Question about Garden
My snow thrower shuts off every time I set it to run. It starts right up, but as soon as I move the choke, it shuts down
    Sergeant:
  • 416 Answers
Clean the carb and put fresh gas in it
Posted on Feb 02, 2015
I have a 26 in craftsman snow thrower brand new engine runs erratically hunting
The choke does not have to be all the way open on a snow blower engine. The choke control has notches or steps for that reason. With the engine running adjust the choke one notch at a time until it smooths out. Once the engine warms up you may have to adjust the choke a notch or two to keep it running smoothly.
Mar 11, 2017 | Craftsman Garden
Hello I have a craftsman 123cc single stage 4 cycle snow thrower. . Motor runs great with a little choke. When I put choke off it runs high and low. The spring linkages are moving back and forth
pull the carby and clean out the jets and passages
the carby cannot produce a constant air/f;ow mixture unless the choke is on and the governor is having difficulty keeping the engine speed constant
Oct 19, 2015 | Garden
Start snow blower runs for 3 min. and starts to over heat checked oil its ok then stats to shut down like its not geting oil
Why do you say its over heating .Runs for 3 minutes the oil is OK .
Do you understand how the choke works .
bacsicly you prime the mechine in cold condutions 3-4 pumps choke to max throttle at 3 /1/4 .
Start backing off the choke after 3-to4 mins .
The choke shuts the fresh flow down to the engine in cold condutions ware it needs more fuel then air to run.
When the engine starts to get hot it can't run with out fresh air to mix with the gas it won't run anymore because there is to much gas and not enough air
Its simple fool prof will work everytime if you adjust it right
Mar 01, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Snow thrower starts then shuts down after a few minutes
Hmmm... THAT sounds like you have an obstruction (ice???) in the fuel line or in the bottom of the tank.
Feb 15, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Cannot start Craftsman snow thrower Model 247.886911
Did you get this resolved? I bet the Ethanol gas beat up your carburetor over the Summer
Jan 27, 2014 | Garden
Why does my snow thrower shut off every time I set it to run?
carb is dirty and needs rebuild and new diaghrams or buy a new one for 30 bucks or less on ebay
Jan 02, 2014 | Garden
Toro snowthrower 38180 won't start
You have probably fouled the spark plug (got a heap of black carbon on it) remove the spark plug wash in some petrol then use a wire brush vigorously brush between the contact points on the plug then reinstall. & lastly don't forget to push in the choke when you get it fired up next time.??
Mar 14, 2017 | Garden
Snow blower won't stay running
ok heres what you do to get your snow blower to keep running.
while you have it choked, and you get it to the running point, turn the cup bowl ajustment in/out a fraction at a time while you move the chock off slowly till you get the right setting to keep it running then ajust the setting once more to clear it up to purrr like a kitten again the vibration moves the screw out to set everything out of wack......
Feb 09, 2010 | Craftsman 16" High Garden Tractor Snow and...
!332 Snow Thrower will not Start - At full choke
change gas filter and spark plug
Oct 07, 2009 | Garden
Snow thrower won't start.
could possibly be the governor it may have contacted the flywheel if it has came apart under the flywheel cover  are the metal fragments easy to pick up with a magnet or  are the aluminum ?  if they are not picked up by a magnet  your problem lies  else wear
Feb 16, 2009 | 2004 Yamaha YZ 450 F
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
