Question about Infinity BASSLINK Car Subwoofer
Speaker will go off intermitent
My speaker playes fine for a while then the bass goes out then comer back on what could be causing this problem
  • 65 Answers
Almost every time you have intermittent problems, they are due to a loose wire somewhere, I would say start with the basics and check every possible connection
-battery to amp
-ground to amp
-amp to sub (if possible)
-deck to amp
Posted on Oct 19, 2007
My radio cuts out when i turn it up and the bass hits on my subwoofer
You are drawing to much power to the amp. I assume that there is no dedicated power fron the battery to the amp. If there is you should look into a capacitor
Feb 13, 2013 | Car Audio & Video
My subwoofer isnt working
it is completley possible that your sub has in fact blown itself out mine has some CRAZY excursion to the point ive turned down the bass on my laptop in hopes to keep it alive so order a new sub SPEAKER if the speaker works the amps FINE
Oct 26, 2012 | Cyber Acoustics CA-3001 Computer Speakers
I have just bought Logitech Z623 Speakers and connected with my computer. All Speakers work fine upto certain Volume and Bass level but One of the satellite Speaker ( Mostly Speaker with Volume/Bass...
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
other than that you might have a warranty issue
hope this helps
Aug 08, 2011 | Logitech Z623
Twin Genius speakers model SP-K10 now carrying sound of intermitent machine gun fire on one speaker and deep bass humming on the second speaker. This is new - what can be the cause?
Could be interference from another electrical device or a loose connection. Or you forgot that you were watching Saving Private Ryan.
Turn off the movie, and then try moving them away from anything electrical; TV, monitor, PC mainly. Cordless phones can do it as well.
Jul 25, 2011 | Genius SP-K10 Computer Speakers
I've got a 1999 ford expedition with the Mach radio system in it and it does not have any bass playing thru the front or back speakers and i've changed out the factory amp thats in the back where the sub...
does the new amp you have have a hpf setting if so check to see if thats on, turn off the x-over so it will play both lpf and hpf, bass and treble. are all the speakers wired to the amp aswell, this is the only thing that would stop bass other than the head units settings.
Jun 21, 2010 | 1998 Ford Expedition
Main Bass speaker not working!!
Hello Adam Hi, it looks like your main IC amplifier inside the main bass box is bad, need to replace that IC. What are your plans, do you want to do the repair or have it service by a tech guy.
May 06, 2010 | Bose Companion 3 Computer Speakers
Bass speaker moving in out more then normal
If you can't hear the difference maybe the bass frequency which is moving the speakers is below your hearing range.
I think you may have a "loudness" button on that amp -- if you do, turn off the loudness -- this is a bass booster.
But, in general, bass speakers are designed to move in & out a lot. They have to move a lot of air to produce the bass sound.
May 09, 2009 | B&W ASW1000 Speaker
Noise from speakers when playing basses
Offhand, could either be the subwoofer speaker itself or the electronics (amp and/or crossover). One way to determine is by physcially checking the sub speaker. When playing with bass on, pls try restricting speaker movement by pressing on it and see if the noise is reduced. Another is to temporarily replace the speaker. You can try speakers meant for the car, home entertainment or book shelf, just dont set the volume too high.
If the speakers are ruled out, then it would be the electronics inside. For this, you would need familiairty with electronic components and circuittry, a DVM and a soldering iron. Access to an oscilloscope and an audio signal generator would be nice but not a necessity. The idea is to inject a constant audio signal and determine where the noise (if electronic) is coming from. In most instances, it would be a leaky electrolytic capacitor either in the input stage or feedback loop. At other times, it would be also a capacitor in the band pass filter.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 28, 2008 | Audio Players & Recorders
hello, check and see if cabinet has loose screws or if back panel is tight,bass can vibrate screw loose.good luck! also look for anything caught in the woofer causing the noise.
Fuzzy Speakers
Suggest that the speaker cone is damaged
Nov 15, 2006 | Dell A525 Computer Speakers
Open Questions:
See all Infinity BASSLINK Car Subwoofer Questions
Infinity BASSLINK Car Subwoofer Logo
204 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
