Question about Sony TC WE435 Stereo Dual Cassette Deck Single Dual Cassette Deck
Belt replacement in a sony tc-wr645s tape deck
Looking for instructions on replacement of belts. which screws to pull, what to look out for...such as gear alignments, etc.
  • 104 Answers
I have just spent half a day trying to replace the drive belts in my sony twin deck unit , in the end it still didnt work as the the old rubber belt did some damage to the unit , anyway shops like **** smith or tandy stock the drive belts , take the front of the unit away from the main case there will be a plastic casing that surrounds the belts there are at least two belts, there should only be two small screws undo these and move the plastic unit forward on the plastic mounting brackets then you will see the metal wheel and the plastic wheel that you fit the belt around , its a bit fiddly but i can do it in my sleep now even though the motor died it was a good experience
Posted on May 23, 2009
I replaced capstan belt and now the reverse play doesn't work. I guess I didn't align the belt around the wheels the right way. I have a sony cassette deck tc-we605s. Do you have an image of how...
You do not need any special instructions- look at the flywheels when they are running- they are hooked to the capstan shafts. The capstan shaft have to go in opposite directions for auto reverse so just threat the belt to that this happens- the unit should then work.
You can get a Service manual from Hi Fi Engine maybe
Aug 26, 2011 | Sony Audio Players & Recorders
Sony TC-138SD cassette deck starts to play then stops after 3 secs. Same when trying to rewind/fast forward
It sounds like the belt is slipping or broken which monitors the speed of the tape movement. When you play or rewind the tape, it thinks the tape has reached the end of play and shuts off. You can try a different tape to make sure the tape does not have too much tension on it. If the second tape has the same result you will need to remove the top cover of the deck to inspect the tape drive mechanism. Make sure the belts and pulleys are clean and replace any belts which have glazing or cracks. If the belt is broken you will need to replace it with a compatible belt of the same length and width.
Aug 15, 2011 | Sony CASSETTE DECK Single Dual Cassette...
Sony tc-wr535 won't eject. Tape stuck. Won't play cassette on either deck A or B .makes noises but won't FF or play, gets stuck and wont eject. Will belt conditioner work? What do I use?
The problem, according to messages on your site, is that the belts are old and have stretched. There is a great step by step tutorial on www.Instructables.com with pictures and all. Parts are not too hard to find on search engine. Looks like less than $25 to fix.
http://www.instructables.com/id/How_to_replace_the_belts_on_a_Sony_TC_WR535_Dual_C/
Jan 16, 2010 | Sony CASSETTE DECK Single Dual Cassette...
NEED THE PART NUMBER FOR SONY TC-WE435 DUEL CASSETTE PLAYER BELTS
Flat belt part number is..
301657001.. BELT (CAPSTAN)
and square belt part number is...
302440501.. BELT (FR2)
Above said info are taken from TC-WE435 cassette player s/m.
Thanks.
Dec 25, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
Sony tc-we471 deck belts are melted or broken need to replace
Well I can't find this model exactly but other sony dual decks seem to use a belt that is 8.2 inches in circumference. See page 88 of
http://russellind.com/client/download/PRB_Belt_XRef.pdf
you will have to match the width as close as what you have left.
or try to call Sony service
May 26, 2009 | Sony Audio Players & Recorders
Cassette Tape stuck
The problem here is that the unit is stuck in a partial position. The "reset" by unplugging and plugging back in usually causes the unit to reset to a known position. If there is no activity (no motor sound), it will need to be opened up and reset manually. If you hear the motor running for a short period, it is attempting to reset, but the belt is most likely worn or broken. These units are relatively simple, but a bit tricky to dis-assemble. This repair should not require anything other than a belt or 2. Figure on $3-$10 for parts plus the local labor rate for the repair.
Dan
Sep 30, 2008 | Audio Players & Recorders
Sony Cassette TC-WR535 BELT REPLACEMENT
Unit may have defective idler or gear. Have serviced
Aug 05, 2008 | Sony CASSETTE DECK Single Dual Cassette...
Cassette Tape stuck
Try pushing the eject button while pusshing the power button. Mine was doing the same and that is how I was able to eject the tape.
Good luck
sam
Jan 01, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
Sony dual cassette deck TC-WR535
i had the same problem of not opening the cassette doors and not running with my sony tc wr535. After I repaced the belts myself with new ones it did run fine! :-) An original sony(!) rubber belt set for the two decks costed me 23 euroos incl pp.
Nov 29, 2007 | Sony CASSETTE DECK Single Dual Cassette...
Replacing drive belts on Sony TC-WR535
http://www.eserviceinfo.com/index.php?what=search2
I am having the same problem with a Sony K717 ES. I found
this site above where they have the service manual for every tape cassette known to man. They ask that you make a donation to
a charity and then they will email you the pdf for free.
Sep 25, 2007 | Sony CASSETTE DECK Single Dual Cassette...
Sony TC WE435 Stereo Dual Cassette Deck Single Dual Cassette Deck Logo
1,543 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
