Question about HP Photosmart C6280 Printer
How to scan fromhp750
I need to know step by step how to scan, when i try to scan on the menue button it will say options not set but does not say how to set options.
    Scholar:
  • 191 Answers
Please Click here and follow the instructions to set scan options for your All-in-one.
Posted on May 23, 2009
Set stations
A channel scan is a vital part of utilizing your cable TV service. When a coaxial cable is connected to a TV, sometimes it will not display any channels until you configure the TV for your specific cable connection and scan for available channels. A channel scan can be applied to basically any type of TV or TV/VCR combo, even if you are missing its remote control.
Read more : http://www.ehow.com/how_6875646_do-old-tv_vcr-tv-remote_.html
Instructions
    • 1 Bring up the TV's menu. Look for a button on the front panel of your TV/VCR labeled "menu" or "setup." Press it and you should see a menu appear on the screen. Part of the menu should inform you what buttons you can use to navigate through the menu. If not, try using the volume buttons or channel buttons on the front of the TV and see if pressing those allows you to navigate through the menu.
    • 2 Specify channel scan settings. Once you are able to navigate through the TV's menu, look for the "channel scan" "auto-program," or "auto-tune" option. This may be inside one of the TV's sub-menus such as "setup," "channel setup," or the like. The key of this step is to specify your cable settings before running your channel scan. The "tuner mode" option needs to be set to "cable" rather than "air" or "antenna." You may have to specify what cable type to use, this will be set to "std" or "standard" for the vast majority of cable providers. If you are not certain what cable type you use at home, contact the technical support department of your cable provider.
    • 3 Run a channel scan. Once the scan settings have been set properly, run the scan (usually done by pressing a "start," "scan" or "begin" button.) When the scan is complete, check to see if you are getting all of your channels. Contact your cable provider if you are not sure how many channels you are supposed to be getting.
good luck
Jan 08, 2015 | Televison & Video
How to scan more than 1 page at a time
ADF : Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first. Adjust the width guides to fit the item. Open HP Solution Center with one of the following methods:
  1. Click Start , click All Programs , click the HP folder, and then click HP Solution Center
  • Double-click the HP Solution Center icon on your desktop. A "Scanning from..." screen displays to prompt for scan settings. If this settings screen does not display before the scan starts, a preference was set to bypass the prompt. To adjust settings, follow these steps to turn the prompt back on:
    1. Cancel the scan, return to the home screen of HP Solution Center, and then click the Settings option.
    2. Click Scan Settings , and then click the appropriate option from the popup menu: Scan Picture Settings or Scan Document Settings .
    3. Select the check box, Prompt for settings at the time of scan , and then click OK .
    4. Click Home , and then start the scan again.On the "Scanning from..." screen, click the appropriate option under "Scan Shortcuts" on the left. Each shortcut has a default group of settings that display when you click it.
  • Click Change Settings , and then read through the drop-down menu choices for all of the settings for the shortcut, adjusting any settings as necessary. Also click the Advanced Picture Settings button and the Save to file Save Options button to view your choices and make any changes. Important : HP Solution Center versions and options vary, depending on your printer. For specific instructions on all the settings the software offers, click the Help button on the home screen or settings screens in HP Solution Center.
  • Click Scan . The preview screen might display, if you selected the option to show a preview. Use the options on the preview screen to make any desired adjustments before you finish the scan.
  • After the scan completes, it goes to the destination that you specified in the settings.
  • Scan Button: HP recommends that you first get comfortable with using the "Scan Picture" and "Scan Document" on-screen "buttons" in HP Solution Center as explained in the previous steps. By doing this, you determine the scan settings that you use most often, and then you can more easily set up the scan button on your printer. Important: Before you use the scan button on your printer, use HP Solution Center to create the settings for that button . For example, you need to decide whether you want a settings prompt screen and a scan preview for each scan. Also, you must create the list of "shortcuts" that you want to display on the front panel of the printer. To get started, click Settings , click Scan Settings , click Button Settings , and then click the tab for Front Panel Scan Buttons . Read through the options, and then create the settings that you want. NOTE: The steps to set up the scan button on your printer can vary depending on your printer model, and the version of software that is installed. For specific instructions, click the Help button on the home screen or settings screens in HP Solution Center.
    Dec 04, 2010 | HP Officejet 6310 All-In-One InkJet...
