D link router password
I set up my router but i cant seem to find the password where should i look?
4 Suggested Answers
  • 104 Answers
SOURCE: cant figureout how to set a password to a d-link router
Hi…I’ll try and lend a hand. There are several ways to set up wireless security on this router. However, I’ll help you set it up using the manual method.
Important note: use a wired (Ethernet) connection to the router to set up wireless security.
There are four main steps:
1) Login to your router.
I’m sure you have done this already, but here it is again for clarity. Type the router address in the address bar of a web browser. For this router, it is http://192.168.0.1
Select ‘Admin’ from the dropdown box, then enter your password IF you have set one – otherwise, just leave the field blank and press return.
You should then see the configuration screen/user interface.
2) Change the router password.
If you HAVEN’T set a password, this is a good place to start. Go to Tools >Admin option. Set and confirm a password for ‘Admin’, and note it down. Also, set and confirm a password for ‘User’. Click ‘save settings’ when finished.
Make sure these passwords are not easy to guess, or a neighbour could log into your router and view/change all your settings.
3) Change the SSID (router name):
Go to Setup > Wireless Settings. You should see an option marked ‘Wireless Network Name’ or SSID. Change this from the default, ‘dlink’, to anything you like –as long as you can remember it. It is case sensitive, and you can use up to 32 letters – but don’t use something that could identify you, or your location. Click ‘save settings’ when finished.
4) Enable encryption
Still in the 'Wireless Settings' menu option, you should see the ‘Wireless Security Mode’ section. Under the 'Security mode' dropdown you have a number of options for encryption. WPA is safest....I would pick WPA-Personal.
You should see a dropdown box marked WPA Mode – select Auto. Leave Group Key Update Interval at the default of 3600s.
Under Pre-Shared Key you should enter a long password, or passphrase, between 8 and 63 letters/numbers long. This can be any series of letters/ numbers, or you can use a phrase with numbers ( eg - 456HappyhOLIdaystoyou8899). It is case sensitive.
Note down the passphrase carefully. You will need this to connect wirelessly. (The WPA shared key may also be called the network key, PSK, pre-shared key or passphrase). Click 'Save settings' when finished.
That's it, you have done enough to secure your network, and can close the screen.
There are further security options to enable if you wish, but these three are the most important.
When you next connect wirelessly, you'll see the router with its new name in your 'available wireless networks'. When you attempt to connect, you are asked for the WPA shared key you set in Step 4. If all goes well, you can then save this and will connect automatically in future.
Hope this helps you. Please come back to Fixya if this doesn't work or if you need help with any of it.
Posted on Dec 23, 2008
  • 104 Answers
SOURCE: forgotten dl-624+ password and cant get into settings 192.168.0.1
If you’re using Windows, go to Start > (All) Programs >Accessories > Command Prompt.
You should see a command line window. Type in ipconfig and press return. In the output you see, the IP address under ‘Default Gateway’ should be your router address.
If this doesn’t work either, or it is showing the IP address you already tried, please come back to Fixya.
Posted on Jan 05, 2009
  • 10406 Answers
SOURCE: set a security password
Start Internet Explorer.
Connect to the web-server "inside" the router.
Run the "Wireless Network Setup Wizard".
Enter a SSID of your choice.
Enter a security-password of your choice.
Posted on Jan 29, 2010
I cant find the password for my dir615 help
Your D-Link router's browser-based wireless settings give you the option to reset the wireless security key, which is a quick fix for a forgotten password.
Read More Help.. How to Reset Password on Link Router and D-Link Router Support
Thanks,
Sep 17, 2014 | D-Link DIR-615 Wireless Router
Ullersinoz@hotmail.co.uki have just bought a d-link router from my friend and cant get it to connect to the internet, he has forgotton the password and username, the reset button doesnt seem to reset it...
If the default password has been changed then -
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
May 28, 2011 | D-Link DIR-412 Mobile Broadband Wireless...
I got a Netgear WNR2000, the dealer said it was a great wireless router, but its causing alot of problems.. It seems to shut down after an hour or so if its not in use, and i cant seem to find any...
have u tried to update the firmware in the router.Try this steps open the GUI page by routerlogin.com it will ask u a user name and password.User name is :-admin and password is password go to the option maintenence and click on router upgrade and select browse and select the firmware u downloaded and then upload it.This is the link where u can download the file
http://kb.netgear.com/app/answers/detail/a_id/11895
and then soft reset the router by clicking on the option.back up settings and click on erase and after then made the wireless settings again as it make the router to factory default
Enjoy.....
May 15, 2011 | NetGear WNR2000 Wireless Router
Cant seem to install my D-link Wireless N 150 Home Router
who is your isp are you connecting with a cable company or dsl?
Feb 28, 2011 | D-Link DIR-600 Router
I cant login to D-link-i have forgotten my password and i have tried 'admin' as username & 'password, admin' for the password and also tried leaving it blank, as well as the pin on the bottom of the...
The default D-link router login is admin with no password. With that said, you probably cannot login to your router because D-link requires you to change this default login the very first time you login to set it up. If you have a router you setup a long time ago and have forgotten its password and settings, you will likely have to reset D-link router password.
If you look at the back of your D-link router, you will see a pin-hole. Inside that hole is a button that resets the router. To perform the reset, insert the end of a paperclip in the hole and depress the button for about ten seconds. Leave the router on during this time. It will reboot by itself and the WAN light will begin flashing on the front.
When it stops, the router is reset and you can login to it using your web browser. Just type http://192.168.0.1 and click enter. You should see the D-link login window. Type admin without a password and you will be presented with the default d-link settings again. Configure a new password and wireless settings and your router will now be accessible again
Jan 27, 2011 | D-Link Xtreme N DIR-655 Wireless Router
I have lost the installation cd to my linksys router and I need software to change the wep password. I cant seem to remember what I have set it to before.
You can know your password without disk too. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Oct 06, 2010 | Linksys Wireless-G WRT54G Router
My husband bought a dlink router (it says dgl-4500 on it) and i cant figure out how to use it to get wireless internet for my new laptop....i have three "codes" he wrote down- a "router pass", a "network...
Router password is the password to access the router settings.
SSID is the network name. When you try to connect to the wireless network on your laptop, you will see this network name.
If your network is secured network then it will ask you for the network key or the password. You need to enter the ' security key '.
Click Here for step by step by instructions
Sep 11, 2010 | D-Link DGL-4500 Wireless Router
Cant recall password to my d-link
You need to reset your D-Link router and use the manual to get the factory login information and redo the settings.
Oh, and after you've done that, it would be a good idea to export and backup your router settings.
Feb 15, 2010 | D-Link Computers & Internet
I cant secure my dlink. Every time iuse the wizard and i am asked to put in admin and leave password blank, it wont accept. I'm not sure if I have put a paasword in before, but i cant progress past this...
this should get you into the setup screen thru your internet browser! thats if a password has not been set if it has you must reset and reconfigure the router!
user is: user
password is:password
Aug 29, 2009 | D-Link AirPlusG DI-524UP Wireless Router
Router configuration password
you can access your router with folowing link
http://192.168.1.1
or
http://192.168.0.1
type suername as "admin" and password is "admin" or blank or "password"
thern you can enter in router configuration then go to wi fi if you set encryption security there then check it is your wi fi security poasword.
Jun 26, 2009 | Zyxel Prestige 660R Router (P660R)
Computers & Internet Logo
114 people viewed this question
David Payne
David Payne
