Question about High quality Nissan Sylphy Sew-on Genuine leather Steering Wheel Cover
Nissan Sylpyh 2002
Flashers are not working. Bulbs and fuses are OK
  • Jackie
    Jackie Jan 03, 2014
    Hi Jackie , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Where is the flasher unit located and could this be the problem
  • Jackie
    Jackie Jan 03, 2014
    Where is the flasher unit located and could this be the reason why the flashers are not working
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
The flasher needs to be changed .Sometimes they are located on top of the steering column under the dash board or near the fuse box.
Posted on Jan 05, 2014
What fuse is for the turn signals in a Ford explorer sport 2002
You should find a fuse that is labeled "multi-purpose" switch or similar. That would be the fuse. You might want to play with the hazard flashers switch a bit by pressing it on and off a bunch of times. Occasionally some debris gets in there and knocks everything out. Could be a loose connector on the multi-function switch. You'll have to remove the cowling to see it.
Good luck.
Dec 10, 2014 | 2002 Ford Explorer
Why does my tail lights and blinker lights not work in my 2002 kia spectra
Normally one would check in the following order.
1. bulbs
2. fuses
3. flashers
etc. So check the bulbs first... if they look burned out then replace them. Then see about the flasher if that bulbs look ok.
Good luck to you
Aug 14, 2014 | 2002 Kia Spectra
Which fuse do i replace to get my blinkers to work?
Try using your emergency flashers. If all the bulbs are working, you don't need to replace any fuses.
More often than not, the flashers go on these older rigs. Fuses rarely fail unless there is a much larger problem.
May 20, 2014 | 1984 Nissan Pickup
Emergency flashers work ok but indicators do not, have checked fuse and its ok changed bulbs all ok,
you need to replace the flasher canister, the car is equipped with two one for the emergency flashers and one for the turn signals the flasher is located on the fuse block.
May 12, 2011 | 1988 Ford Escort EXP
I have a Frontier XE 2001. Niether turn signal works have good bulbs and fuses are OK. Where else should I look.
did both signal lights stop working at the same time or not,it may just be the signal flasher has gone bad,it is located under the dash by the fuse panel.if the hazard flashers work then i would say the signal flasher is bad.with the hazards on you can locate it and that is what the signal flasher looks like and it is a separate flasher,
Mar 31, 2011 | 2000 Nissan Frontier
Turn signals are not working
Do your emergency flashers still work? Have you had a tech check the bulbs? It could be the bulbs, The flasher module that plugs in to your fuse panel or a fuse, faulty wiring< (which I seriously doubt)> or your blinker actuator on the steering column. I think its just a fuse but I could be wrong.
May 07, 2010 | 2002 Chevrolet Impala
My break lights don't come on when I press the break pedal. The bulbs, fuse, emergency flashers and turn signals work fine. Other suggestions for what is wrong and how to fix? Thanks
you may have a bad brake pedal switch. When you press the brake pedal, the switch is not activating the lights. If everything else is working, it's most likely your brake pedal switch.
Nov 14, 2009 | 2002 Nissan Pathfinder
2003 Envoy xl..right brake won't work..flashers
no wire harness problem probably that side. also lost some fuses?
Apr 20, 2009 | 2003 GMC Envoy Xl
High quality Nissan Sylphy Sew-on Genuine leather Steering Wheel Cover Logo
91 people viewed this question
Top Riz Insulation & Building Material Taishan Co., Ltd Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Riz Insulation & Building Material Taishan Co., Ltd Vehicle Part and Accessory Expert? Answer questions, earn points and help others
