Question about Harman Multimedia Audio Players & Recorders
Kardon avr 155
KEIN HDMI SOUND BILD JA
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Harman Multi... Master
  • 924 Answers
Please respond back in English only.
Posted on Dec 19, 2014
ithana
  • 185 Answers
SOURCE: harman kardon avr 245
Adjust the receiver in proper position and fix it,it may helps u.
Posted on Sep 03, 2008
smarthome2
  • 1114 Answers
SOURCE: Harman Kardon AVR 154 OSD setup screen wont display
It will only display via component. Your HDMI firmware is either 1.1 or 1.2 and has HDCP issues (High Definition Copyright Protection) it's a firmware problem that has been fixed on all new receivers, not just a HK issue, all receivers! the new version 1.3a and 1.3b have fixed the issue. Unfortunately you cannot update the firmware on the receiver. Hope this explains it for you, sorry! Lot's of angry people out there!!! myself included.
Posted on Jul 01, 2009
  • 382 Answers
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Posted on Jan 01, 2010
Testimonial: "cheers, have a good year."
SOURCE: I have a harman kardon avr 745....looks frozen
Did you happen to come up with a solution. I have the same problem, 100% as you have described it.
Posted on Apr 23, 2010
jonsen
  • 62 Answers
SOURCE: harman kardon avr 100 no power
check the fuses it help the power !
Posted on Jun 10, 2010
Connect pc
To connect your PC or Laptop to your Harman Kardon AVR 2600 you need to connect the HDMI cable output of your graphics card to one of the 4 HDMI inputs on the AVR 2600 receiver. The HDMI connector on the AVR 2600 labeled "HDMI Monitor" is on output and cannot be used as in input.
You need to select the corresponding input from the front of the AVR 2600 or using the remote. Next you need to make sure your have the HDMI output port selected on hour graphics card. This will probably not apply to your PC, but may require some settings from the function keys on your Laptop.
Note that you will probably need to also connect audio from your PC to your receiver as well. I would recommend you use HDMI cable with ver1.4 specification so that you have the best chance of getting audio over the HDMI. If you only get video, then run separate Toslink (optical) or RCA cables to get the audio to the system from the PC.
Jan 12, 2014 | Harman Kardon AVR 2600
Harman/Kardon AVR 3650 3D A/V Receiver
Make sure TV's HDMI port is working if it is working check it with a new HDMI cable changing the HDMI cable will fix the problem
Dec 15, 2017 | Harmon Kardon Harman/Kardon AVR 3650 3D...
Connecting
did you check this out yet? (from the owners manual)
IMPORTANT NOTE: If the AVR's video output resolution
is set higher than the capabilities of the actual connection,
you will not see a picture. If the best available video connection
from the AVR to the TV is composite video, press this button
and change the resolution to 480i.
Oct 06, 2012 | Harman Kardon AVR 3600
Just bought a Sharp LED TV and there is a slight delay between hearing sound and seeing lips move. Have cable box hooked up to tv by HDMI and have cable box hooked to AVR (Harmon Kardon AVR125) by optical...
Hi if there is an optical out on the television i would use that direct to your Harmon Kardon AVR 125, the sound would be in sync with picture, as the source is the same.
Jan 31, 2011 | Harman Kardon AVR 125 Receiver
Bei unserer Canon sehen wir kein Bild mehr auf dem Monitor. Man hat auch kein Foto wenn man abdrückt.
Ich hoffe, dass Sie mit den folgenden, wie ich nicht Deutsch sprechen, und ich bin mit Google übersetzer. Ein stecken Auslöser ist ein weiterer häufiger Fehler-Modus für Digitalkameras. Die Symptome einer stecken oder "klebrige" Auslöser sind sehr ähnlich zu CCD-Bildsensor Scheitern. Die Kamera kann Bilder aufnehmen schwarz (für Verschlusszeit fest geschlossen), oder die Bilder können sehr hell und überbelichtet, besonders wenn im Freien getragen (für Verschlusszeit fest offen).
Um eine Verschlusszeit fest zu bestätigen, legen Sie die Kamera in einem anderen Modus als "Auto", und der Blitz ausgeschaltet (Sie wollen nicht blind sich für den nächsten Schritt).Zunächst blicken die Linse und ein Bild. Sie sollten ein kleines Flackern in der Mitte der Linse sehen, wie der Verschluss öffnet und schließt. Wenn keine Bewegung zu sehen ist, dann haben Sie wahrscheinlich ein Auslöser stecken. Wenn ja, lesen Sie bitte diesen Link für weitere Informationen und ein einfaches Update, das helfen kann.
Mar 19, 2010 | Canon PowerShot A620 Digital Camera
Can I conect harman Kardon avr 230 to apple tv
Dec 08, 2009 | Harman Kardon AVR 230 Receiver
Problems with setting up Harmon Kardon AVR 146????
in what display i need to put reciver when i use the optical digetal
Oct 19, 2009 | Audio Players & Recorders
No sound in hdmi mode unlock flashes on display I get sound in cd
Its asking your permission to unlock the setup menu. When you hit setup, and it says "unlock," you have to hit one of the navigation arrows on the remote control. Once you have unlocked the menu, you can assign the audio to that HDMI input.
Jul 30, 2009 | Harman Kardon AVR 130 Receiver
Jun 27, 2009 | Harman Kardon AVR 235 Receiver
53 people viewed this question
Top Harman Multimedia Audio Players & Recorders Experts
Steve
berggei
Are you a Harman Multimedia Audio Player and Recorder Expert? Answer questions, earn points and help others
