Question about Samsung Televison & Video
Samsung ht 4500
Dont load srt file
Bass treble on Samsung ht-tx72
Follow the link to the instruction manual. It is a pdf file so give it time to load. https://content.abt.com/documents/27920/HTTX75_om.pdf
Jul 20, 2016 | Samsung HT-TX72 Theater System
Add subtitles to a dell webcam video
If you convert it to a .MKV you can create a subrip format .srt files using notepad and then merge it into the video using MKVtoolnix. It is probably a .mpg file like my Samsung and Canon cameras so MKVtoolnix can load it and out put it into a .mkv format container without recoding it since .MKV supports that codec. You can the .srt during conversion on in a second step. I would recommend using two step to avoid or correct any errors since you are unlikely to syncronize everything correct the first time.
You can see samples of the structure of the .srt text files at the wikipedia page at "http://en.wikipedia.org/wiki/SubRip". It is a very simple format and it's a text file not binary so it's easy to create your own from scratch.
Mar 26, 2014 | Dell Computers & Internet
I have downloaded an srt file but computer cannot open it
srt file is subtitle for video and played with a movie. You can open and view an .srt file with a subtitle editor program like Subtitle Creator or open via webbrowser.
Jun 13, 2011 | Computers & Internet
HT-A100T upgrade so it can support greek subtitles
incorporate srt file (ansi only) with AVIAddXSub and you will be able to watch avi with greek subs
Nov 17, 2010 | Samsung HT-A100T Theater System
Hi, how to enable subtitles for DivX movies from USB on LG 42LE5500? I connect USB, TV recognizes folder where DivX .avi file is but within same folder it does not "see" .srt subtitle. Also, in settings...
It seems that subtitle file must have exactly same name as movie file. For example: Movie file: Mission impossible.avi Subtitle file: Mission impossible.srt or Mission impossible.sub or Movie file: Mission_impossible.avi Subtitle file: Mission_impossible.srt
Aug 14, 2010 | LG 42LE5500 42 in. TV
NEED TO UPGRADE MY HT-BD2 SYSTEM
There are two ways to approach this. You can either download the update from Samsung's support page, burn it onto a CD, place the CD into your Blu-Ray player and let the update load...or you can connect your Blu-Ray player to the internet and let the player download and install the update automatically.
For the first approach, the upgrade file can be downloaded by clicking on the following link:
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=us&CttFileID=2149020&CDCttType=FM&ModelType=N&ModelName=HT-BD2&VPath=FM/200903/20090318095607437/081227_01_HT_BD2_XAA.zip
...and the instructions to installing the file on your system can be found here:
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=us&CttFileID=2149021&CDCttType=FM&ModelType=C&ModelName=HT-BD2&VPath=FM/200901/20090109105847140/HT-BD2_System_Upgrade_by_CD_Method.pdf
The second approach is detailed in the HT-BD2 User's Manual (pages 46-49). It requires you to first plug a network cable into the back of your Blu-Ray home theater unit, then connect the other end into a LAN connection on your wall (or into the back of your cable/DSL modem) Page 26 of the user's manual shows you how to make the connection.
Apr 05, 2009 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Samsung ht-tz315 subtitle character problem
Hi Old man
You're going to be in trouble. Beware.
Apr 10, 2017 | GoVideo Go Video DVD/VCR Combo
How i can view divx whit subtitles (.srt, .sub.ssa)?
Look for firmware upgrades in Samsung's website.
You have to download a set of files, burn them on to a CD or DVD (check the help file in the download) and then insert the CD or DVD to your DVD Player and follow the on-screen instructions. It is really simple, just make sure you download the correct upgrade from the website. And one advice, use a RW DVD or RW CD because you may have to try it many times ;) .
Nov 10, 2007 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Divx greek subtitles
look in the menu and try to change the encoding, There should be 3 options, Unicode, Cyrilic & Greek. Select greek if the .sub or .srt file is in ANSI encoding, or select Unicode if the file is in UTF-8 or Unicode encoding.
To find out the encoding of an .srt file the simpliest thing to do is open them with notepad and got to "File" -> "Save as", The encoding should appear in the bottom of the dialog.
Oct 25, 2007 | Samsung HT-Q100 System
it is quite easy to play those anoying subtitles first name the same way both files (video file and subtitle file) example movie.avi movie.srt be sure that both files are in the same folder second: insert the cd/dvd in the yht-630 when the menu appears select the subtitle file using the arrow keys and press the "subtitle" key after this at the screen you will see -> subtitle selected finally select the file that contains the movie (again arrow keys) and press "ok" or "play " key the movie will start and the subtitles will appear. it functions with sub and srt files
Jan 25, 2006 | Yahoo YHT-630 System
Televison & Video Logo
13 people viewed this question
Jerry Greenberg
Jerry Greenberg
