Question about Bionaire Dehumidifiers
How does the Bionaire dehumidifier model number BDQ01
I filled the container with water and turned it on and I got red lights and I'm not sure if I'm suppose to here anything. How does this work?
  • 5 Answers
SOURCE: Collecting no water
My crosley dehum. acted the same way. It turned out to be a bad defrost thermostat on the evaporator coil.
Posted on Oct 26, 2007
  • 121 Answers
SOURCE: DeLonghi 50 Pint dehumidifier DE 500P won't turn back on
If it is not responding when you try to activate the shutoff button and are still not recieving an acknowledgement that the bucket is full you may hav a defective shutoff button. Try contacting the Manufacturer and see if you can purchase just the button. This i a common part and the price is usually reasonable. If you feel very technical inclined you can remove the button and touch the 2 wires together simulating a closed contact. The dehumidifier should now acknowledge the bucket is full. If you recieve the notification then the button is bad. If you found this solution helpful please rate it.
Thanks - Tech101
Posted on Jun 24, 2008
  • 59 Answers
SOURCE: kenmore dehumidifier is running but not pulling water
normally this means that the compressor is not running. Check capacitor and connections to compressor.
David
Posted on May 25, 2009
  • 40 Answers
SOURCE: Dehumidifier not filling the bucket with water
It's low on freon
Posted on Aug 26, 2009
heatman101
  • 43501 Answers
SOURCE: Dehumidifier not drawing moisture
Here is a tip that I wrote that will help you...
http://www.fixya.com/support/r3877515-dehumidifier_problems_dehumidifier
heatman101
Posted on Apr 16, 2010
How much water do I put in water bucket on this thing?
You don"t put anything into the bucket. A dehumidifier will fill the bucket for you.
Jan 13, 2013 | Whirlpool AD50USL Dehumidifier
Running, but not taking water from air
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 20, 2011 | Bionaire BDQ24 Quietech Dehumidifier
The dehumidifier stopped collecting water. It was working great, then just stopped collecting water one night.
heatman101
Jul 17, 2011 | Bionaire Dehumidifiers
Drain hose is hooked up, however, "full" light is
The drain tube of hole inside the unit may be clogged. Unplug the unit and remove the water container. With a flashlight look up and into the unit to locate the tube or drain hole. Using a 12' long Zip Tie, carefully run the Zip Tie up into the tube or hole, as far as you can. Gently turn it and with draw the Zip Tie slowly. This should remove any clogs.
Hope this helps to solve your problem.
Mar 07, 2011 | Bionaire BDQ25 Dehumidifier
Collects very little water never fills up the container. all fiters are clean
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Take care.
Aug 11, 2010 | Fedders A7DH45B2A Dehumidifier
Haier dehumidifier will turn on but does not collect water.
hello. If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Apr 14, 2010 | Haier HD656E Dehumidifier
FULL LIGHT FLASHES
An automatic overflow switch and Container “Full” indicator light are provided to turn the
dehumidifier off before the container overflows. When the indicator light on the control panel
glows, the water container must be emptied. If the light remains on and the dehumidifier does
not begin to operate make sure the float is attached to the water container.
When the condensate water container is full, the indicator lights up.
1. Turn the power off before removing container. Wait 3 minutes for
any remaining water to drain into the condensate container.
2. Tilt the container forward then lift carefully by the handle.
3. Empty and gently re-insert the container.
Important:This water is not suitable for drinking.
Please rate and god bless:)
Apr 24, 2009 | Fedders A7DH45B2A Dehumidifier
My lg 30 is not working.
It is supposed to. There is a float that rises as the container fills. When the container is filled to capacity, the float is at its highest point and the humidfier turns off. At the same time, the red light comes on. This is normal. When you remove the container, the red light stays on b/c the float is still at its highest position. It is designed to do this so the humidifier doesn't run when the container is not installed. If the light does not turn off after you replace the container, give the humidifier a tap to move the float back.
Jan 12, 2009 | LG DH30 GoldStar Dehumidifier
Dehumidifiers Logo
Top Bionaire Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Bionaire Dehumidifier Expert? Answer questions, earn points and help others
