Question about Lands Phones
Vtech ia5863 How to derigister handset and register to new base unit ia5863
SOURCE: Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
Posted on Apr 13, 2008
SOURCE: Register additional handsets on a Uniden phone
On most models you can find an option in the menu for De-register? In that case you would select that option and select to deregister the handset.
TRU88 models you go to the main menu and go to De-register HS select yes to deregister the Handset.
DCT5 and DCT6 models: Press menu on the handset. Go to System Reset and Press select. Go to Deregister HS and press select. Arrow up to yes and press select. Then go back into the menu. Go to system reset and press select. Arrow down to Replacing the base and press select. Arrow up to yes and press select.
DCT7 models: Press and hold "end" and "#" until the system reset menu appears on the display. Then follow the instructions from above for the DCT5 and DCT6 deregister procedures once your into the menu.
TRU4 and TRU5 models: Press and hold xfer/del and end until "de-register?" appears. Use the plus+ button to go up to yes and press select.
To register any of the following phones please see you owners manual under either:
•Register handset or
•Register the digital security code.
Posted on Mar 05, 2009
  • 4 Answers
SOURCE: How to I reset the base for a Vtech VT-2431
This worked for me after lots of digging....If you have already tryed reregistering your handsets and can only get two-or three to work try this and deregister them and re-register. If your base model number is vt2431: Take the handset out of the base, press **335782 on the dial pad of the base. (do not have the line active or anything , just put the (2) stars and 335782 in (no spaces) on the base unit. This will de-register all of the handsets at one time.
Posted on Aug 16, 2009
SOURCE: Reset base unit of Uniden TRU9485
Uniden TRU9485 (This didn’t work for me but this was the first instruction from Uniden Tech Support)
TO RESET THE BASE UNIT:
Unplug the base unit AC adapter.
Hold down for 15 seconds the DND, * and “menu” soft key (the middle silver soft key under the LCD) while plugging the base unit AC adapter back in.
All the settings should be reset.
Uniden TRU9485 (Worked for me)
ALTERNATE WAY TO RESET THE BASE UNIT:
Hold down for 15 seconds the DELETE KEY (zero with a line through it) while plugging base unit AC adapter back in.
Posted on Sep 20, 2009
SOURCE: My vtech 5825 screen says NOT REGISTERED and does not work
Place the handset in the charger and press find handset for 4 seconds.This will register the handset. do the same for other handsets.
Bought a used vtech 5.8 phone, charged the battery and now see message "not registered. I can not make calls... how do I register it?
I believe it is telling you it is not registered with the Base Unit. You did get the Base Unit with it didn't you, otherwise you have a paperweight.
If you do have a set then this is the answer
Tip 1 of 1
Step 1: Place the handset in the base or charger. If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in the base or charger.
Step 2: On the telephone base, press and hold FIND HANDSET for approximately four seconds. Release FIND HANDSET once the IN USE light comes on.
After a while, the handset will emit a series of tones, and the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
https://vt.vtp-media.com/ecp/documents/product_Product/67/UserManual/1647/ia5874_manual_bkm.pdf
Search Results
VTech 5.8GHz Cordless Home Telephones & Handsets ' eBay
https://www.ebay.ca > ... > VTech 5.8GHz Cordless Home Telephones & Handsets Results 1 - 25 of 151 - This is a Vtech 5.8 cordless phone digital answering machine base with time stamp & a handset that needs a new battery. It came from an ...
Technical Product Support ' VTech® Cordless Phones
https://www.vtechphones.com/support/technical-support Stay up-to-date on new VTech products, emerging technology and special offers. ... My VTech DS6722-3 Cordless Phone rings once and then disconnects. Why ...
Vtech 5.8 Phone Instructions ' Techwalla.com
https://www.techwalla.com/articles/vtech-58-phone-instructions Mar 31, 2015 - The Vtech 5.8 is a cordless phone that allows you to add additional handsets to your main phone so that you can have quick access to phones ...
[PDF]User's manual - VTech Canada
www.vtechcanada.com/support_docs/vtt/CS/CS5111-x_en_cib.pdf everything new at VTech, visit our website at www.vtechphones.com. ..... Once you have initiated your call by dialing the phone number in pulse (rotary), press.
[PDF]User's Manual
https://vt.vtp-media.com/ecp/documents/product.../67/.../ia5874_manual_bkm.pdf and operate your new VTech phone . Please take the ... Enhanced 5.8GHz Technology - Dual band transmission combines the best of 5 .8GHz and 900MHz ...
