Trouble with toshiba dvd player
My dvd player is not reading and playing any of my dvds. It keeps saying disc error. I put a laser lens disc cleaner in and it played. I cleaned it about 5 times and then I tried one of my dvds again, it played. I tried playing a dvd the second time about 10 hours later, now it's not reading any dvds again. So then, I tried to clean it again with the laser disc cleaner, it's not reading it at all.
simplemitch
  • 752 Answers
SOURCE: Toshiba SD-2050 problem reading discs
If it reads only the first track, it sounds like a mechanical obstruction of the laser assembly (something is physically blocking it from travelling on its rails). If you are so inclined, try removing the deck lid andgently pushing the laser (in an area where there's nothing fragile) along its track to see if it frees up. It doesn't usually take much.
Posted on Sep 20, 2007
SOURCE: Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Posted on Dec 21, 2007
  • 286 Answers
SOURCE: movie skips and freezes during play
This is a common problem on CD and DVD players.
Altini is correct to a point. You can try taking the top case off, removing the DVD drive and taking the top off of the drive. Then use a q-tip on the laser lense. I use a little squirt of windex on the q-tip. Gently clean the lense even if it doesn't look dirty. Make sure you very gently work the lense up and down through it's travel. This will make sure no dust or dirt is interfering with the lense focusing.
Reassemble and try your movies again. This is a 50 50 proposition. If you still have the same problem, the mechanism has likely gone bad. Time for a new DVD player.
Posted on Feb 14, 2008
  • 3 Answers
SOURCE: Disney dvd player wont play movies (dvd) but plays music (cd) fine
Might be the type of movie - some of them are only able to play "G" ratings. Try this: click <play> 1234 <play> It will likely unlock the dvd that is in and will begin to play. You will have to do the 'code' each time, or there's an unlock program you can purchase.
Posted on Feb 01, 2009
SOURCE: DVD PLAYER
my portable dvd player shows no disc everytime i put dvd in player
Posted on Feb 25, 2009
Getting a C 13 70 disc is dirty message only for DVDs that I'e burned recently. I bought a new pack of blank DVDs, the same kind I've always used, but every movie I burn on these new ones, they...
Hello, welcome to Fixya!
Was this player playing previously? And how long have you been using this player? I suspect the lens of the player. Once the lens of the player becomes weak, it won't play discs any longer.
The first thing my mind goes to, is the lens. The lens id responsible for reading/loading data on discs. So if the lens is unable to read the disc, there is no way the player is going to play the disc.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or probably, a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Nov 03, 2011 | Sony DVP-SR200P DVD Player
Problems reading dvds
Have you tried cleaning the lens of the portable player? You can purchase a DVD cleaning disc, this disc has microfiber brushes which clean the laser len assembly of the player as the disc spins.
Hope this helps
Jul 06, 2008 | Televison & Video
Need help working out what is wrong with my DVD player
If the dvd player is old it maybe the laser pickup lens dirty you can clean the lens but you have to be very very careful if you do try put no pressure on the lens
get a cotton bud/q-tip and clean the lens very gently you will not see much dirt but lite cleaning will remove a film from the lens
I hope this helps
Feb 21, 2008 | Panasonic DVD-F87 Multi-disc DVD Player
No DVD is playing and says disc error all times. The same DVD plays on my computer. I have tried many DVDs and the same error everytime
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load DVD's. The weak lens is also what's making it say disc error.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all DVD's with no problem at all.
Good luck.
May 15, 2010 | Samsung HT-Z310T Theater System
My dvd player will not play any dvds or cds... It says disc error
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it say disc error.
By so doing your player would play all Cd's with no problem at all.
Good luck.
May 13, 2010 | Audio Players & Recorders
My dvd player plays cds but wont play dvds says disc error or unknown disc
The lens is weak and that's why it cannot read/load DVD's. The weak lens is also what's making it says "disc error" or "Unknown disc". It can still play Cd's because, Cd's does not contain large files, unlike DVD's.
Good luck.
Apr 22, 2010 | LG RC897T DVD Recorder/VCR Combo
Disc error
how long have you been using the player. There is every tendency that the lens (laser) of your player is weak and that's why it cannot read or play DVDs.
The lens (laser) is what makes the player reads discs, and if the lens is weak/dirty, there is no way it can read or play disc.
Get a lens cleaner and use it to clean the lens, if that does not solve the problem, then its means, the lens needs to be changed completely.
Good luck.
Apr 17, 2010 | Toshiba SD-2815 Multi-disc DVD Player
Not reading and playing dvds
You can try cleaning the DVD lens.
DVD just says loading--
This can be as simple as a dirty DVD lens. CAUTION!! The lens is delicate! I wipe DVD lenses with ONE drop of glasses cleaner on a Q-tip and, starting in the center, wipe in circles to the outside. Do not press down! Do not force the lens side to side. It will move while cleaning but don't put more pressure than needed to move the lens 3/4 way down!
Its a cheap test to see if there is a fingerprint on the lens. (You won't be able to see it - does not take much)
If this does not help, it means it needs a laser or worse. Probably just replace the player.
Apr 16, 2010 | Durabrand DVD-1002 DVD Player
I have a portable dvd player model number mdp1030 the unit keeps saying no disk I have tried numerous disks same results.
then i think the lens is not able to read the disk.
and so i would suggest you to buy a disk cleaner CD and run it in your DVD player and then use your regular disks.
if this is not working then it is some internal fault in your DVD players lens.
Aug 13, 2008 | Mintek Televison & Video
Dvd player dvd3020
This is a known problem with the DVP3020.
I am assuming that your lens cleaner is for CD as well.
Although identical, CDs & DVDs store data completely differently, which means DVD players need two lasers to read both formats.
It sounds like the DVD laser has failed on your player, which is why it will still play your lens cleaner.
Unfortunately the cost of replacing the laser outweighs the value of the player.
The DVP3020 has been replaced by the DVP3120 which is far more reliable.
The DVP3120 with a multi-region modification can be bought for £17.99 from CheapestElectrical.
Click here for details:
http://www.cheapestelectrical.co.uk/catalogue.php?category=6&title=DVD+%26+Video
May 13, 2008 | Philips DVP3020 DVD Player
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
