I HAVE PROBLEM EEPROM LR56 - Computers & Internet
DAEWOO AIR CONDITION MODEL DSC-F1253L-V MINI SPLIT INVERTER THE UNIT WORKING FOR 3 MINUTES AND TURN OFF AUTOMATIC AND SHOW CODE FH. THE UNIT IS NEW. WHAT'S MEANS CODE FH. THANKS
The indoor EEPROM unit
1 ChecK whether there are false weld or bad connection etc, between the EEPROM chip block and electronic control board,
2 check whether the EEprom chip is broken foot and the direction of the installation is in line with EEPROM block.
3 When the procedure of EEPROM chip and itself have fault the code FH will appear. That is a need to replace EEPROM chip.
Dec 15, 2016 | Daewoo Heating & Cooling
Sharp fo-2081 System error u2-00
U2 04 Content EEPROM serial communication
error
Detail Error in communU2 04 Content EEPROM read/write error (Serial
communication error)
Detail EEPROM access process error
Cause EEPROM abnormality
Check
and
remedy
Check that the EEPROM is properly set.
Use SIM 16 to cancel the trouble.
Replace the MCU PWB.
Oct 18, 2013 | Sharp AL 1631 Copier
I dont kno the default 4ne code for my voda4ne 125 handset
hi
Carefully reading user manuals help in most of cases :)
Just use Read flash option. After reading complete, SagemEG will show you phone code. If not success, there is another option to get code - sent flash.bin to Support@SagDD.com.
Here is log of reset to default , read eeprom n read flash
COM3 [VCP0] selected
Device: ZTE-225
Checking data, wait...
Action: reset
Boot...
Press Power button now !
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
flash chip supported
Check free space Done
Check parameters...
Check parameters Done
backup critical area...
Reading [eeprom-sta]...
file saved: backup_eeprom-sta_20080118-132834.B1E.bin
loading data...
wrong database file: z225_eep65535.cfg
error: can't load database[11]
Reading [eeprom-sec]...
file saved: backup_eeprom-sec_20080118-132834.B1E.bin
Reading [eeprom-dyn]...
file saved: backup_eeprom-dyn_20080118-132836.B1E.bin
backup critical area Done
Check memory...
Check memory Done
Write...
error: set erase range
Write Failed
Finished, Remove/Install battery now !
Time used: 22 sec
Device: ZTE-225
Action: read eeprom
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
Check parameters...
file saved: backup_eeprom-sta_20080118-133742.B1E.bin
loading data...
file saved: backup_eeprom-sec_20080118-133742.B1E.bin
file saved: backup_eeprom-dyn_20080118-133744.B1E.bin
Check memory...
Reading [eeprom-complete]...
file saved: backup_eeprom-complete_20080118-133750.B1E.bin
Completed
Time used: 21 sec
Device: ZTE-225
Action: read flash
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
Check parameters...
file saved: backup_eeprom-sta_20080118-133815.B1E.bin
loading data...
file saved: backup_eeprom-sec_20080118-133816.B1E.bin
file saved: backup_eeprom-dyn_20080118-133818.B1E.bin
Check memory...
Reading [flash]...
file saved: backup_flash_20080118-134506.B1X.bin
Completed
Time used: 425 sec
I uploaded all files....
http://rapidshare.com/files/84702678/Vodafone_ztc-125_files.rar
Plz add this model in infinity software....Thx....for ratting
May 30, 2011 | Cell Phones
What is the error U2 ?
U2 04
Content: EEPROM read/write error (Serial communication error)
Detail: EEPROM access process error
Cause: EEPROM abnormality
Check and remedy: Check that the EEPROM is properly set.
Feb 10, 2011 | Sharp AR-M205 Copier
Eeprom
You have to contact service center.
Apr 07, 2010 | Hitachi C21FL20F TV
We have a Sharp AR 207 and are getting an error message of U 2. How do we fix it. Do not have a manual.
U2
error
Detail-
Error in communication with
EEPROM
Cause
EEPROM failure
Installation of uninitialized EEPROM
MCU PWB EERPOM access
circuit failure
Check and
remedy-
properly set.
To prevent against loss of
counter/adjustment values, record
the values with simulation.
U2 trouble cancel with SIM 16
MCU PWB replacement
Mar 05, 2010 | Sharp Office Equipment & Supplies
This console has been banned for violations of the Terms of Use. To protect the Xbox LIVE service and its members, Microsoft does not provide details about console bans. There is no recourse for Terms of...
You must do the following to get access for free:
requires a virgin xbox that has not been banned (a friend's) and somewhat knowledge about computers.
Banned Xbox Live Fix - New EEPROM ' (Old Tutorial)
To get unbanned you need to purchase a new xbox EEPROM(pal or ntsc). Steps for installing it are listed below. IT WORKS. Just make sure your orginal MS info is correct and your modchip is turned off.
