Question about Sony VAIO V505DC PC Notebook
Would any 16volt ac adapter be ok to charge my PCG-VX89 vaio notebook?
Can i use any 16volt ac adapter to charge my vaio model # PCG-VX89
  • 191 Answers
You can use any laptop AC adapter DC output-16V and 4A (current). if its jack size natch your laptop DC jack.
if the adapter DC current less than 4A (over 2.5A at least) you should only make the battery charging without laptop turn on!!!
please take a rating let me know how much helped you thanks!
Posted on May 21, 2009
  • 1 more comment
  • Frank Zhang
    Frank Zhang May 22, 2009
    please take a rating if the solution helped you thanks! keep in touch your comment.
  • Frank Zhang
    Frank Zhang May 24, 2009
  • Frank Zhang
    Frank Zhang May 30, 2009
Battery/Ac adapter issues for Sony VAIO Model
So I gather the laptop does not run when the battery is in and the AC adapter is not connected? Laptop batteries tend to ware down over time and will need to be replaced as they end up not being able to hold any charge. Look online for a new replacement of the battery under the model number of your laptop
Aug 13, 2013 | Sony VAIO PCG-K33 Notebook
The dc in will not fit the power plug anymore
I think the internal socket on the main circuit board has broken . This is common enough with old laptops.
It will have to be dismantled and the socket replaced, which is easy enough for a tech.
http://www.insidemylaptop.com/disassemble-sony-vaio-pcg-k-notebook/
Sep 13, 2012 | Sony Vaio Pcg-K45 Notebook/Laptop/Notebook...
Sony vaio model pcg-61611L it turns on for 4 seconds and then it turns off using the ac adapter . help please
The charger may be bad, will it charge the battery? a common problem is the DC jack in the laptop breaks connection on the motherboard internittent operation or no power and shut down. If you can sub the charger that will tell if the power supply is bad or the problem is in the laptop. If the computer is the issue I recommend a professional because it will require extensive parts removal.
Mar 04, 2012 | Sony Vaio PCG-71318L
Is there a software that is associated with my sonny battery that will make it charge again
If you plug in your AC adapter to your laptop to charge the battery and get the "plugged in, not charging" message then try the following solution:
  • Disconnect AC adapter
  • Shutdown laptop
  • Remove laptop battery
  • Connect AC adapter
  • Power on laptop
  • Click the Startup Menu
  • Type Device and select Device Manager
  • Under the Batteries category, right-click Microsoft ACPI Compliant Control Method Battery and select Uninstall.
  • Shutdown laptop
  • Insert laptop battery
  • Power on laptop
    If you follow these steps and find that your laptop still does not charge then consider replacing the laptop battery itself.
    Hope to have been of assistance,
    Thanks.
  • Sep 14, 2011 | Sony VAIO PCG-K23 Notebook
    How can i get a free video device and driver for my sony pcg-r505v/db
    You can download the device drivers from the Sony WEB site.
    Select your model notebook and the Windows drivers you require. Please click on this link to the Sony support WEB site :-
    http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=1,24,72&DIRECTOR=DRIVER
    Aug 11, 2011 | Sony Vaio Pcg-R505V/Bd...
    HI IAM USING SONY VAIO LAPTOP VGN SERIES NR11Z/T WITH MODEL NO.PCG-7Z1M. MY LAPTOP DOESNT USE THE BATTERY WHEN I CAHRGE. PLEASE HELP ME. IAM FACING TROUBLE AS I WILL HAVE TO ALWAYS CONECT TO POWER IF I...
    Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
    Mar 12, 2011 | Sony Vaio PCG 7Z1M Laptop Universal AC...
    Sony Vaio PCG 7v2l won't turn on
    this may or may not be the solution but its some sort of indication of what is going on. Ok when you plug the ac adapter do u get a flashing light to indicate your batter is being charged? If you do then there is power going through the laptop to the battery, which is great. Now if you don't have the indicator flashing then it could be that the where the AC adapter plugs to the laptop could be now faulty. The other one could be that the AC adapter plug i.e. head that goes into the laptop some how internally has a severed connection.
    comment on what you find and ill see what else i can advice :)
    Plz rate me
    Jun 02, 2009 | Sony VAIO FRV Notebook
    Sony vaio pcg-grt170 when I push the power button, the green light and 2 yellow lights blink one time but the computer will not turn on. I tried taking the battery out, checked the power cord.
    Perform these steps and the issue will be resolved if the issue is with the Static charges on the Mother board.
    I recommend you use Power Drain procedure by following these steps:
    1. Disconnect the AC Adapter.
    2. Remove the Battery.
    3. Hold the Power button down for 30 seconds to 1 minute.
    4. Reconnect the AC adapter and do NOT connect the battery now.
    5. Turn on the Notebook power.
    Feb 18, 2009 | Sony VAIO GRT170 Notebook
    Sony VAIO V505DC PC Notebook Logo
    182 people viewed this question
    Top Sony Computers & Internet Experts
    Martin Murray
    Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