Video as well in link
vtech 5 8 phone Google Search
Jul 17, 2017 | Vtech Lands Phones
Lighting knocked out a base of VTech 15950. I replaced whole unit, working ok. But old handset, registered with old base shows "Out of range OR No power at base ". It doesn't response to any button.
There is a registration process you have to go through with each handset to connect the old handsets to the new base. It should explain it in the users manual for the base.
Mar 22, 2017 | Vtech Lands Phones
How do I register my vetch cordless phone?
General - Product Troubleshooting - VTech® Cordless Phones
www.vtechphones.com/support/.../35/178
VTech Communications Inc.Step 1: Place the handset in the base or charger. If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in the base or charger. Step 2: On the telephone base, press and hold FIND HANDSET for approximately four seconds.
Product Registration - VTech® Cordless Phones
https://www.vtechphones.com/.../product-re...
VTech Communications Inc.Vtech DECT 6.0 cordless phones are among the most advanced and innovative homephones on the ... Product Registration. How do I register my product?
vtech cordless handset, how to register - YouTube
? 3:21
https://www.youtube.com/watch?v=dV9rZ_cYcks
Feb 22, 2015 - Uploaded by Brian Williams
i registered my handset but im not able to call and answer call from my ... you lose your phone you have to de register allphones and start over.
Jan 21, 2016 | VTech Communications CS6114 - cordless...
How do we add additional handsets to a vtech 6.0 phone?
search through the menu's for the base unit - and you should come across register handset - choose yes or accept ?
on the new handset you should also see register handset do the same select yes and the 2 should see eachother and link to one another
May 08, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
Vtech Dect 6.0 says not registered. how do I register?
Instructions for registering additional new handsets on VTech Model DS6151: Place additional handset on main base. Press HOLD on main base and # on handset. Asks you to de-register. Press no. Registration of additional handset takes place.
Aug 17, 2010 | Vtech DECT 6.0 Digital Cordless Phone
How do I deregister my handsets on my VTech 2656
To be able to register your replacement handset, you must de-register all the handsets from the VT2656 base unit.
Follow the steps below to de-register your handset(s) from the VT2656 base:
1. Take out the handset that sits on the base.
2. Unplug power from the base.
3. Hold down PAGE while reconnecting power. When the In Use light blinks, release the PAGE key.
4. Hold down PAGE key for 5 seconds. When the In Use light begins to flash, release the PAGE key.
5. The handset charging light will blink 5 times. Within 5 seconds from when it stops blinking, press PAGE once.
You must register the handset(s) by following the steps below:
1. After charging the handset, remove it from the cradle, the LCD display will read "SEARCHING FOR BASE".
2. Press "NEW" and then enter the 15-digit Base ID code, located on the underside of the VT2656 base unit.
3. Press "OK". The handset will display "PLEASE WAIT!!".
4. Wait approximately 15 seconds. The handset will display "FOUND BASE". If the handset displays "BASE BUSY TRY LATER", this indicates that the system is in use. Wait until the base unit is in the idle (on hook) mode and repeat steps 2-4.
Apr 30, 2010 | Vtech Digital Cordless Telephone VT-2568
This worked for me after lots of digging....If you have already tryed reregistering your handsets and can only get two-or three to work try this and deregister them and re-register. If your base model number is vt2431: Take the handset out of the base, press **335782 on the dial pad of the base. (do not have the line active or anything , just put the (2) stars and 335782 in (no spaces) on the base unit. This will de-register all of the handsets at one time. Then just re-register the handsets...
May 29, 2009 | Vtech VT-2431 Cordless Phone
Feb 28, 2009 | Vtech VT-2431 Cordless Phone
Problems with C110 & A110 Vtech Mirage Dect Home phones
Have strangely got the same problem - about the same time you posted this, but intermitently. I have isolated that the problem is in fact the handset itself, not the base unit. I eliminated a problem with the base unit by a) registering a different DECT phone to it. - The base still works fine. b) Leaving the handset switched off for an hour or so (press and hold the "OK" botton to switch off / on); then whislt it was working, registering the handset to a different base (Base 2). And guess what, after 30 mins the "BASE 2" message started flashing on the faulty handset.
So, if you already have an A110 extension handset, make sure it's also registered to base 1 and maybe try to get just the handset repaired via VTECH. (or just buy a new handset if they are available).
Jun 21, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
VT 2461 Won't let me register new handset
jimmackey
were you ever able to register the additional handset? I have the same problem with 4 handsets, one broke and I bought 2 new vt2420 handsets. The unit wont register handset #3 (the one that broke). Would love to know if you were able to resolve the issue?
Oct 11, 2007 | Vtech VT 2461 Cordless Phone
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
