Question about Whirlpool Wsf26d4exw
No water dipensing
No water dispensing
2 Suggested Answers
catriver
  • 878 Answers
SOURCE: Water Dipenser is not working
Ajay, couple of things you want to check. First thing is to check the reservoir itself. Remove the drawers on the refer side and see if the tubing is frozen up. It will be on the back side of the refer compartment. Take a hair dryer and go lightly across the plastic coils for a while and then try to dispense the water. The ice-maker line and water line are seperate. As long as you hear the water lever paddle making the switch, you should be ok there. Next would be the valve itself. You can ohm it out, check for continuity or take a cheater cord 120V. across the terminals and see if the valve operates. Be very carefull with the cheater as you are working with live voltage...Catriver..post back.
Posted on Oct 02, 2006
On my lg tromm. My softener dipenser will not work. It still has softener in it.
You may have a problem with one of the water valves not dispensing water into the softener dispenser. You will need a technician to check it out for you.
Jun 16, 2011 | Washing Machines
Ice maker dispenses ice but the water dispenser does not dipense water help!
the water line may be frozen / if so you can adjust the tempt and in 24 hr it may start working / if that does not correct problem ck the dual valve as the water side may be burned out .. mm
Jul 03, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water will not flow out of dispenser
This is common when the water filter needs to be replaced. GE recommends:
Water filter clogged. Replace filter cartridge or remove filter and install plug. Air may be trapped in the line: Press the dispenser arm for at least two minutes.
Dispenser is LOCKED. Press and hold the LOCK CONTROL pad for 3 seconds.
The water line may be turned off or disconnected.
Sep 07, 2009 | GE Refrigerators
Water dipensers drips
replace the water disp solenoid,its located at the back of the fridge where the water line connects
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a Kenmore side-by-side refrigerator and the water dipenser quit working, the ice maker works fine. Any solutions?
Check water valves on back of fridge, one is for the ice maker and other is for water dispenser. Need to get the correct and complete model number listed on front and near floor behind the fresh food door. Problem may be the water valve in back or the dispenser switch on the front. let me know and I will try to get it going for you.
Thanks, Sea Breeze
Mar 20, 2009 | Kenmore 57029 Side by Side Refrigerator
Fabric softener dispensing before wash begins
I was having the same problem. Repair man replaced VALVE AW
He told me it is from the sedement in your water. If you have a water softner, it may not be the problem, unless it is not working properly. Sounds strange, but problem is fixed.
Nov 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Fridge is leaking
Your plastic line which carries water to the dispenser has a crack in it.  Activate the dispenser and have another person pinpoint the lead and splice two pieces together with plastic connector.
Oct 15, 2007 | Amana ACD2232HR Side by Side Refrigerator
Oct 01, 2006 | Whirlpool GD2SHGX Refrigerator
Whirlpool Wsf26d4exw Logo
10 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
