Question about Samsung HL-T5676S Television
Black screen Power on, no picture
Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Oct 26, 2008 | Vizio Televison & Video
What's your problem? Nikon Coolpix S220 - My screen is black and takes black pictures. I can still look at old pictures that are saved to the device and see how much battery power etc, but it will
i can recommend read very well you owner manual specially the troubleshooting section. The images in the LCD monitor will darken in strong sunlight or bright light. This is a normall occurrence the devices containing CCDS, and doesnot contitute a malfunctions.
If you are using too much the flash+zoom, the batteries quicly will drain. maintian another set of batteries for replace, or better buy recharges batteries.
God bless you
Jul 31, 2012 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Had a major electric surge and now tv has no picture, but has power to it?
when on black screen, put a flashlight onto screen, if u can see picture, its the capacitors (2), 3.00 in parts, follow the power cord to the board inside, look for capacitors that are bubbled on top,
Dec 21, 2011 | Samsung Televison & Video
When tv turned on will get apicture for only a few seconds then screen goes black, but wil continue to have audio. Cannot pull up menu on tv either
Hello.The screen goes black means that the backlights of your LCD is not working.Maybe the problem is the power supply or the driver board of the backlights.They shutdown because there have a shorted parts on the circuit or power supply. Did you try to reset the power and turned on and get a picture or every time that you reset the power it will get a picture and the picture goes black?
Jul 02, 2011 | Sanyo DP19649 LCD TV
Spetroniq 42"lcd screens black no picture no
Sounds like maybe power supply, but I would check with flashlight 2 in from screen when the green light comes on to see if you have a picture, if so then you have a bad inverter board, if not then power supply problems. You can look for bad or bulged caps in PS
Jan 06, 2011 | Spectroniq PLTV-42HW68 42 in. LCD TV
Power light comes on but no picture. Black screen
if the set appears dead ecept for the power light, unplug the power cord from the back of the set, wait two minutes, then plug it back in and try to turn on the tv. Doing this worked for me.
Jan 27, 2010 | Sanyo DP42746 42 in. Plasma Television
No picture Screen black
Hi, you need to get your TV kit replaced... Please reply with the model number of your TV if you repairing it by your own.
Jul 20, 2009 | Protron Televison & Video
CAMERA TURNS OFF WHEN IN PICTURE OR VIDEO MODE
Does the camera turn off or does the screen go black? if the screen goes black but the power lamp stays green then the screen is just turned off (power save mode), If it’s just the screen to turn on the LCD. There are 3 buttons just to the right of the screen, press the center button.
May 20, 2008 | Sony Cyber-Shot DSC-P52 Digital Camera
Samsung HL-T5676S Television Logo
22 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
