Elliptical screen not resetting properly
Reboot sole e25 elliptical
SOURCE: E25
This happened to my Camera and I fixed it by turning it on and hitting the back of it hard and the lens retracted back into the camera.
Posted on Sep 20, 2007
  • 13 Answers
SOURCE: NOISEY SCHWINN 430 ELLIPTICAL
Hi I'm Ryan, do you know where it is squeeking from? if you can find the squeek try 3 in 1 oil that should stop it.
Posted on Dec 31, 2008
OrjisonStar
  • 5 Answers
SOURCE: i need sound driver for amilo la 1703 e25
Go to www.driver-downloads.com Goodluck.
Posted on Jul 24, 2009
SOURCE: I am looking for an owner's manual for the Champion Elliptical
Did you find a manual? I have the same problem.
Thanks.
Posted on Oct 28, 2009
  • 171 Answers
SOURCE: cd player not working. CD error E25
First get a CD Lens Cleaner and try it; if not, disconnect the negative lead from your car battery for about 10 min. BUT! Unless you have the radio code make sure you car radio doesn?t have an anti-theft system; if after this few steps still nothing you have to send it to an electronics repair shop (the CD Lens is bad).
Posted on Jan 06, 2010
Sole elliptical e55 makes thumping noise
If you wish to get some details about elliptical and treadmill ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 28, 2016 | Sole Fitness Sole E55 Elliptical
Why is the the resistance on my sole e55 remaining easy to spin regardless of which resistance setting I select?
Belt could have come off. if the belt did break or come of it would be very easy to spin pedals. Flywheel ( brake ) could have jammed up. Loosen the covers and look for the brake cable that's connected to the resistance motor. Then run the resistance up to 20. If cable feels loose , the brake is stuck. Sometimes you can pull on the cable and it will free it up.
Aug 30, 2014 | Sole Fitness Sole E55 Elliptical
Incline Error Message E3
If you wish to get some details; check the site linked here. Pull up older posts treadmill . http://electro-medical.blogspot.com/ Surf the site with patience.
Dec 23, 2013 | Sole Fitness Sole E25 Elliptical- 2013...
Sole elliptical display first said Level Err and now says Motor Error. What can I do to fix this?
follow this steps and fix it. God bless you
Check power problems if the console on the elliptical machine does not light up. Make sure that the plug for the machine is secure in the outlet. If it is plugged in, ensure that the outlet is receiving power. Check the breaker to make sure it has not tripped off.
Be sure that you are using the correct adapter that came with the elliptical machine. Because different adapters are able to handle differing amounts of energy, the wrong adapter will not transfer electricity like it should. If the adapter is pinched or damaged, this could also alter its effectiveness.
    • 2
Make sure the correct adapter is being used if the resistance settings seem to be too hard or too easy. If the correct adapter is being used, reset the machine. To reset the machine, either switch the "On/Off" button or unplug the machine from the wall. Doing this will allow the device to reset itself to the default resistance. Turn on or plug the device back into the wall and retry all of the levels of resistance.
    • 3
Do not be concerned if you see small particles left on the guide rails. Over time, the roller wheels gradually wear down. When this occurs, they leave residue on the rails. Because this is considered to be normal wear, all you need to do to fix the problem is wipe the rails off with a damp cloth.
    • 4
Minimize the risk of receiving erratic readouts on the monitors by avoiding outside interference. For example, gripping the heart rate handlebars too tightly can affect the monitor. Similarly, the heart rate grips can be rendered less effective when there is too much vibration. Consider not holding these monitors throughout the workout to minimize vibration. The readouts also can be affected by jewelry. To minimize errors, take off rings and other jewelry before working out on an elliptical machine.
Oct 17, 2013 | Sole Fitness Sole E20 Elliptical
Sole E55 console display flashing "Need Lube"
Got a Sole elliptical machine? Is it displaying a NEED LUBE error message when you turn it on? Tyler at Sole service told me this is a software bug. It appears every 180 miles of usage, and it was really only intended for treadmills, not ellipticals.
You can clean and lubricate the rails and wheels - and you should - but the error message won't go away. Instead, you can get rid of it by resetting the odometer. First, press and hold the Start, Enter, and Stop buttons for five seconds to enter engineering mode. Use the arrow keys to select FUNCTIONS, then select ODO RESET and press Enter. Turn the machine off and on again, and voila, no error message.
Thanks Tyler! Happy exercising!
Jul 06, 2013 | Sole Fitness Sole E55 Elliptical
Why did I suddenly lose resistance and smell burning on my sole e55 elliptical?
proceed according. iF THE problem persis after you LUBEt, TIME to replace the old board deck belt.God bless you
Apr 04, 2013 | Sole Fitness Sole E55 Elliptical
Where can I find the serial number on a Sole E25 elliptical trainer?
on the front of the machine, right under the display, on the back side, there is a pyramid shaped piece of plastic wrapped around the middle bar. pry it up with a screwdriver, it should unsnap, and will reveal the mythical red serial number.
Feb 08, 2011 | Health & Beauty
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