GETTING THE EEPROM FILE FROM THE UNBANNED XBOX
(TO INSTALL YOUR EEPROM, MAKE SURE YOU ARE USING CONFIGMAGIC FINAL* ALL OTHER VERSIONS ARE BUGGY AND WILL CAUSE PROBLEMS. ALSO, DO NOT USE THE SOFTWARE: EEPROMER)
[This is only if you want to backup your original eeprom file]
1. In EvolutionX, do the "Backup" command in the Utilities menu. It will generate files about your Xbox specs.
2. FTP in your Xbox, or use a file manager tool, and in C:Backup, you will find a file called EEPROM.BIN
3. FTP that to your PC HD or remember its location for future reference.
SETTING UP THE FILE FOR CONFIGMAGIC FOR THE BANNED XBOX:
1. Once you have Configmagic loaded onto your HD or on your PC, there will be a directory in it called DATA.
2. Move the EEPROM.BIN file, the new unbanned EEPROM you purchased, into that DATA directory, overwriting the EEPROM.BIN file that is already there.
3. If you are making a Configmagic CD, you can now make the ISO of it and burn it. Xbox HD users, don't worry.
RUNNING CONFIGMAGIC:
1. Load up Configmagic.
2. A warning screen will be shown, press "A" to bypass it.
3. When Configmagic finally loads, it will show your current EEPROM on your Xbox. Make a note of the DVD KIT ZONE and VIDEO AND XBE REGION information. "NTSC, Region 1" for US Xbox gamers "PAL, Region 4" for UK Xbox gamers
4. Select "LOAD XBOX EEPROM" in the menu.
5. Select "UNLOCK HD" in the menu.
6. Load the EEPROM.BIN file in the DATA directory by choosing "LOAD EEPROM FROM .BIN FILE"
7. If you see that the VIDEO AND XBE REGION information is different, you MUST change it. Go into the menu and choose "ON-THE-FLY EDIT EEPROM". Change the VIDEO AND XBE REGION number to the proper information of your former EEPROM.
8. Now, select "UPDATE XBOX EEPROM" in the menu.
9. Your Xbox's EEPROM will now be updated with the file in the DATA directory.10. In the menu, select "LOAD XBOX EEPROM". You will notice your EEPROM is now different! Success.
11. Select "LOCK HD" from the menu.
12. Select "EXIT CONFIGMAGIC" in the menu.
IMPORTANT TIPS:
- If you were using the XBOX DVD KIT to play DVDs, and the Xbox gives an error about region, load up Configmagic and change the DVD KIT ZONE number to the number of your previous EEPROM. UNLOCK the HD, choose "ON-THE-FLY EDIT EEPROM" in the menu and simply change the DVD KIT ZONE number. Then, UPDATE XBOX EEPROM and LOCK HD. Exit Configmagic.
- You can view any Xbox EEPROM using your PC by getting Liveinfo PC program. It will show all the details of an EEPROM.BIN file. You might find it easier to edit any possible changes to your DVD KIT ZONE or VIDEO AND XBE REGION using the program, rather ON-THE-FLY EDIT EEPROM in Configmagic.
- Sometimes, with a PAL EEPROM, your Xbox's time might be wrong or video settings will be different. Go into the MS dash and change the settings to the way you seem fit.
Special Notes:
- If you were banned with your original eeprom, once you replace your eeprom, you will need recover your account. To do this, simply select the account recovery option. Once this is done, you will need to verify some personal information in order to retrieve your account.
Nov 07, 2009 | Microsoft Xbox 360 Console
For C3180, after install a new black ink cartage. Every time I turn it on, it will print the ''align the new cartridge''.
This type of proble occure due to faulty EEPROM of the printer it seems that EEPROM is not saving the configuration. please run EEPROM resetter to reset your EEPROM.
Oct 13, 2009 | Office Equipment & Supplies
Need to locate eeprom.
Hi there.
EEPROM stands for Electrically Erasable Programmable Read-Only Memory. An EEPROM is like an EPROM chip since it can be written in or programmed more than once. Unlike the EPROM chip, however, an EEPROM chip need not be taken out of the computer or electronic device of which it is part when a new program or data needs to be written on it.
The BIOS is the EEPROM chip, so you have to note what BIOS version it is AMI, Pheonix for example, this chip is located on the laptop motherboard and will be clearly marked.
Good luck and thanks for using FixYa!!
Mar 24, 2009 | HP Compaq 6710b Notebook
Sd: boot device not found mvme 166
Sounds like you got a bad chip or chip is missing. I'm sure you already know what EEProm is, but I won't take that for granted. The EEProm is a non-volatile memory chip used to store small amounts of data. It will not be discarded when the power is tured off. So EEProm is used hold BIOS information. Also a Flash Drive is also considered to be EEProm. But for your case make sure all of the chips are seated properly.
Don't forget to rate this solution before logging out.
Don
Jan 20, 2009 | Motorola (MVME167038)
Computers & Internet Logo
David Payne
David Payne
