Question about Maytag Ovens
Oven door springs
R eplace spring no. 7803p058-60
  • 641 Answers
SOURCE: oven door does not close
Remove the side panel and you will have an access to it. Good luck !!
Posted on Jun 05, 2006
SOURCE: How do get access to the door hinge of my Maytag CWE4800ACB oven
In first, excuse my poor english if i make some mistake.
I hare repair the same problem. part broken in left side and the door fall.
You have to pull out the oven from the wall, use some objet to support the oven,small table or plastic box if you dont want to put down completely.
You have to unsecure the electric wire connection in back if you whant to pull out enough for remove the left cover. You have to remove some parts in front for acces to screws on the side cabinet.
In my case the hinge was broken, i have soldered and fix again.
If hard to replace the spring in the mecanism, you better to do this on the bench before put all in the side of the oven.
I think the maytag oven have the same problem.
Other problem also is the timer alarm sound in the night went you sleeping, prob whit switch sensitif pc board. Now i turn off the breaker in the back of oven all night, and i sleep good.
Bye..
Posted on Jun 03, 2009
SOURCE: Multiple replacement of Microwave door springs
KitchenAid Architect Series KEBC107KSS Electric Single Oven problem error F1E7
Posted on Sep 30, 2009
rmrcompany
  • 3 Answers
SOURCE: The door on my Okeefe and Merritt antique stove
O'Keefe and Merritt is always a challenge to the inexperienced because, although two stoves of the same year and model can look identical, there are subtle differences in both, especially in the door spring mechanism, that make it difficult to explain without seeing the stove and/or asking you a series of questions in person. Here it goes anyway: Some models have access panels that are visible when you pull out the broiler drawer. This makes changing a spring a breeze, as long as you know which spring you need. A sample of a broken one, or and intact one always helps when buying a replacement. Other models operate on a system of hooks, cables and springs. These often require a skilled technician to come out and repar for you. Most of the time, the door has to be physically removed from the frame so that new cables (and sometimes rods) can be installed on the hinge and then the door would have to be re-installed fishing the cables through a small opening on the bottom of the stove. A spring then attaches to the cable and the hook of the spring is then attached to one of three small aligned holes on the bottom stove panel.
One constant i s that there are 2 sets of springs for each of the door panels. You are right, there are springs in the middle. And you are also right that the white panel removes from the door after you remove the truss head sheet metal screws.
You might want to give me a call and chat about this further at RMR Company, Inc (RMR Stove Company) 619-231-2808
Posted on Dec 11, 2009
SOURCE: Oven Door will not close properly
Don't buy Bosh. This is a common problem with them and they are not interested in a fix (ie a thinner door seal would help or adjustment to springs...
Posted on Jan 01, 2010
Oven door springs won't close door properly
get an engineer to change the springs for you.
Dec 15, 2011 | Ovens
I have taken the door off the oven but how do I get the hinge into the oven section with spring loaded so tight?
When you say the spring is loaded tight I assume that you mean that the bracket is hard against the oven door. The brackets/arms have to point away from the door so they click into the oven. Normally when you pull the bracket down and away from the door you put tension on the spring. Once the bracket travels more that 180 degrees, probably to about 200 degrees the bracket won't normally spring back and should stay there by itself.
Feb 13, 2011 | Ovens
Unable to remove oven door for cleaning
Click on the link below to watch a video that explains how to remove the oven door on most modern ovens.
Jan 10, 2011 | Ovens
How to remove door on stoves EL716 toop oven
I can only say for the 720. You have to remove the whole oven from the kitchen furniture and then unscrew/remove the top and side panels. You will then see the springs on either side of the door.
Important. Remove the inner glass panel from the door first, before you release the springs.
To remove the springs, ensure the door is closed and then unhook them. You then should be able to remove the door frame.
May 07, 2010 | Stoves 720EF Electric Double Oven
Oven door won't close completely
You will probably have to replace the springs I doubt if they can ve fixed. you can open the door all the way and you will see a hole in the spring just inside the door. you can stick a nail in that hole, both springs that will hold the door open and you can lift the door out and check the springs I will tell you to have patience its not easy.
Apr 21, 2010 | Kenmore 47702 / 47704 / 47709 Electric...
Need a new main oven door spring
You can get a new spring from Airedale Springs Telephone - 0845 4754201
Apr 20, 2010 | Ovens
We have a 30 in prostyle electric double wall oven - the oven takes forever to preheat and the doors do not seal tightly when they are closed.
Hello- Many ovens use spring-loaded hinges to carry the weight of the door. Over time, these springs weaken or the hinge gets bent just enough to not fully close door. The door gasket can also become flat and stiff, compounding problem. Any small gap releases heated air, and oven will not heat up properly. Replacing the door springs should solve problem.- Thanks -Ed
Mar 14, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
The lower door does not close firmly. It seems like the spring load is weak. Is there a way to improve the spring tension? I have model CM302ZS (Microwave/convection oven on top and convection oven on...
There is no provision made for adjustment of springs,
I'm afraid the only solution is to replace both door springs.
Trust this helps solve your priblem.
Dec 21, 2009 | Thermador SC302T Electric Double Oven
Moffatt double oven 4175 lower oven door springs broken
My problem was not with an Amana single oven but aMoffatt double oven ! However I have now decided to buy new.
Oct 31, 2009 | Amana AEW3530DD Electric Single Oven
Feb 11, 2008 | Ovens
Ovens Logo
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Mack Baxter
ashburton
Are you a Maytag Oven Expert? Answer questions, earn points and help others
