Question about Miele S7280 Bagged Upright Vacuum
Broken part on a S7280
Broken part that connects hose handle to machine
Why does it have little to no suction power on carpet?
either your hose is stopped up or your motor is going bad and doesn't have enough power, first clean out your vacuum and check belts and make sure they aren't worn out and broken or stretched
Dec 13, 2015 | Miele S7280 Bagged Upright Vacuum
Top coupler on gas pump handle ONLY (Majestic 360 SS) is broken. Do we have to replace whole hose and handle assembly?
They now make a replacement tab so you don't have to replace the entire handle grip. The bad part is, most of the time it's the handle grip that has the broken place in the plastic, not the latch tab. That too can be bought seperately though, so you don't have to buy the hose. Call your local vac shop for assistance.
Oct 21, 2014 | Filter Queen Majestic Canister Vacuum
How can I repair? The power nozzle N109J is not operating, but the handle can turn the vacuum on/off and there is plenty of suction. Is it possible the electric connection in the handle is broken?
Yes,also try checking the connection from the hose to vacuum.Make sure hose is in vacuum port properly.To test this just wiggle the hose end up and down with machine running.It the problem is there the head should start intermittently.If not get back to me with more info.hope this helps,it is a fraustrating but fixable problem. Chris
Aug 16, 2014 | Electrolux Vacuums
Why when I Pull out handle to use edging attachment, suction stops?
Make sure that the vacuum cleaner is in the fully upright position as there is a slide 'gate' thet directs suction to either the vacuum head or to the handle section depending as to which section you wish to use. In the upright position, you shoud be able to hear the vacuum at the handle where the attachments connect. If you still have vacuum at floor level, check the action of this gate. The actuating mechanism may be broken. Cheers Bob
Jul 12, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
I have a Renassiance C104A and once you plug it into the wall socket, it starts to run and no lights are on the handle....I've replaced the circuit board in the handle and the triac inside the...
There are a lot of things that could cause this problem because the wire runs through the hose. There is a connection on both ends you should check to make sure they are clean.
With the machine running try to "wiggle" the hose connections to see if the head gets power intermittently
Oct 16, 2013 | Electrolux Guardian Bagged Canister Vacuum
We have an electrolux central vac. The power head won't turn on. It has a 3 way switch on the handle. When to the left it is just air for the floor. center is off and to the right is the power head. ...
I assume you did press the reset switch on the power nozzle. If so, there are a number of things that could cause this. To rule out the hose and power switch, connect the Sidekick (if you have one) to the handle. Turn vacuum on. If the sidekick runs, the problem will be in the wands or power nozzle. Try connecting the power nozzle directly to the hose. If it runs, the problem is the wiring connections in the wands, or from the lower wand to the power nozzle. Check all connections for discoloring and broken or cracked wand fittings.
The wiring in the elbow of the PN is a fairly common problem, especially with certain models. A piece inside breaks, resulting in the wire connection to not make contact. No contact means the PN motor won't run. And there's always the possibility that the PN motor is bad.
If the Sidekick doesn't run when connected directly to the hose, the switch could be bad, the wiring in the hose could have broken, which is another common problem in older hoses, or the ECV board in the vacuum could be bad.
If the problem hasn't been resolved at this point, it's best to take the entire machine to the Aerus Electrolux store near you for a free diagnosis.
http://www.aerushome.com/storelocator/
Jan 07, 2011 | Electrolux Central Vacuum
I need help removing a cat toy from the handle that connects to the hose on my vacuum? The ball seems to be stuck in the curve or just below the curve before it enters the hose.
The handle needs to be removed to do this. Taking the handle apart and especially putting it back together can be tricky, so I recommend taking it in to an authorized Aerus Electrolux store to have the item removed. If you don't put it back together properly, it could result in an electric shock, and even a fire. I have seen a totally melted hose from someone trying to dig out an object, then the hose wiring shorts out and lights up.
I dislike having a disassembled machine or part brought in to be reassembled, and finding a broken tab that requires replacing the handle or part that's brought in.
Be safe, please take it to the shop.
Dec 17, 2010 | Electrolux Lux 5500 Canister Vacuum
Progressive Kenmore hose canister connection broken 116,2341130
A regular person with patience can however it is tricky. Kenmore hoses have an arrow at the cuff where the corrugated hose meets the swivel elbow at the machine, and at the cuff where the handle meets the hose. If your parts fit in the handle, the cuff needs to be squeezed slightly out of round at the arrows to allow the handle to be popped out, usually by using a vice and applying a sharp blow by hand to the underside of the hand grip.
If your problem is in the lower sleeve area where dirt gets into the contacts at the machine end, there is a 1" clip with bayonets on either side. It must be compressed at the bayonets to allow the sleeve to slide off. The internal contact rings should be cleaned and polished with W/D sand paper #600 and then lubed with vaseline. Contact fingers should be spread to apply more pressure on the internal rings before reassembling in opposite order.
When in doubt Panasonic and Kenmore warranty centers will be familiar with these.
Aug 05, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Brush is not turning
You may not have power to the power head. Check the plug at the neck of the power head, also the wand connections to make sure they aren't burnt. Most of these powerheads also have a circuit breaker on the top of it, press it to see if it will re-set. At the end of the hose handle, there is a female plug where the wand plugs into, push it ans see if it will move inward or not. If it does, then it has broken loose inside of the handle and isn't allowing a connection to the wand. The switch on the hose handle may be bad. The power head motor could be bad. These are the most common problems when the power head won't run.
Jan 26, 2009 | Kenmore 22812 Bagged Canister Vacuum
Miele S7280 Bagged Upright Vacuum Logo
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
