Question about Stihl Garden
How to replace fuel filter - Stihl Garden
How to change fuel filter triton 3.2L diesel 2009 mL
Posted on Feb 04, 2015
Replaced the fuel pump and filter on a 2000 Nissan Altona it's shooting fuel from the pump but not near the filter what can cause this
Nissan fuel pump recall : Nissan Altima Common Engine ...
repairpal.com > Problems > Nissan > Altima
Nissan issued a recall on the fuel pump for premature failure. ... I am in need of a newfuel pump and scared to drive my car and its leaking ... pump and fuel filter located and how can i access them if i wan to replace th. ... 2000 Nissan Altima.
Fuel pump and fuel filter - 2003 Nissan Altima - RepairPal
repairpal.com > Questions > Nissan > Altima > 2003 Nissan Altima
Mar 25, 2009 - Where is the fuel pump and fuel filter located and how can i access them if i wan to replace them?
Fuel Pump Replacement Cost for Nissan Altima - RepairPal ...
How To Replace Fuel Filter on Nissan Altima 2001 - YouTube? 6:46https://www.youtube.com/watch?v=Vwg2wm13ilMOct 25, 2011 - Uploaded by roluardoHow To Replace Fuel Filter on Nissan Altima 2001 ... How toreplace a 2002 Nissan 3.5 Maxima Fuel Filter 2000-2004 pt 1 - Duration: 14:20.fuel hose replacement. Car fuel leakage. fuel pump ...? 5:30https://www.youtube.com/watch?v=BPGaxxkK71cApr 4, 2014 - Uploaded by LearningZoneHere I am going to illustrate the fuel hoses (fuel lines)replacement for Nissan Sentra ... Fuel pump leak fix - quick and cheap - Duration: 11:16.
Jan 13, 2016 | Nissan Cars & Trucks
What could cause the engine not to stay running after the fuel filter was replaced? Even after fuel pump was replaced?
From remote site, it is hard to tell what is the root cause, and change pump was done in proper order -- you should post the problem before replacing fuel pump.
Here is what I will do, assume you can do a little by yourself.
Changing fuel filter should be easy by disconnect fuel hose (pipe) from the fuel filter . Since ASE mechanic did job in your house, I assume the old fuel filter is still in your hand. Change it back (replace new filter with your older one) to see if your car will work as before. This supposed to be done before replacing the fuel pump.
If older filter works, then you knew the new filter is the root cause. This could be resolved by replacing another new filter. If the problem appear again, leave the new filter in for over night to see if the new filter will work on the next day (you could use exiting new filter to avoid buying another filter, unless you will get a different brand one). If not, the choice is to use older one for a while when trying figure why new filter does not work.
If old filter does not wok either, then something is in forwarding fuel line between fuel filter and fuel ejection system. Then, that section needs to be cleaned. Assume the pressure is measured at connection between forwarding line and fuel filter.
Oct 05, 2014 | GMC Sonoma Cars & Trucks
Where is 2004 avalanche fuel filter
The fuel filter is contained in the fuel sender assembly inside the fuel tank. the paper filter element of the fuel filter traps particles in the fuel that may damage the fuel injection system. The fuel filter housing is made to withstand maximum fuel system pressure, exposure to fuel additives, and changes in temperature. There is no service interval for fuel filter replacement.
IMPORTANT: This vehicle has a lifetime fuel filter built into the fuel sender inside the tank and thus is not serviceable separately. The fuel filter is not a replaceable part.
Jul 15, 2014 | Chevrolet Malibu Cars & Trucks
Replacing fuel filter
Hello kenny,This article is showing the instructions of replacing fuel pump and fuel filter,you can read it ,How to Replace Fuel Pump and Fuel Filter
Mar 01, 2014 | Cars & Trucks
How to change fuel filter catrige and micro filter on BMW X3
IF YOU HAVE FUEL FILTER WITH FUEL PUMP ASSEMBLY YOU HAVE TO REPLACE FUEL PUMP ASSEMBLY REMOVE THE REAR SEAT BENCH IN ORDER TO REPLACE THE FUEL PUMP ASSEMBLY. NOW IF YOU HAVE FUEL PRESSURE REGULATOR AND FUEL FILTER AS ONE UNIT.BECAUSE FUEL PRESSURE REGULATOR BUILT TO THE FUEL FILTER.TO REPLACE FUEL FILTER, FIRST DEPRESSURIZE THE FUEL SYSTEM BY REMOVING THE FUEL PUMP RELAY LOCATED ON THE COWL.THEN CRANK ENGINE UNTIL IT DIES LACK OF FUEL.THE CRANK ENGINE OVER FEW TIMES TO MAKE SURE ALL FUEL OUT THE FUEL LINES.LOCATION OF FUEL FILTER UNDER THE VECHICLE MOUNTED TO THE LEFT SIDE OF THE CHASIS.
