Question about Edge Products 2010 GMC SIERRA 3500 HD 85200 Evolution CTS Diesel Progr
Front axle nut torque specs - Edge Products 2010 GMC SIERRA 3500 HD 85200 Evolution CTS Diesel Progr
NNeed torque specs for 2010 harley ultara classic, front axle nut, front brake calipers, axle nut holder
Front Axle = 60 to 65 foot pounds
Front caliper banjo bolts = 17 to 19 foot pounds
Front Brake disk screws = 16 to 29 foot pounds
Front caliper mounting bolts = 28 to 38 foot pounds
Front axle holder nuts = 132 to 180 inch pounds
Aug 23, 2014 | 2010 Harley Davidson FLHTCUTG Tri Glide...
What are the torque specs for 2010 harley ultra classic, front axle nut, front brake calipers
Front caliper -
Brake Pad Pin = 75-102 INCH lbs.
Caliper to Fork Bolts = 28-38 FOOT lbs.
Harley torque specs
2007 XL = Axle (front) pinch screw 21-27 ft-lbs 28.5-36.6 Nm
Axle nut, front 50-55 ft-lbs 68-75 Nm
May 22, 2014 | 2007 Harley Davidson XL 883 Sportster
Front hub torque specs
The torque for the hub bolts is 120 ft. lbs
The torque for the axle nut is 185 ft. lbs.
Dec 29, 2013 | Dodge Cars & Trucks
2013 ultra classic torque spec's on Rotors front Axle's front and rear
Front axle nut torque 70-75ft lbs, rear axle cone nut first torque 15-20ft lbs, second torque 95-105 ft lbs, front disc torque 16-24 ft lbs, rear disc torque 30-45ft lbs.
Nov 24, 2012 | 2005 Harley Davidson FLHTCUI Electra Glide...
What is the torque spec for front axle on 2012 blackline?
Hi John, here are your axle torque specifications for all late models 2000 and up.
1. Front axle nut 50-55 ft lbs.
2. Front fork slider cap nuts 11-15 ft lbs.
3. Front fork pinch bolt 30-35 ft lbs.
4. Rear axle nut 60-65 ft lbs.
Good luck and have nice day.
Nov 02, 2012 | Harley Davidson Motorcycles
Rear axle torque spec
Hi Anonymous, here are your axle torque specifications for all late models 2000 and up where applicable.
Apr 18, 2012 | 2010 Harley Davidson FLSTSB Softail Cross...
What is the torque spec for the front center axle nut on a 2003 tahoe?
The torque specs.are for 15k series trucks is 155 ft.lbs.For 25/35 series it`s 133 ft.lbs.Hope this helps.Good luck.
Dec 03, 2011 | 2003 Chevrolet Silverado 1500
No problem I need torque spec's front brake rotor,front axle nut and front brake caliper bolts 2005 Harley davidson ultra classic
caliper torque 28-38 ft lbs,front axle nut torque60-65 ft lbs. front brake rotor torque 16-24 ft lbs. straight from harley manuel.
Aug 14, 2011 | 2005 Harley Davidson FLHTCUI Electra Glide...
Front Hub Bearing Torque specs to complete replacement
THE LUG NUT TORQUE SPEC - 140FT/LBS\
CALIPER MOUNT - 80FT/LBS
CALIPER BRACKET 129FT/LBS
AXLE NUT 177FT/LBS
Apr 24, 2009 | 2003 Chevrolet Silverado 1500
Edge Products 2010 GMC SIERRA 3500 HD 85200 Evolution CTS Diesel Progr Logo
194 people viewed this question
Top Edge Products Optics Experts
Michael Sullivan
Michael Sullivan
Level 1 Expert
Lawrence Oravetz
richie46
Are you an Edge Products Optic Expert? Answer questions, earn points and help others
