Question about Eclipse AVN5500 Car DVD Player
NOT POWERING UP.
I PURCHASED IT OFF THE NET AS IS WITH NO POWER WIRE, I NOW HAVE THE POWER WIRE AND FINALLY WENT TO GET IT INSTALLED THEY SAID THE UNIT HAS TROUBLE WITH POWERING UP.I NEED A BIG HELP WITH THIS MATTER,I'LL APPRECIATE YOUR RESPONSE.
    President:
  • Eclipse Master
  • 1,114 Answers
This unit is equipped with ESIV which is an electronic security system that is coded by any cd of the users choice. If the ESIV was on when the unit was un-installed from wherever it was, it will not work. find the units serial #, call Eclipse, IF it has Not been reported stolen, you can get the code reset by Eclipse. I think they charge for this service, however it's worth it. If there is a problem with the unit, it can be repaired by them as well. Most car deck repairs are under $ 150 unless it's really serious. Best of luck! Hope this helps
Posted on May 22, 2009
I bought my stereo of some guy on net but it never turn on ...i dont know wats the is problem
Posted on Aug 08, 2009
When powering on my Samsung 55 inches LED TV, the middle/bottom light panel just flash/blink and there is no picture on the TV screen dark/black screen. I would have to let the TV on for 1-2 hours to
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Feb 06, 2015 | Samsung Televison & Video
Battery hookup
It seems the radio is your problem! On the car you have, the ignition wire on radio (mostly red) is draining the battery! The power bleeds through, even with car off! you may have to have a relay installed, to stop the drain on the battery or a on/off switch. also make sure the dimmer wire is used or not, this can also cause drain on lights! if not really needed disconnect! hope this solves your problem, good luck!
Jun 12, 2017 | Soundstream Car Audio & Video
Will not power off
reset the unit,if the problem persists,contact your infocus dealer
May 28, 2010 | InFocus IN24 Multimedia Projector
Remote car starter will not start car
It sounds to me like you're missing a wire. There should be a wire leading to this that sends power to the distributor. If you don't have power to the distributor it won't fire it will just continue to crank over.
Nov 09, 2009 | GMC Jimmy Cars & Trucks
My car amp kills my car battery
It should not have affected anything unless the amp gets too hot due to being bridged or the ground and a power source touched each other which would have sparked and put the some amps in protection mode unless it has a fuseable link then it will blow the fuse such as the 12v battery or the power on wire which is blue and is called the (remote wire).
When adding (Amplified Powered Equipment) to your car you have to in most cases:
  1. What kind of sub and amp do you have?
  2. Make sure that your battery terminals are tighten.
  3. Depending on the size battery thats already in your vehicle you will need to Upgrade your battery size with about 800 Cranking Amps or add a Capacitor depending on the wattage of the amp
  4. Alternators are a big issue as well due to amp outputs in your case it shouldn't unless your light is slightly visible on the dash.
May 30, 2009 | Alpine Car Audio & Video
Equipment not turning on!???
Have you tried checking the remote wire yet? Because it could very possibly be that. Without a remote wire hooked up, you cannot get any power. Try that and see if it works.
Apr 29, 2009 | Alpine MRP-M500 Car Audio Amplifier
Another "No Audio output device is installed"
Actually the problem that you have is the power management. Go into Control panel then the power settings. Make sure to turn off system standby. The reason that it is not installed after it comes from sleep is that it is not reenabling. THe computer turns off the component during sleep.
Feb 06, 2009 | Microsoft Windows Vista Ultimate Edition
Eclipse AVN5500 Car DVD Player Logo
271 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
