Question about Philips CD235 Twin Cordless Phone
Philips led not working on phone it is very difficult to read
How can I see display better in sunlight?
Viewing screens that make use of "back lights" (LEDs, fluorescent, etc) to see / read the display in direct sunlight is often very difficult. Increasing the back lighting level is one method - but even when at 100% brightness, it is hard to overcome the sun. Shielding the screen from sunlight with your hand, body, etc., is often the only way that works effectively.
Apr 10, 2015 | Cell Phones
Red LED blinking after turn on the TV
These blinking codes are fault indications. By counting these, you can understand the location of the faulty section inside it. But, counting these blinks too is somewhat difficult to a user who is not aware in electronics. Check this link, and see how to count the standby light blinking codes to Philips brand TVs. Details are described there in detail.
Jan 13, 2013 | Televison & Video
How do I unlock my philips DVD player, model DVP3600
this very difficult, since all manufacturer has special code for certain region. Do not exist universal code for alll region world.
All manufacturer put in the ROM of the microcontroller the special TOC, for guide the DVD to read only the region that they sell.
However you must read your instruction manual for to see the indication for to see which format read your DVD.
God bless you
Jul 11, 2012 | Televison & Video
If the legrand dimmer 400w - pro21 can function with led dimmable light "philips master led spot "
The answer is NO. You need a Trailing Edge dimmer to control LEDs.
The Phillips master LED spot manual says
Lighting controls: bulbs are dimmable 20-100% with ""select"" Trailing Edge RC devices
http://www.prismaecat.lighting.philips.com/FredhopperPDFWebServiceInter/docts/1d8ea75f-e889-424d-92dc-450fbeb85f6a/Smart_LED_Spot_da.pdf
The Legrand pro21 manual does not say anything about being a Trailing edge dimmer.
http://www.legrand.com.gr/gr/gr/liblocal/internet_greece/PDFS/NOTICES/IOBL/ROOSTATES/775637EN.pdf
Legrand diagrams show what appears to be incandescent bulbs, and say nothing about LEDs
LEDs cannot be dimmed as ordinary incandescent (tungsten) bulb.
More reading:
Wikipedia article on dimmers includes technical stuff on Trailing edge dimmers
http://en.wikipedia.org/wiki/Dimmer
2 sites show LEDs bulbs that dim:: both seem new ...
http://news.thomasnet.com/fullstory/LED-Bulbs-feature-smooth-dimming-range-566574
http://www.earthled.com/lumiselect-dimmable-led-light-bulbs.html
Oct 11, 2010 | Legrand On-Q/ ALC 600W Dimmer Switch,...
Remote not working
i've a philips video player model no  ( DVD622),remote not working
May 23, 2009 | Philips DVDR3575H/37
Disc is not working. Error message No disc
Try cleaning both the disk and the lens of the dvd player. Sometimes even a little bit of dust can make your dvd player go ballistic. Brands like Sony,Philips and LG are very sensitive. If anything else fails, you can take it to a repair shop to find out if the lens isn't cracked or the LED isn't responding while trying to read the disk.
Apr 02, 2009 | Philips DVP3960
Programme actor 10in1 urc
Philips codes:003,026,027046,073,113,115,155,191,192,193,194,223,266,230,242Sharp codes:044,054,119,124,196,198,225,2271)Press SET key and hold it.Then press the device key you want , eg TV12)The LED will be on. Release the keys3)Enter the 3 digit code of your device.If it is correct , the LED will be off.If not , the LED will blink. (read on bellow)4)Try if the keys work.If not find other code , and repeat steps 1-4
Feb 21, 2009 | Sharp Televison & Video
Just bought a Philips Digital Phone Model No.CD135. Is THERE NO BACK LIGHT on this phone as it is difficult to read screen even in daylight. I would not have purchased it otherwise. If not do you have a...
Hi
I contacted Philips by phone and the told me that there is no back light on Model No CD135. I think that is stupid as you can have a back light on the cheapest mobile phone. All handset phones should have a light so it can be used in bad light.
Frank
Sep 26, 2008 | Lands Phones
42PF7321D/37 LED Light Blinking RED
my dad had this happen too. after some research, we found out that there are two capacitors on the power supply board right next to the connector for the main logic board that went bad. you can just pull those out and solder in new ones, and it works like new again! i found a repair kit on ebay for $35 including shipping, and that's all it took!
Jul 17, 2008 | Televison & Video
55pl9773
55pl9773 philips dlp
yellow led blink on/off then go away,"shutdown???"
fans will not turn on, go to back off unit and open lamp door,lamp swith is off,turn tv on,now all fans are on and running,unit seem like working ,no picture or sound.if i close lamp door swith it shut down again,
replaced new lamp ballet ,it is same problem????
anyone have comment??
Jan 15, 2008 | Philips 55PL9773 55" Rear Projection...
Philips CD235 Twin Cordless Phone Logo
26 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
