Question about Whirlpool Stove Oven Sensor 8053344
Heat indicator light wont turn off
Heat indicator light will not turn off
Dishwasher wont turn on when I press start and... the "3 second" lock light is constantly on??
Child Lock Controls
To prevent children from accidently changing the
dishwasher cycle or starting the dishwasher, lock the
dishwasher controls by pressing and releasing the RINSE
ONLY pad (some models) or the NO HEAT DRY pad (some
models) for 3 seconds while the door is latched. An
indicator light on the lock graphic pad will illuminate when
the controls are locked and no new selections can be made
until the lock is released. To unlock the controls, press the
same pad, RINSE ONLY or NO HEAT DRY, again for 2
seoncds until the indicator light goes out.
Hope this helps?
Mar 31, 2016 | Frigidaire FFBD2406NW Built-In Dishwasher...
Thermastat wiring t6360
its normal always on the light for the indicator light of oven, if will go off the light if the heat inside reach by the set temp, and will on again if the heat inside will down.
the indicator light on its means the oven is in use. or some indicator light is on if the selector switch turn in other position.
Nov 02, 2013 | Honeywell Heating & Cooling
Hot tub wont heat up
What is going on? Is the tub running? Does it trip the breaker when you turn it on?
Is the heat indicator light on on the topside panel?
Need more information before we can answer the question.
Rod
www.uspartscenter.com
Jan 24, 2013 | Pool & Spa
Light flashing says check filter. Dryer wont heat up? What filter and where is it located
The filter screen check light is just a reminder indicator. It will always come on whenever you turn on the power. As for the heat, you didn't state whether it's electric or gas.
Jul 15, 2011 | LG Dryers
I have a whirlpool accubake duo, super capacity 465 and when I try to bake something the oven wont stay on...how do I get the oven to stay on
What do you mean that it wont stay on? Does it turn off and on during cooking? Does it just go off and wont come back on? The oven thermostat regulates the heat in the oven and the oven element and the oven indicator light will turn off and on during cooking. If it stayed on constantly on full oven element power everything would burn.
Mar 01, 2011 | Whirlpool Ovens
My Kenmore Dishwasher Wont Turn On and The Clean Light Wont Stop Flashing
This is an indication that the water did not heat properly, I have put together instructions on how to reset the control so you can use the dishwasher and things to check to resolve it from coming back. Follow the link and let me know if it helps.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 10, 2010 | Kenmore Dishwashers
Oven & broiler not heating on our Maytag MER5530. Lights on the control panel indicate it should be working. When I set oven temp, the oven "thinks" it's at that temp already. Turn broiler on and no...
May be the heating coil is bust?
The control panel is in parallel usually so as long as the controls are getting power they will turn on. But if the coil is gone you wont get heat. If you want to try fixing it, you may need a multimeter, or a continuity tester.
Jul 08, 2009 | Maytag MER5530 Electric Kitchen Range
Flashing clean light and wont start. Is there a sequence of buttons to reset the switchboard?
sani rinse---heated dry---sani rinse---- heated dry.. all the lights on console should light then close the door, let run for 20 -30 secs, and cancel the cycle, if the problem happens again yo need t call a servicer. 1 time maybe a fluke but to happen again indicates a heating, issue somewhere(or a lack of heating)
Mar 04, 2009 | KitchenAid 24 in. KUDU02FR Built-in...
Saeco Talkeo Giro
indicates that descaling needs to be carried out. To cancel Press and hold the hot water button until indicator light goes off (about 6 seconds)
Mar 01, 2009 | Saeco Talea Giro Espresso Maker -...
Whirlpool Stove Oven Sensor 8053344 Logo
61 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