    Had been scanning pictures into computer and now i
    First let us remove the No Scan Option.
    First try to Scan from HP director or HP Solution Center.
    If it is scanning, perform the steps given below to resolve the issue.
    Open HP solution center/HP Director:
    Click on settings:
    select scan settings from settings.:
    A Menu Appears.
    select scan to setup:
    a new page will appear:
    you will see all options on the left side:
    select all the options manually and click on the right arrow
    to move all the options from left to right side.
    after perfoming these steps.
    Restart the printer:
    and try scanning from printer now.
    now will be able to scan from printer itself.
    Jun 02, 2010 | HP Photosmart 3210 All-In-One InkJet...
    J4580 OfficeJet All In One Printer Laser: the printers scanner is not working and when i pre...
    Just check that can you scan from HP Solution Center, if yes. Then perform the steps given below to resolve the issue.
    Open HP solution center:
    CLick on settings:
    A Menu Appears.
    May 18, 2010 | HP OfficeJet J4580 All-In-One Laser...
    My local time says 0146 on my ipod and i cint change the time
    1. Step 1 Turn on the iPod or access the main menu. Scan down the menu listings for "Settings." Use the click wheel to highlight "Settings." This will pull up a side-bar menu of options for the iPod.
    2. Step 2 Pick "Date & Time" from the list of options on the side-bar menu. Once again you will be given a list of options. Highlight "Set Date & Time" using the click wheel and then select it using the center button.
    3. Step 3 Use the click wheel to change the current minutes setting. When you are finished, press the center button to move on to the hours setting.
    4. Step 4 Use the click wheel to change the current hours setting. As before, use the center button when you are finished. You have set the time on your iPod.
    May 03, 2010 | Apple iPod MA446LL/A MP3 Player
    I only get 2 choices in the scan menu what happened to the rest
    Hi
    As you have not provided me the O.S information I would still like to perform few basic troubleshooting steps.
    Step 1:
    Populate the Destination List with following steps:
    a. Open the HP Solution Center.
    b. Click on Settings --> Scan Settings --> Button Settings.
    c. In the window opened, select "Scan to button" tab
    d. Click the Destination List tab.
    e. Click on each of the programs you want to appear in the scan to list.
    f. Click the Add button. This moves the selected programs to the Front Panel Destination List.
    g. Click OK.
    h. Now try the scan to function from the all-in-one.
    To save the above changes I request you to perform steps given below as Dest test.
    Step 2: Perform the dest test:
    1. Close all applications including HP Solution Center.
    2. Open and run the DESTTEST file from the location:
    C:\Programfiles\hp\digitalimaging\bin\Under Destination:
    a. (Optional) Set the Category for the Destination List scroll
    down menu on WEB_APP.
    2. On the 5th option "Close Dest Test After sending to Destination", put a check mark and click on Save Results Before Exit.
    3. Click on Exit in the bottom.
    4. Now Open the HP Solution center, Click on Settings -> Scan Settings & Preferences -> Scan To Setup.
    5. You will see all Button settings on the right side under the front panel destination List. In Case If not, click on Restore Defaults, click on Apply and click on Ok.
    6. Push Scan To button on the unit you will see all the Destination List on the unit. Select the appropriate one.
    For pictorial representation on these steps, please visit below URL:
    http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&docname=c00280633
    Yours,
    Roger
    Oct 03, 2009 | HP Photosmart C5180 All-In-One InkJet...
    I am unable to send faxes or recieve faxes
    Please follow the steps given below to check wheather the error correction is turned off.
    You need to disable "Error Correction," please follow the steps given below:
    1. Press "Fax Mode."
    2. Press "Menu."
    3. Press "Up" or "Down" Arrow button repeatedly until "Ringing and Answering" is highlighted.
    4. Press "Select."
    5. Press "Up" or "Down" Arrow button repeatedly "Error Correction" is highlighted.
    6. Press "Right arrow" or "Left arrow" button until "OFF" appears.
    7. Press "Select."
    Please follow the steps given below to recieve the fax:
