Question about mid M9100 9" Dual Camera Android 4.0 ICSOS 1.2Ghz Capacitive Mu
I can connect to the internet but can not connect to play store or netflix
Get netflix and others
Netflix is available on play store. Go to play store and search for Netflix or any other app you nee and just download it.
Professional essay writing services cheap essay writing services uk essay...
Jun 07, 2016 | Televison & Video
Why do Netflix movies keep stopping?
It could possibly be a slow internet connection speed. Netflix posted requirements. This is a good site to check your speed. http://www.speedtest.net/ Internet Connection Speed Recommendations Below are the Internet download speed recommendations per stream for playing movies and TV shows through Netflix.
  • 0.5 Megabits per second - Required broadband connection speed
  • 1.5 Megabits per second - Recommended broadband connection speed
  • 3.0 Megabits per second - Recommended for SD quality
  • 5.0 Megabits per second - Recommended for HD quality
  • 25 Megabits per second - Recommended for Ultra HD quality
HD Video Quality
Movies and TV shows we have available in high definition will play in 720p or better with a fast enough internet connection. To watch Netflix in HD, ensure you have a HD plan, then set your video quality setting to High in the Playback Settings for your account.
Netflix Bandwidth Usage
Higher quality video uses more bandwidth than lower-quality video. If your service provider applies a bandwidth or data cap to your Internet service, you canManage Bandwidth Usage by changing the video quality settings to Low or Medium to consume less data.
Oct 01, 2014 | Netflix
Ds1489@windstream.net
Your internet provider shouldn't matter. Your user name and password are stored in the Wii or whatever you use to connect to your modem. It should connect same as usual.
Good luck.
Aug 02, 2014 | Netflix
Netflix for a hp tablet
Hello, I order to get netflix on tablet you will have to be able to go to the internet and go too www.netflix.com or go to google play store and download the app.
Watch TV shows movies anytime anywhere Plans from 7 99 month https://play.google.com/store/search?q=netflix%20app&c=apps
Apr 20, 2014 | Netflix
Cant get oo computor
Test the Internet Connection
Make sure yourcomputor an Internet connection by opening another Internet application or the app store.
  • If you are not able to reach the Internet through your cellular carrier, try a wireless network.
  • If you are not able to reach the Internet through a wireless network, you may having network connection issues
  1. Check the date and time on your computor
    If the date and time of your device is significantly different from the current date and time, you will have a problem playing your video.
    1. Tap the Settings icon on the Home screen.
    2. Tap General.
    3. Tap Date & Time.
    4. Tap Set Date & Time.
      • If the date and time are incorrect, adjust the time until it matches your time zone.
      • Or, tap On/Off toggle to On in the Set Automatically field.
  2. Reinstall the Netflix application
    1. From the main menu, touch and hold the Netflix app on the Home screen until it jiggles.
    2. Tap the X in the top left of the Netflix icon, then tap Delete.
    3. Enter the App Store, search for "Netflix" and select the free Netflix app from Netflix, Inc.
    4. Tap the Install button. You will need to enter your iTunes password to install the app.
    5. Once installed, tap the Netflix icon.
    6. Enter the email and password for your Netflix account and tap Sign In.
  3. Troubleshoot your Internet Connection
Oct 24, 2013 | Netflix
Netflix wont connect on my apple tv and i'm connected to the enternet
  1. Test the Internet connection on the Apple TV
    1. From the main Apple TV menu, navigate to Trailers.
      • If you don't see Trailers: Select Movies, then In Theaters.
    2. Select any title and click Play. If trailer plays, the device is connected to the Internet.
    3. If you are unable to connect to the Internet, you may be having network connection issues.
  2. Restart the device
    Restart your device by unplugging it from power for at least 10 seconds, then plug it back in and turn it on with the power button. Restarting the device is often enough to restore your ability to connect to our service.
  3. Disconnect Apple TV from your Netflix Account
    1. Navigate to the main Netflix menu inside the application and click Logout.
    2. Select Yes.
    3. You will be returned to the Apple TV's main menu, at which point the device has been successfully disconnected from your Netflix account. You may select Netflix to sign back in with your account information or connect as a different user.
  4. Troubleshoot your Internet Connection
Oct 23, 2013 | Netflix
Download on my computer
  1. Test the Internet connection on your device
    Many devices have an application to test the Internet Connection. If not, try opening the application store or another Internet-enabled application and check if your device is able to reach Internet services.
    • If you are unable to connect to the Internet, you may be having network connection issues.
    Note: All devices are different. Some may take up to 15 minutes to fully restart.
  3. Disconnect and Reconnect the Netflix application
    These instructions will work on most consumer electronic devices with the Netflix application.
    1. Launch the Netflix app.
    2. Using the arrows on your remote, enter the following sequence:
      • Up, Up, Down, Down, Left, Right, Left, Right, Up, Up, Up, Up
    3. Select Deactivate and exit the screen.
    4. Restart the Netflix app and sign in to your account.
Oct 22, 2013 | Netflix
Need netflix app for kyros 7042 not kindle
  1. Test the Internet Connection
    Make sure your iPad, kindleor iPod touch has an Internet connection by opening another Internet application or the app store.
    • If you are not able to reach the Internet through a wireless network, you may having network connection issues.
  2. Check the date and time on your Apple iPad, kindleor iPod touch
    2. Tap General.
    3. Tap Date & Time.
  3. Reinstall the Netflix application
Oct 19, 2013 | Netflix
I can't access the playstation network, Netflix, or PS store but I can access the Internet. I have wifi and my iPhone works fine. When I try to log in it says "connection with PS network timed out
Turn the playstation off and then back on. You have to be connected to PSN to play Netflix and connect to the PS Store--is something maybe wrong with your username/password?
Feb 12, 2011 | Sony Playstation 3 (PS3) Console
mid M9100 9" Dual Camera Android 4.0 ICSOS 1.2Ghz Capacitive Mu Logo
70 people viewed this question
Top mid Computers & Internet Experts
David Payne
David Payne
Are you a mid Computer and Internet Expert? Answer questions, earn points and help others
