Question about Xerox 6505N AllInOne Printer
Toner invalido xerox 6505 - Xerox 6505N AllInOne Printer
Xerox 6505 Scanner Sensor Error 062-360
Check out the Xerox.com website.
Good luck..
Oct 03, 2014 | Xerox Office Equipment & Supplies
What is the problem if xerox 6505 is noisy during operation in the imaging area
This is usually from a worn gear in the transport area. Xerox service call.
Aug 06, 2014 | Xerox Office Equipment & Supplies
What is the life of a Xerox 6505 toner cartridge
The life of a toner cartridge is governed by how much printing it does.
As an example: the average full toner cartridge was expect to yeald approximately 10.000, A3 prints of approxamatly 5% coverage.
That equates to your average business letter :=
Dear Sir, blah, blah, blah ... Yours sincerely.
If you want to print construction plans and black and white drawings expect to get less prints than you expected.
On average they don't do too badly, but if you want to print advertising flyers expect less if there in full colour with bleed.
If you print 4 colour black then don't expect not to use the C,M & Y that also gets used up at a similar rate.
Good luck.
Jun 09, 2014 | Xerox Phaser 6128MFP AllInOne Laser...
Xerox black developer fade printing
Try this: http://www.fortwayneprinterrepair.com/wordpress/2014/03/17/xerox-phaser-6500-workcentre-6505-light-print-issues
Apr 25, 2014 | Xerox 6500/N Phaser Laser Printer
Xerox workcentre 6505 reset drum
You will need to replace the chip on the drum unit with one like this that is available for purchase.
2pcs Drum Reset Chip Imaging Drum Unit for use in Xerox Phaser 6500...
Mar 20, 2014 | Xerox Office Equipment & Supplies
Scan documents on the 6505/DN using my pc or mac, what do I need from xerox
copier/scanner should do the trick and the new product will contain all the equipment.
Oct 17, 2013 | XEROX - COLOR PRINTERS 6505DN 6505/DN...
Xerox 6505N AllInOne Printer Logo
69 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
