Question about Lexmark Z2300 InkJet Printer
Lexmark z2300 eplacing ink cartridges
Do i have to replace both color and black ink cartridges to make it work again lost the manual to lexmark z2300 printer. don;t know how to change the ink cartridge? Pls help.
Go to www.lexmarkz2300.com. There will be instruction on how to replace the cartidges. you will b e able to print out the instructions after you fix the problem.
Posted on May 21, 2009
Computer wont recognize printer,power light flashing
The flashing of the power light indicates a problem in the cartridge/s. Try to remove your cartridges from the printer > close the printer cover > unplug and re-plug the printer into the power source to reset > when the printer turns on, reinsert one cartridge first > check the behavior of the power light. If power light does not blink, open the printer cover again and reinsert the other cartridge. Replace whichever cartridge is causing the power light to blink with a new genuine Lexmark supply.
Dec 22, 2011 | Lexmark Z2300 InkJet Printer
I just installed two refilled lexmark cartridges color and black yet printer is reading black cartridge missing and color cartridge missing. I am unable to print
Refilled cartridges become unreliable and can damage your printer - you will need to try an original Lexmark cartridge before considering replacing your printer.
Sep 05, 2011 | Lexmark Z2300 InkJet Printer
I just added a new black ink cartridge to my Lexmark z2300 and it will not recognize it. I had a problem the last time I changed the color cartridge, tried calling Lexmark with no help, and finally...
To rectify this error with your printer, first of all, you need to snap the cartridge in and out a few times. If this doesn't work, you need to remove the printer cartridge from the printer and then clean off the foil contacts. You need to be careful while doing this and do not wipe the nozzles from where the ink comes out. Insert the cartridge and switch on the printer. Now your problem might be fixed. If this does not work, it is better to inform the manufacturer or contact online technical support experts.
Jan 06, 2011 | Office Equipment & Supplies
IT WON'T PRINT DO i NEED A USB CABLE IF SO WERE DO i PLUG IT INTO ON PRINTER? THANK YOU ALSO DO i NEED A BLACK INK CARTRIDGE?
Hello Grannie,
You will need a printer USB cable to connect the printer to your computer. These cables a standard for all printers and look something like thispatzky.jpg.
You should find a square like opening on the back of the printer to connect the cable.
As for the ink cartridges, I believe lexmark only requires either a color cartridge or a black cartridge to be installed. Use one of the two and the printer should work.
Thanks,
Pat
Nov 07, 2010 | Lexmark Z2300 InkJet Printer
No black ink coming through LEX Mark Z2300
Remove the ink cartridge and check the bottom making sure all the tape has been removed. Small pieces of tape frequently tear off and block the ink flow. If this does not work clean the holes on the cartridge with a Q-Tip moistened with warm water.
Oct 01, 2010 | Lexmark Z2300 InkJet Printer
Lexmark 6170 Cartridge Error 50C How to resolve?
"Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Apr 17, 2010 | Lexmark X6170 All-In-One InkJet Printer
How to change the ink cartridges
Here's a link to download the PDF file User's Guide of your Lexmark Z2300 printer. http://bit.ly/amfEfI . Go to Maintaining the printer section to see the instructions on how to change/replace ink cartridges. It has some graphics in it to better understand the instructions. Hope this helps.
Apr 02, 2010 | Lexmark Z2300 InkJet Printer
The black cartridge is optional, so you should have to just replace the color.
Feb 24, 2009 | Lexmark X2350 All-In-One InkJet Printer
Lexmark Z2300 InkJet Printer Logo
510 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
