Question about Vacuums
Zanussi ZAN1829 1800w
While using Zanussi ZAN1829 1800w Cyclonic Cylinder Vacuum Cleaner, it stopped suddenly. I changed fuse but still not working. I think its an electrical fault.
  • 72 Answers
SOURCE: Emptying cylinder
I hope you've found out by now, but, in case you haven't, the latch to remove the canister is right by the handle on top of it, just don't lift until you release the latch with your thumb, it's got a safety to keep you from hitting the release when you're using that handle to carry the vacuum.  (good engineering).
you can download a manual from the dyson site, here:
http://www.dyson.com/customercare/manuals/us/dc07_opmanual_usa.pdf
Posted on Oct 20, 2007
  • 389 Answers
SOURCE: no power for the vacuum
Hi! I work at repairing Sebos, so can certainly help.  Most probably the cable is damaged, and the two most likely places for that to happen are where it enters the plug and where it enters the rewind mechanism. Before you even think about dismantling the machine to get at that end of things, though, you need to be 100% sure that power is reaching the machine.
I know you've tried a different socket, and that you've changed the fuse (by which I assume you mean the plug-top fuse, and therefore that you're probably in the UK like I am). Good first steps. Checking the integrity of the wire in the cable is a different matter, though. There are inexpensive devices you can buy to check for voltage through normal insulation, but I don't know how deep in to this you want to get...  you've got to be pretty keen (and competent) to think of changing the cable yourself.
If you'd like to post a response, indicating how far you want to go yourself, I can help you get in to the machine if necessary.
Posted on May 27, 2009
SOURCE: hoover fusion plus cyclonic upright vacuum
While I'm having a different problem, the problem you guys are experiencing can easily be fixed by cleaning the two internal filters. My vacuum did the same thing, just stopped running mid-stream. Remove the main filter cup. Look inside the cavity of the vacuum and you'll see a grey bar at the bottom of the cavity, pull this up and you'll find the first of two washable filters. Just rinse it under warm water squeezing as you rinse until the water runs clear. The roll the filter in a few paper towels or towel and unroll, reroll until completely dry - should only take a few minutes. Then, look in the same cavity except up top there is another filter which seems to be hidden. The back wall of the inside cavity will guide you to these filters as well. You will be amazed by the difference cleaning these will make in the suction power of your vacuum. Also, if you remove the belt cover and clean out the hose in this area it will improve suction as well. Hope this helps. Now, if I could just get the darn belt back on mine. First belt smoked and popped. Bought replacement belt, smoked and popped within seconds... HELP!!!
Posted on Aug 11, 2009
tooltech75
  • 80 Answers
SOURCE: Miele 5000 vacuum cleaner stopped during use. no lights on
could be your retractable cord assembly's contacts..
push the power on while pulling out the cord. see if it tries to start.
Posted on Oct 07, 2009
SOURCE: oreck vacuum cleaner stop working; earlier it was off-on while in
orick vaccum has started being hard to push and does not pick up small fuzz or specks.
Posted on Dec 06, 2009
How to replace brushbar motor on a dyson dc17 vacuum cleaner
Hello, this is Ava with Think Crucial.
You may watch our video tutorial below on how to change the brush roller for your Dyson DC17.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jun 05, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson cylinder i was sucking a vacuum space saver bag and my vacuum just stopped
Hi Philip,
Your DC11 is equipped with a safety device which shuts the cleaner down if it starts to overheat. It's likely that this is what occurred, as there may not have been enough airflow through the cleaner to keep the motor cool. If you unplug the cleaner and leave it to cool down for at least an hour, you should find it will work again.
If the cleaner still won't run after this time, get in touch with us directly so we can provide further assistance - you can call us free on 0800 298 0298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Oct 31, 2011 | Dyson DC11 All Floors Bagless Canister...
How do i change the motor on th dc08 dyson vacuum cleaner
Hi there, It is a bit difficult to describe how to change the motor for a Dyson DC08 so I have made a video. I think it shows how it's done pretty clearly if you like the video leave me a thumbs up or a comment. If you realise while watching that you need parts for your dyson I would recommend you check out Nelson Vacuums or Vacuumspot.
Oct 11, 2010 | Dyson DC08 Cylinder Bagless Canister...
Plug gets hot when using vacuum.Could it be the motor? My husband thinks it's because it is drawing to much power. That the vacuum is blocked somewhere.
Do you mean the plug in the wall gets hot if so this should never happen has the fuse in the plug been changed?
if not the vacum can not be pulling to much power as the fuse will blow to stop that
Yes the vacuum may be blocked some where but should be easy to find out where as these models come apart with ease
Jul 20, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson upright vacuum cleaner makes horrendous noise
It might be a simple as changing the clutch belt and the drive belt and cleaning out the brush roll. You can get replacement belts here:
Dyson DC07 Belts
Dec 08, 2009 | Dyson DC07 All Floors Bagless Upright...
Vacuum just stopped, won't turn on
Take it back under guarantee, could be faulty mains lead or switch or motor
Sep 20, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
My dyson dc14 suddenly stopped working while vacuuming. What should I do?
Check mains fuse, if OK, suspect mains cable broken where it enters the machine. Wriggle the cable with the machine switched on.
If it's done a lot of work, the motor brushes could be worn out.
Jul 31, 2009 | Dyson DC14 All floors Bagless Upright...
It shut off and will not restart
All the filters have to be removed and cleaned or replaced
Apr 20, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Motor and Lights stopped suddenly after vacuuming the stairs.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19809&thid=745467
Motor and Lights stopped suddenly after vacuuming...
Posted by Brigham81 on Jul 05, 2008
I was vacuuming the stairs, and all of a sudden the light went out and the motor stopped. Is it possible to overheat it, or blow a fuse? Thanks, Brigham
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL2200 Bagged Upright Vacuum. It sounds to me that when the lights go out and it stops working that the motor is bad that you would have to replace the motor. It is still cheaper to replace the motor than to purchase a new vacuum. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 05, 2008 | Oreck XL2200 Bagged Upright Vacuum
Vacuums Logo
56 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
