Question about Python Vehicle Parts & Accessories
Alarm will not disarm - Python Vehicle Parts & Accessories
I have a 2003 GMC yukon slt xl, i need to disarm the alarm, help!!!
using the key not the remote, lock drivers door from outside, wait 20 seconds and then unlock it, that should disarm the alarm.
Sep 27, 2012 | GMC Yukon Cars & Trucks
I have a crime stoppers remote start/alarm when I use the unlock button it only unlocks the doors, it does not disarm the alarm. How do I disarm the alarm?
You need to hook up the disarm wire also and depend of what car you're working on, it will disarm when you unlock the car.
Jan 13, 2011 | 2-Way Remote Starter
Why does the alarm in my car go off when I try to start it with the remote car starter?
If this is the vehicle's factory alarm that is being triggered then your factory alarm must be disarmed prior to the remote starter sequence. The Autopage unit has a factory disarm wire available for this purpose. When the alarm triggers again try turning the key in the driver's door to see if there is a factory disarm wire available in the vehicle or if the factory alarm is RF disarm only. If it is the after market alarm that is being triggered then you made need to decrease the sensitivity.
Nov 23, 2010 | C3RS727LCD 4Channel Alarm with Remote Car...
When use remote starter to start car, factory alarm goes off. How can I use the remote starter without this happening?
It sounds as if your vehicle's factory alarm is not disarming before the remote start sequence. You will have to disarm the factory alarm before start. On most vehicles there is a disarm wire, usually in the door that operates with the key cylinder. To test, probe the wire at the key cylinder while unlocking the door with the key. Some vehicles have the disarm wire in the driver's kick panel, but they operate the same way (with the key cylinder). Other vehicles can be disarmed with pulsing the key sense wire. Some vehicles do not have a factory alarm disarm wire,i.e. some Subaru and GM cars and trucks. They can only be disarmed through data modules. More information on the year/make/model of your vehicle will be needed to accurately solve your problem.
Nov 08, 2010 | Prestige Remote Start
Alarm button broken. Cannot disarm alarm. What do I do? Chrysler Town & Country LX 2003 model.
You can arm or disarm alarm manually with the key at the drivers side door, turn the key to open the locks and the alarm must be disarmed.
Nov 01, 2010 | 2003 Chrysler Town & Country
How can i disarm the factory security alarm.i have tried the key locks. i have no remote with the car. i didnt know it had an alarm when i bought it . 1995 chrysler cirrus
Here is what I do on my 95 Cirrus I also do not have a keyless remote (well I do but is broke) and after frustation after frustation trying to disarm the factory alarm I find out that by unlocking the passenger front door with the ignition key from the outside will disarm it you may have to try few times before it's disarmed you need to make sure that the blinking red light stops blinking and all of the locks on all 4 door are up or unlocked, this is what I been doing for 3 years now and that's how I disarm the alarm on my car, I hope this helps.
May 15, 2010 | 1995 Chrysler Cirrus
Ford factory alarm arm output and disarm output
I don't show this truck as having a factory alarm, is there maybe an aftermarket alarm in it
Dec 28, 2009 | Code-Alarm Code Alarm Transponder
Toad car alarm - text alert texts when arming and disarming alarm
yes this is aknownprobplem to Scorpion (Toad), you will need to use relays on the trigger wires
Jul 16, 2009 | Vehicle Parts & Accessories
Vehicle Parts & Accessories Logo
91 people viewed this question
Top Python Vehicle Parts & Accessories Experts
rjivaro
AzVip
D. E. Hev
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
