Question about Braun KSM2-WH Electric Grinder
How to clean Braun Coffee Grinder Burr Grinder 4045 KMM20
4 Suggested Answers
  • 670 Answers
SOURCE: I cannot find a user manual for my Braun 4045
I dug in and found your manual at Braun. Take this link and select the second choice to print your 9 page manual. Let me know if further assistance is needed.
http://www.service.braun.com/product/search.asp?rg=NA&c=US&l=GB&typ=ui&frmTyp=s&sgrp=s&grp=HH01%3C%7C%3E&s=kmm30&subgrp=0
Posted on Oct 11, 2009
SOURCE: Where can I get a replacement knob for a Braun
www.theessentials.com
In particular:
www.theessentials.com/jump.jsp?itemType=PRODUCT&itemID=399
You need both the knob and the spring clamp ring.
Posted on Apr 22, 2010
  • 13 Answers
SOURCE: Part for Braun 4045 coffee grinder
depends if ur DIY (do it yourself)type or u know someone who are..or last solution is to order from factory..
Posted on Sep 12, 2012
My Breville BDC600XL grinder appears to be clogged and would put ground coffee into the basket. The grinder also slows almost to a stop. How do I fix it?
if this isa bed-bath and beyond unit?! take it bak!. and try the Braun coffee grinder. I hav had mine for 10 years and nevr a problem.
Dec 31, 2014 | Breville Bdc600xl YouBrew Drip Coffee...
Sep 12, 2012 | Braun Coffee Makers & Espresso Machines
How do I clean the inside of the coffee grinder kitchenaid model A-9
Instructions Things you need
  • Soapy water
  • Screwdriver
  • Burr cleaning brush
  • Damp cloth
1 Turn off your KitchenAid coffee grinder and unplug it from the socket.
This reduces the risk of injury while cleaning the appliance.
2 Turn the bean hopper, located at the top of the grinder, counter- clockwise and remove it from the appliance.
3 Slide the coffee bin toward you to remove it from the grinder.
4 Wash the hopper, hopper lid and the coffee bin in hot, soapy water. Rinse and dry these parts after cleaning.
5 Locate the grind control dial on the front of your KitchenAid coffee grinder. Screws are located to the left and right of this dial.
6 Turn the screws counter-clockwise with a flat head screwdriver to remove them from the grinder.
7 Pull the entire faceplate assembly gently toward you and out of the KitchenAid coffee grinder. The faceplate assembly is attached to the back of the grind control knob.
8 Pull out the burr shaft assembly, which is right behind the faceplate assembly.
9 Brush the burr shaft assembly with the burr-cleaning brush included with your KitchenAid coffee grinder to remove any debris or remaining grinds.
10 Reassemble the KitchenAid coffee grinder by returning the burr shaft assembly and faceplate assembly to the appliance. Tighten the screws with a screwdriver to hold the assemblies in place.
11 Wipe down the exterior of the coffee grinder with a damp cloth.
12 Return the clean coffee bin, hopper and hopper lid to your clean KitchenAid coffee grinder.
Aug 17, 2012 | KitchenAid Model A-9 Coffee Mill Grinder
Unit is about 6 years old . it takes loger now to grind. is there a part to replace? where to obtain and how to do it. Thanks
You can first try cleaning the burrs, but they are most likely worn and will need to be replaced.
Here is the number for Braun 1-800-816-0810
Mar 01, 2011 | Braun KMM 30 Electric Burr Grinder
Oily beans seem to have clogged our coffee grinder up. What can we do?
Rotate the bean hopper counter clockwise until it stops. Lift it off. Remove the outer burr with the 2 wings and clean under the burr. Clean the opening going to the chute for ground coffee(inside where the burr was).
Install the outer burr. Install the bean hopper. Rotate the bean hopper to the French press grind (coarsest) and operate the grinder. This will clean the burrs and the passages. If it starts to clog, repeat the last part to clean the burrs and passage. It must be grinding to go to a finer setting, but you can go to a coarser setting any time. Another thing. Turn the grinder upside down (empty) and rotate the bean hopper back and forth to clean the threads of the adjusting burr..
Dec 20, 2009 | Solis Maestro Electric Burr Grinder
My Barista Burr Coffee Grinder suddenly grinds too fine.
If it is any consolation, mine just did the same thing, now takes too long to grind and it is way to fine dispite a thorough cleaning by disassembly.
Jun 07, 2009 | Starbucks Barista Burr Grinder
Food processor
Hi there
the following should be the link to your manual
http://www.service.braun.com/line/HH/H3045/H3045_1_MN.pdf
Best wishe
Sep 12, 2008 | Braun KMM 30 Electric Burr Grinder
Braun KSM2-WH Electric Grinder Logo
104 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