Jul 12, 2011 | 2009 BMW X3
2002 kia sedona, can you replace the fuel filter without replacing the fuel pump
the fuel filter is inline with the fuel line in front of the fuel tank. Inside the tank is a sock that filters the fuel in the suction pipe to the fuel pump also That sock filter is always replaced upon replacing the pump only.
Apr 18, 2010 | 2002 Kia Sedona
Replace Fuel Filter on 2006 Chevy Aveo Hatchback
If the fuel filter is mounted inside the fuel tank at the pump it does not need replacing and is a permanent filter. All you have to do it follow the fuel lines from the fuel tank to the engine. If the filter is mounted in the fuel line you will find it.
Dec 10, 2009 | 2006 Chevrolet Aveo
I need to replace my fuel filter. need to know where it is and what i need to do to access it.
Regarding Fuel Filter - Under vehicle, driver side, below seating area, front of fuel tank, mounted on chassis in fuel line.
A device located in the fuel line to remove impurities from the fuel before it enters the carburetor or injector system.
INSPECTION
Fuel filters can be located in a fuel line, in the tank, in a carburetor, or in any combination of these. A carburetor often has a filter behind the fitting at its fuel inlet.
A carburetor inlet filter. Courtesy of General Motors Corporation, Service Technology Group. Fuel filters that are installed on the outlet side of a fuel pump are called outlet filters.
An external fule filter. Courtesy of General Motors Corporation, Service Technology Group. Engine heat causes fuel to vaporize, which can result in vapor lock in the filter. Some fuel filters have vapor return lines to allow for expanding vapors and fuel to return to the tank.
A fuel filter with a vapor return outlet. Courtesy of AlliedSignal Automotive Aftermarket. Fuel injection systems require larger, heavier duty filters than carburetors. They filter out smaller particles of dirt while still allowing the pump to supply a substantial amount of fuel.
REPLACE
Fuel filters and elements are serviced by replacement only. Some vehicle manufacturers recommend fuel filter replacement at 30,000 miles (48,000 km). Always replace the fuel filter at the vehicle manufacturer's recommended mileage.
The fuel filter replacement procedure varies depending on the make and year of the vehicle and the type of fuel system. Always follow the filter replacement procedure in the appropriate service manual. The photo sequence below shows a typical procedure for relieving fuel pressure and removing a fuel filter.
Removing a Fuel Filter on an EFI Vehicle
Disconnect the negative cable at the battery.
Loosen the fuel tank filler cap to relieve any fuel tank vapor pressbae0f2b.jpga678067.jpg
Connect the fuel pressure gauge to the Schrader valve.
Install the free end of the gauge bleed hose into an approved gasoline container, and open the gauge bleed valve to relieve the fuel pressure.
Oct 08, 2009 | 1997 Chevrolet Malibu
Fuel filter location for 1996 honda odyssey
All of the fuel filters with exception of the V6 Odyssey models are located on the vehicle's firewall, in line with the fuel line feeding the engine's fuel rail. The fuel filter on the 3.5L V6 Odyssey is located in the fuel tank and requires fuel pump removal to access. Fuel filters located on the firewall should be replaced if the fuel filter exhibits signs of seepage or corrosion. Always replace a fuel filter and its sealing washers if the fuel system has become contaminated, if the fuel system fuel pressure drops below specification prior to replacing the fuel pump, or whenever the fuel pump is replaced.
Jun 06, 2009 | 1998 Honda Accord
How to replace fuel filter on a Mercury Village '95?
go here for help on villager issues
http://autos.groups.yahoo.com/group/villagerquest/
It's unde the hood, on the firewall, on the driver side.
Fuel Filters In-Tank
Removal and Installation
The in-tank fuel pump filter is not serviced separately. To service the fuel pump filter, replace the fuel pump (9350). Refer to the procedure in this section. In-Line
Removal
The following illustration is an exploded view of the fuel filter (9155).
Item Part Number Description 1 9K299 Fuel Filter Upper Hose 2 9A335 Fuel Filter Bracket 3 — Fuel Hose Clamp 4 9C323 Fuel Filter Lower Hose 5 9155 Fuel Filter 6 — Fuel Hose Clamps
  1. Relieve the fuel system pressure. Refer to the procedure in this section.
  1. Remove the fuel hose clamps.
  1. Disconnect the upper and lower fuel filter hoses from both ends of the fuel filter. Plug the fuel hoses to prevent leakage and contamination.
  1. Remove the fuel filter from the fuel filter bracket (9A335).
Jun 05, 2009 | 2001 Mercury Villager
Garden Logo
721 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