    1. From the control panel, press "Fax Mode."
    2. Press the "Menu" button once.
    3. Press up or down arrow repeatedly until "Ringing and Answering" is highlighted.
    4. Press "Select."
    5. Press up or down arrow repeatedly until "Pick-Up On:" is highlighted.
    6. Press left or right arrow to choose an option.
    7. Press "Select."
    If you want to set a schedule to turn "Auto Answer" "on" or "off:"
    1. Press up or down arrow repeatedly until Auto Answer Scheduling is highlighted.
    2. Press left or right arrow until "On" appears.
    3. Press "Select."
    4. Press down arrow button to select the time for "Auto Answer On."
    5. Use the keypad to enter the date and time. Press 1 for AM, 2 for PM, or 3 for 24-hour mode.
    6. Press down arrow button to select the time for "Auto Answer Off."
    7. Repeat step 5.
    8. Press "Return" button to save the settings and exit the menu.
    9. Make sure the "Fax Auto Answer" light is on.
    When the number of rings you set is detected, the printer automatically receives the incoming fax.
    To scan a document, please follow the steps given below:
    1. Go to "Start," "Programs," Lexmark printer, "Lexmark All-in-One Center."
    To see how an image will look after it is scanned, click "Preview Now."
    2. Click "Scan," "Send scanned image to."
    If scanning an image, choose a graphics program such as "Lexmark Photo Editor," "MS Paint," etc.
    If you wish to "Scan to OCR," choose a text program such as "MS Word," "WordPad," etc.
    Once the image is scanned, the "Abbyy OCR" software will open automatically.
    3. To begin the scanning process, click "Scan Now."
    4. To view the additional options, click "See More Scan Settings."
    To indicate what type of image is being scanned, select the "Option" next to the type of object you are scanning. Your settings will be optimized for that object type.
    To indicate how the scan will be used, select the relevant option from the menu. Your resolution and other settings will be optimized based on your selection.
    5. To revert back to the normal All-in-One main page, click "Hide Extra Scan Settings."
    6. Under "Display Advanced Scan Settings"; you can see change settings, which will affect the outcome of your scan.
    Mar 21, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
    MY HP PHOTOSMART DOES NOT GIVE OPTION TO SCAN TO PC
    First make sure that the software is sucessfully installed in you computer and then try the steps metioned bellow.
    Go To My computer>C:\Drive\windows>system32
    Copy hpzipm12
    minimize this window
    Right click on Start button on the computer>Explore>Programs>Startup>edit>paste
    minimize this window.
    Go back to My computer>C:\Drive\windows>system32
    Copy hpzinw12
    Now you will see two new files in Startup
    Now go to My Computer>C:\Drive\Program Files>HP>Digital Imaging>bin>
    Copy hpqtra08
    close this window
    Restart the computer
    Open Hp Solution Center> Settings>Scan settings and preferences> Scan to button>
    check destination list> if available applications are not in the destination list then add them in the front panel destination
    Tried to scan.
    Dec 21, 2008 | HP Photosmart C5280 Printer
    Won't scan legal documents properly
    Make sure that you set the paper size in the setup menu for legal - 8.5 x 14 for the manual paper feed.
    Jul 01, 2008 | Samsung CLX 3160fn All-In-One Printer
    Can not scan to computer
    hi,
    below are the steps that i want you to follow. The "NO SCAN OPTIONS" refer to the absence of options when you try to scan using the printer button your printer. However, if you are going to scan from the SOlution center installed in your computer, it will scan without any problem.
    Step two: Populate the destination list The destination list must be populated in order for the Scan To function to work. Follow these steps to populate the destination list.
    1. Open the HP Solution Center. Use one of the following methods to open the HP Solution Center.
      • On the Windows desktop, double-click the HP Solution Center icon.
      • On the taskbar, click Start , Programs , or All Programs , click HP , and then click HP Solution Center .
      If more than one HP device is installed, click the tab for the All-in-One product. The HP Solution Center shows only the functions, settings, and support options that are appropriate for the selected HP product.
    2. Click Settings .
    3. Click Scan Settings and Preferences .
    4. Click Scan to... Setup .
    5. Click the Destination List tab.
      NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after the printer or computer is turned on.
    6. If the Front Panel Destination List is empty, continue with this procedure. If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
    7. Click each program to include on the Scan To list.
    8. Click the Add arrow.
    9. Click OK .
    10. Scan a document using the Scan To button on the front panel.
    11. If the scan fails, try to scan using the HP Solution Center Scan button. If the scan still fails, please let me know.
    Thank you so much.
    adonscott
    Jun 02, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
    HP Photosmart C6280 Printer Logo
    73 people viewed this question
    Seeker5211
    Seeker5211
