Question about Maytag Washing Machines
Maytag MAV5000 washer, water filling does not stop, small tube in back is hooked up.
Water filling does not stop. the small tube hose is hooked up.
  • goldenrulero May 22, 2009
    I won't be able to check tonight but thank you so much for the information, expecially the idea of unclogging before replacing! Awesome help!
  • Maytag Master
  • 3,361 Answers
Remove the small tube from the water level switch and blow through it to clear any clog in the air dome on the side of the tub.
Remove the small tube from the air dome and blow through it into the water level switch to reset it.
Then set the machine for spin and run spin cycle for 1 minute. Then try your fill again. If it does not work this time, replace the water level switch.
Posted on May 21, 2009
Water will not stop filling up the tube
IF YOU MEAN YOUR TUB WON T QUIT FILLING THE WATER LEVEL SWITCH HAS A TUBE ON IT ITS IN THE CONTROL PANEL THE SMALL HOSE IS PROBABLY OFF THE SWITCH AND IT CANNOT TELL THE TUB IS FULL
Jun 19, 2014 | Frigidaire FWS1339A Top Load Washer
Replace water inlet valve now the water keeps filling with water
Did you hook up all the wires correctly ? Ck to see if washers are installed in the hose ends, and hose clamps are snug. Reset load size to small and try again.
Apr 22, 2014 | Maytag Neptune MAH5500B Front Load Washer
Maytag Performa washer overflows when filling on any size load. Will stop when I push in the timer knob.
Overflow is usually caused by a "stuck-open" fill valve, with the cold water half of the valve 'sticking' open from sediment buildup inside the valve.
This can also be caused by the fill system control components: pressure switch, pressure tube, or pressure tube dome/port. So let's take a look at these.
First of all, determine whether your overflow condition is mechanical or electrical. Start the washer filling, then turn the timer off by pushing the knob in. If the fill continues, pull the washer plug. If filling continues with the washer unplugged, you have a mechanical problem - nearly always a stuck valve ***'y. Replace the fill valve.
If however, the fill stops when you unplug the machine, you are looking at an electrical fill control problem, and it gets a little more complicated.
Here a small piece of rubber or plastic tubing is handy. Unplug the washer and open the console where you'll see the pressure switch. This is the switch with a small rubber tube, usually clear, sometimes black, attached. Pull this tube off and replace it with your short tubing. Blow a bit of pressure into the switch using your mouth, and listen for a click, then another when you release the pressure. Hear two clicks? Good! The switch is probably OK
Plug the washer back in (being aware that components in the console are now 'hot' - live electric, use extreme caution , u can be SHOCKED), and start the washer filling again. With it filling, again blow a bit of pressure into the switch. If the switch is good, the fill should stop and the machine should start to agitate.
This verifies that the pressure switch is working, and causes us to suspect the pressure tubing or a clogged port/dome to which it connects. Wipe off the end of the original tube you removed from the switch, and blow into it. You're blowing air down into the tank now, and you should feel very little restriction. If it is very hard or impossible to blow through this tube, the tank dome or port is clogged.
Really old Maytags were known for this, and if you have one, spin out all water, remove the 'Corbin' clamp from the pressure tube outside of the tank and pull the tube off. (Pull washer front off - 2 Phillips screws at bottom, then two 3/8 in. hex screws release top, which swings upward) You will probably see 'gunk' clogging both the rubber tubing and the 'spud' that is a part of the tank. The hose ***'y can be taken to a sink and flushed clean with hot water, and an old toothbrush used to clear the tank spud, which, in the Maytags, is about 3/4 in. ID.
Very important: WHENEVER THE PRESSURE TUBE IS REMOVED, BEFORE REINSTALLING IT, BE SURE ALL WATER HAS BEEN SPUN OUT OF THE WASHER! Otherwise, the water fill level will be incorrect and you'll be back in trouble.
May 25, 2011 | Maytag PAV2300 Top Load Washer
I have an auto sensing load whirlpool washer, WTW57ESVW1 it won't stop filling with water. The water just keeps on running in the tub, it won't agitate but it will spin out when I turn the knob to...
this could be caused by a plugged water level sensor tube, or a bad water level sensor. if you remove the back panel of the washer you will see a small tube that is attached to the outer drum and this tube runs down to a small sensor. disconnect the tube and makes sure that it is clean and clear,, if it looks clear --check real quick to see if the wires are secure to the sensor and if all looks ok then assume that the sensor is bad,,, remove the sensor ( label the wires ) and take it down to your local appliance repair shop and buy a new one ( when you go down to the repair shop - make sure you write down the make,model and serial number of the machine -- this might save some time and confusion ). install the new sensore and replace the back panel,, re hook up hoses and start and test the machine,,,,, should be running great now.
c...
Feb 02, 2011 | Whirlpool Washing Machines
Our unit is hooked up to a hose drain had has been
proably trash in your diverter (the thing that allows water to run to tank, or hose) try a pipe cleaner or blow with air, is it electronically controlled? or is there a valve?
Apr 03, 2010 | Dehumidifiers
Water is over filling the tub, and spilling all over the laudry room floor.
this sounds like a ge ? if so you need to remove front cover between the top and the front cover you will see a small gap on both sides you will have to put a putty knife in about 2" from the ends and push in
once removed on the left side of tube you will find a small rudder hose pull the hose of clean in side of hose with small screw driver also fill washer with water with hose of untill water leavel is to the center of the box now use a turky baster to force air in to tub by placeing baster over the stem wher the hose was force air in to tub fill washer a lititle more untill water shots out of stem stop washer and drain all the water out cut about 1"off hose reinstall stop useing liqid soap
Jan 30, 2010 | Washing Machines
Washer is filling too much and water is coming out overflow
you need to clean the pressure swith hose on the lft side of tub small rubber hose stop use in liqid soap
Jan 30, 2010 | GE Washing Machines
Water keeps filling up washer
u have a bad water valve. thats the plastic piece behind the washer that the hoses hook upto. part roughly 39.99-89.99 labor 75-125.00 depending on were u live and who u use. if you decide to do it yourself i would say a 5 on a scale of 1-10 . turn water supply off, remove both hose.turn off power remove top panel 2screws in back and push panel back and off. remo 2 screws that hold water valve in place. remove wires from pld valve too new one. reassemble . hope this helps.
Oct 07, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
213 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
