Asterisk as SIP Client... Unable to make outgoing calls
I am trying to register my Asterisk as a Client at a SIP providerwhich provides PSTN access so that I can dail in and out on PSTN usingSIP softphone (X-Lite). Now, I am able to register Asterisk against theSIP provider and get incoming calls on softphone too. But the problemis with outgoing calls. After dailing the PSTN number the PSTN phonerings but even after picking the PSTN phone the softphone displayscalling 0xxxxxxxxxx (PSTN number). Then finally the sip softphonedisplays ''Call Failed: Service Unavailable'' and you hear the voice ''Theperson you called is unavailable''.
The Settings in sip.conf are:
[general]
port = 5060
bindaddr = 0.0.0.0
context = others
sipdebug = no
realm = domain.com
trustrpid = yes
sendrpid = yes
register => uname@domain.com:pwd:authname@IP/46
registertimeout=20
registerattempts=10
[my_provider]
type=peer
fromuser=uname
fromdomain=domain.com
canreinvite=no
secret=pwd
insecure=very
host= ip
qualify=yes
nat=no
The configuration in extensions.conf is as follows:
exten => _0.,1,Dial(SIP/${EXTEN:1}@my_provider)
The output on Asterisk CLI is:
Executing 04045834323@tutorial:1 Dial(''SIP/alice-c0000a60'', ''SIP/4045834323@my_provider'') in new stack
— Called 4045834323@my_provider
== Everyone is busy/congested at this time (1:0/0/1)
== Auto fallthrough, channel 'SIP/alice-c0000a60' status is 'CHANUNAVAIL'
Can someone please explain where and what I am doing wrong?
Thanks.
Why Add SIP Trunking to Telephone System?
SIP trunking is cost effective, particularly when you are doing international calls, relative to general telephone technology. Enterprise Sip Trunk is Voice over Internet Protocol (VoIP) and streaming of media service is based on Session Initiation Protocol. By unifying these protocols Internet Telephony Service Providers (ITSP) deliver their services to those customers who are equipped with IP-PBX and facilities having unified communications. IP-PBX is SIP based private branch exchange. You can seamlessly stream voice, video, conferencing, etc. on this platform.
There are two domains of SIP trunking- private domain, public domain. Private domain is typically owned by a person or a firm through its server equipped with IP-PBX. Whereas public domains use PSTN. In private domain, the responsibility for everything is that of the firm or the individual, but in public the responsibility is that of the Internet service provider.
May 02, 2017 | Radio Communications
How to fix snom 300 because it cannot received calls
Is your phone connecting to a hosted PBX provider or is it connecting to a premise-based IP PBX? Incoming and outgoing calls are usually handled by two separate connections between your PBX and the service provider SIP trunk. Sounds like a registration problem with the SIP trunk. There is nothing you can do from the phone itself to fix this.
Nov 16, 2014 | Snom 300 IP Phone
3COM 3100 entry phone, how to configure SIP
From Digium Mailing List:
3Com 3100 series phones do not support SIP with non-3Com systems. They have a basic boot loader which must download code from a 3Com NBX or a 3Com VCX system. If you don't have either of these, then you won't get runtime code on the phone, thereby making it impossible to use the thing with Asterisk.
Asterisk Users 3Com Phones
Mar 14, 2014 | 3Com Computers & Internet
How can call with nimbuzz
SIP (Session Initiation Protocol) is a protocol used to establish, modify and terminate VOIP telephone calls. Using SIP, you can make cheap calls to a landline and regular mobile phones. With Nimbuzz SIP support, you can make Internet calls via the Nimbuzz Phonebook feature by adding any SIP provider you already use. Costs depend on your SIP provider rates.
SIP calling is mostly used to make cheap international calls.
You can go to Options > Settings > SIP Accounts to register an account.
After that you can place VoIP calls via the Phonebook.
User Fring if you want to make free calls. It works on Yahoo Messenger and Gtalk so you can call your buddies available on Yahoo! or Gtalk.
Apr 11, 2011 | Nokia N73 Cellular Phone
I have polycom SoindPoint 301 and i would like to use as SIP to one of the VoIP providers. I dont have asterisk in my network and i would like to connect it directly to the VoIP provider. So there is no...
1st. Get the IP address of the phone. and type that into browser.
*- default user: Polycom / password: 456
*- Under menu SIP, type in your voip provider
*-Under menu LINES type in user info and "secret" should be your password.
Make sure your ports are open (SIP is usually 5060) you can change it in that same config screen.
Mar 28, 2011 | Polycom SOUNDPOINT IP 301 SIP
Using D-Link DPH-50U with a softphone ie. Xlite,eyeBeam, etc
That phone looks exactly like the one I use from sjlabs.com. I have a SIP account with FWD on mine. The router should have nothing to do with it unless you are behind a corporate router with strict ACLs. The soft phone is software based. Just make sure your STUN server and SIP proxy is set up correctly. The Xlite should provide all the info needed,
Jan 29, 2009 | D-Link DPH-50U (0790069289750) Router
Audiocodes MP118 8 FXO early media to Freeswitch SIP extension
Hi, man.
There are many things to consider in this type of application.
when calling from PSTN to IP using analog lines from time to time you will have this type of event, I suggest working with H323 protocol, this will tone down a bit your problem.
If you want optimum performance, you should use a DID with the channels you need and address to your PBX SIP FreeSwitch. The DIDs are cheaper and are digital which eliminates random connectivity problems in the incoming call.
Once you have directed the DID you tell your server to transfer the call to the IVR using your internal dialing plan.
Lucky
Oct 06, 2008 | AudioCodes MP118 Analog Modem
Connect an avaya one-x edition to asterisk
have no clue about Asterisk. BUT, i know that Asterisk can do SIP trunks, as well as the newer releases of QE. You might be able to set up a SIP trunk between the 2.....????
Apr 26, 2008 | Avaya Lands Phones
Polycom Soundpoint IP 501 - URL call is disabled
This in it's most basic description means that the phone is unable to register with the SIP server, most likely for lack of internet connectivity or a firewall blocking the packets.
If you've verified connectivity and opened the proper ports and the phone fails to initialize and still getting “URL Call Disabled” or all of the above parameters are correct, update the firmware for the router. This can usually be done within the router configuration. Then reboot in order, the cable modem or DSL, the router or switch, then the phone. This may solve the problem.
If still having the same issue, confirm in the router configuration for settings such as SIP proxy, gateway, or application layer or any configuration setting for SIP or VOIP. If any of these do exist, make sure they are turned off as these may only confuse or adversely affect many implementations.
Jan 08, 2008 | Polycom SoundPoint IP 501 IP Phone
Computers & Internet Logo
846 people viewed this question
David Payne
David Payne
