Question about Garden
Why does my snow thrower shut off every time I set it to run?
It starts right up, but as soon as I move the choke, it shuts down
  • Greg Hoffman
    Greg Hoffman Jul 02, 2015
    Might need a new diaphragm in farn
  • Greg Hoffman
    In carb sorry about not catching my autocorrect
    Top Expert:
  • Garden Master
  • 45,384 Answers
That would tell me it has a fuel problem and needs service done on the carburetor
Posted on Jul 02, 2015
    Top Expert:
  • 10,875 Answers
Carb is dirty and needs rebuild and new diaghrams or buy a new one for 30 bucks or less on ebay
2 Suggested Answers
  • 451 Answers
SOURCE: Craftmans Snow Thrower 247887001 Tire Flat. How to Refill.
The tires are probably tubeless type. If the bead is broken ( not sealed to the rim) the tire will not inflate. Taking the weight off the tire will some times allow the bead to seal against the rim and allow tire to be inflated. You can also put a small ratchet strap around the tread of the tire and tighten it up. This will squash the tire and make the bead seal up. MAKE SURE to loosen strap as soon as bead seals and tire begins to inflate. Hope this helps.
Posted on Jan 01, 2014
How can I adjust the throttle on my Toro Snow thrower?
There are a couple of reasons this could be happening.
1 - Check the top of the throttle shaft where the shaft meets the plate, if it is loose or separated it will not allow the throttle plate to move properly.
2 - The governor spool may be damaged internally in the engine.
http://www.barrettsmallengine.com/manual/tecumsehlheadmanual.pdf
http://www.barrettsmallengine.com/manual/tecumsehcarburetormanual.pdf
Feb 03, 2016 | Garden
Hello I have a craftsman 123cc single stage 4 cycle snow thrower. . Motor runs great with a little choke. When I put choke off it runs high and low. The spring linkages are moving back and forth
pull the carby and clean out the jets and passages
the carby cannot produce a constant air/f;ow mixture unless the choke is on and the governor is having difficulty keeping the engine speed constant
Oct 19, 2015 | Garden
Start snow blower runs for 3 min. and starts to over heat checked oil its ok then stats to shut down like its not geting oil
Why do you say its over heating .Runs for 3 minutes the oil is OK .
Do you understand how the choke works .
bacsicly you prime the mechine in cold condutions 3-4 pumps choke to max throttle at 3 /1/4 .
Start backing off the choke after 3-to4 mins .
The choke shuts the fresh flow down to the engine in cold condutions ware it needs more fuel then air to run.
When the engine starts to get hot it can't run with out fresh air to mix with the gas it won't run anymore because there is to much gas and not enough air
Its simple fool prof will work everytime if you adjust it right
Mar 01, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Snow thrower starts then shuts down after a few minutes
Hmmm... THAT sounds like you have an obstruction (ice???) in the fuel line or in the bottom of the tank.
Feb 15, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Snow thrower that wont stay running
clean the carb
check you have gas in it
Feb 01, 2014 | Garden
Toro snowthrower 38180 won't start
You have probably fouled the spark plug (got a heap of black carbon on it) remove the spark plug wash in some petrol then use a wire brush vigorously brush between the contact points on the plug then reinstall. & lastly don't forget to push in the choke when you get it fired up next time.??
Mar 14, 2017 | Garden
Snow blower won't stay running
ok heres what you do to get your snow blower to keep running.
while you have it choked, and you get it to the running point, turn the cup bowl ajustment in/out a fraction at a time while you move the chock off slowly till you get the right setting to keep it running then ajust the setting once more to clear it up to purrr like a kitten again the vibration moves the screw out to set everything out of wack......
Feb 09, 2010 | Craftsman 16" High Garden Tractor Snow and...
!332 Snow Thrower will not Start - At full choke
change gas filter and spark plug
Oct 07, 2009 | Garden
Snow thrower won't start.
could possibly be the governor it may have contacted the flywheel if it has came apart under the flywheel cover  are the metal fragments easy to pick up with a magnet or  are the aluminum ?  if they are not picked up by a magnet  your problem lies  else wear
Feb 16, 2009 | 2004 Yamaha YZ 450 F
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
