Question about Sewing Machines
My foot pedal fell apart and a diagram would be nice to reassemble it
The foot pedal for do-all aerial assault trap thrower fell apart while I was using it . Is there a diagram that I may look at to see if I lost any parts and if I am reassembling it properly.
  • 25 Answers
SOURCE: can't reassemble the shuttle/hook
Turn the hand wheel until the hook race is in the left position..replace the hook to right side...replace the hook race cover..smooth end to the bottom..and snap back the hook retaining arms...now ready for inserting bobbin case...Good Luck
Posted on Jun 02, 2009
  • 68 Answers
SOURCE: Pfaff 2020 Foot Pedal--taken apart; need help putting back tog.
Are you able to post a picture of what pieces you have? The contact board may not be pressed down all the way or the contact itself may be bent. You should be able to purchase both pieces if needed from a pfaff dealer.
Posted on Feb 25, 2010
  • 68 Answers
SOURCE: White 1600 SpeedyLock. Power, but foot pedal
When stepping on the foot control, does the motor hum or anything? Or is dead silent? If it sounds like it's trying to do something, the serger probably needs to be serviced. If it's silent, you probably need a new foot control.
Testimonial: "No sound. I ordered a new foot control. Thank you. "
  • 1788 Answers
SOURCE: mine is apart around the bobbin case - do I oil
Your manual show tell you where to oil and where not to. If you do not have your manual, I suggest going to www.sewingmanualsonline.com and download a copy for $10. It is well worth it and you have a permanent copy.
Posted on Sep 21, 2010
SOURCE: lost foot pedal and electric cord need to replace
try sewingpartsonline.com
Posted on Nov 30, 2010
Can I get a wiring diagram for a foot pedal 4C-316 B?
foot pedals are basically a variable resistor and if it is not working the problem may be in the wiring to the pedal. If it is sealed unit containing a transistorised control the a replacement unit will be the best idea.. Take the control to a machine mechanic and have it tested .
Feb 10, 2015 | Sewing Machines
How fix singer foot control fuse broken lots little discs fell out of control
You didn't specify a model, but foot pedals are generally used by a wide variety of models of machines. Go to eBay and enter your machine's model number, and you'll probably see foot pedals for your model of machine for sale.
Aug 11, 2014 | Singer Sewing Machines
Assembly instructions for Singer Merritt 4525
The service manual for that machine can probably show you, and I would make sure and get the parts list as well. I just checked Sewing Parts Online, and it was not listed, but if you send an email to them (they give the address at the top of the page), they can and will purchase it for you. Usually takes about 2 weeks. However, I just saw a used one in nice shape on eBay for $72.99 and $27 shipping in the original box, so you might consider just buying another one. I also noticed that a new tension assembly is being sold for $18.95 including shipping, and if you write to them, they may include replacement instructions. Just do a search on Singer 4525 on ebay--they have all kinds of bobbins, foot pedals, and parts for it.
Jul 09, 2014 | Singer Sewing Machines
Mechanism that snaps the presser foot on and off fell apart, need a diagram to show how to put the little black plastic part back on and where the black spring that fell out goes
Assuming you have all the parts, the spring goes inside the little hole in the back of the mechanism.
You then position the lever behind it, line it up with the bar that holds the lever, and put the lever pin back in.
This is very tedious, and can be frustrating. You might consider paying for a new one.
Apr 10, 2013 | Dual Sew 3400 Mechanical Sewing Machine
The foot pedal on my Singer Inspiration is stuck on fast speed.
Hi lawoffice474...
Unplug your foot pad from the machine and the electrical receptical.
Try moving the foot pedal with your hands, back and forth as if you were pressing your foot on it.
Did it loosen up?
If yes then you still need some maintenance...
If no then you still need some maintenance.
Disassemble the foot pedal and take as many pictures as you need to be able to reassemble it.
Once you have disassembled then you will look to oil (one drop max) the pivot points of the foot pedal, like the hinge assembly, reostat linkage,etc.
Once you have it oiled then try moving the foot pedal again my hand before reassembly.
If everything moves ok then your good to go...
Reassemble the foot control.
If not then its time to replace it with another foot pedal such as one of these at this webpage below:
Please take time to rate me thumbs up.
http://www.sewingmachinesplus.com/singer-foot-controls.php
Sep 10, 2011 | Singer Inspiration 4206
Took my foot pedal apart, now it wont work at all, just makes a clicking sound when trying to put my foot down on it..
Hello
Unplug the machine plug and wall plug on the sewing machine.
Check the power cord for cracks, burns, or faulty contacts as this could be a possible reason for the foot control not working.
Open the foot control by using a knife or flat surface tool, such as a flathead screwdriver, to pry open the corner of the foot control.
Check the wires to see if they are disconnected; this can happen if the foot control drops to the ground. To check wires, remove the circuit board using a flat knife. Inspect the wires inside the foot control. You will see some wires that are soldered together. Check to see if there are any broken wires, as this could be the problem. If the wire is broken, clean the area to remove any debris or dirt. Remove a small amount of the insulation before soldering. Solder wires together.
When you are done, reassemble the foot control and make sure it's working again.
Jul 12, 2011 | PfaFF Creative 7570
Feb 24, 2010 | PfaFF Tiptronic 2040
White 1600 SpeedyLock. Power, but foot pedal won't engage. Took foot pedal apart, mechanically looks fine-- computer board in there. Do I need a new foot pedal?
Feb 22, 2010 | White Sewing Speedylock 1600 Mechanical...
Sewing Machines Logo
14 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
