Question about Hotpoint SY36 Style Line Stainless Steel Electric Single Oven
Numbers worn off - Hotpoint SY36 Style Line Stainless Steel Electric Single Oven
I have a jenn aire JGR8875RDB oven. The control panel is partially out. The numbers beep. The clock displays and all the oven controls do NOT work.
Go to the power panel of your home and locate the circuit breaker for the oven. Turn this breaker on and off several times then check the oven controls. If this restores normal operation, then I would replace the breaker. If the breaker trips instantly every time you try to reset it then suspect the heating element and the thermostat. When a heating element shorts, it can ruin the contacts inside the thermostat.
Aug 07, 2016 | Ovens
NUMBERS MISSING FROM FRONT OF OVEN
if you get a solution could you tell me too please? Or do you have a link to where I can get a manual from please@
Nov 10, 2013 | New World 70TC Electric Single Oven
Can i have a picture of the front panel control knobs ie which is which mine are worn off and i dont know which is grill or bake etc
Try look on line. Maybe under appliance parts there may be a picture. You will need make, model and serial numbers. Sometimes in oven door openingor sadly on back of stove. Good luck
Feb 10, 2011 | Ovens
Can no longer read the temperatures around the oven knob
On the 720EF the numbers are recessed behind a small glass panel, so I think you are not talking about the same unit. If all else fails, I suggest you buy an oven thermometer from say Lakeland - they are about 4 to 5 pounds and are good. Run the oven, making a note where the marker is and see what temperature the thermometer gives.
Failing that, run the oven with the thermometer in all the time and experiment to see what the control; knob is pointing at for any given temperature.
Apr 10, 2010 | Stoves 720EF Electric Double Oven
I don't have the model number for this range but it's a very old magic chef gas oven. What I need is the oven temperature knob. The knob used to have all of the temperature numbers printed on it however...
If you go any hardware store (Lowe's, Home Depot) they have universal knob replacement kits. Take your old knob with you and ask for help from someone who looks like they know something (the old guy). Its so much cheaper this way, exact replacement knobs can run $20 or more each. Good luck!!
Jan 16, 2010 | Magic Chef 9122 Gas Single Oven
Temperature settings have worn off.
this is a tappan range any tappan dealer can help you find the knobs
Apr 20, 2009 | Ovens
Hotpoint SY36 Style Line Stainless Steel Electric Single Oven Logo
16 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
